Door lock wiring?
Discussion in '4th Gen. Tacomas (2024+)' started by synfinatic, Mar 31, 2025.
  1. Apr 15, 2025 at 9:43 PM
    synfinatic
    synfinatic [OP] Well-Known Member
    San Jose, CA
    2024 Trailhunter
    Almost like I know what I'm doing. Only made two sacrifices to the fuse gods wiring up the locks, cargo & tail lights, and amp/voltage meter. Well, I did install the fuse right at the battery where I added the extra wire to power everything, so I guess I'm not totally stupid. :D
  2. Apr 15, 2025 at 9:57 PM
    synfinatic
    San Jose, CA
    2024 Trailhunter
    As full custom wiring goes... I'm fairly happy with this? Still need to wrap a few things with Tesa tape before I call it done, but it was dark and called it a night. Designed and 3D printed some brackets for the relays, fuses and bus bars as well as some cable management thingy's for the T-slots. But there aren't a lot of great places or ways inside to run wires near the corners or the doors so had to make do with 3M cable management stickers.
    Right side showing all the hardware. Volt/Amp meter to keep an eye on the 12V starter battery since everything runs off that. Another switch to run the cargo lights for on, off, and tied to the door lights. All the wiring for power, doors, etc is on quick disconnects so if I ever remove the cap, I can do so with out cutting anything.
    Driver side showing the wiring running across the T slots:
