Door hinge to body seperation, help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nvtaco, Sep 8, 2013.
  1. Sep 8, 2013 at 7:51 PM
    nvtaco
    nvtaco [OP] Well-Known Member
    Vancouver, BC
    07 Double Cap TRD Sport
    Vent visors, backup lights, the loadhandler!
  2. Sep 8, 2013 at 7:52 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Pictures?
  3. Sep 8, 2013 at 8:16 PM
    nvtaco
    Vancouver, BC
    Just trying to upload, first time..
  4. Sep 8, 2013 at 8:17 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  5. Sep 8, 2013 at 8:20 PM
    nvtaco
    Vancouver, BC
    That's it! The brown looking area in the right that is also a silver painted gasket. That's the area that has come away from the body.
  6. Sep 8, 2013 at 8:46 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That's not a gasket. That is sealant.
    I'm not sure if Toyota uses adhesive to attach the hinge to the body or if it is welded, but I suspect it is attached with adhesive and it has been compromised.
  7. Sep 8, 2013 at 9:08 PM
    nvtaco
    Vancouver, BC
    Hmm..the door doesn't jiggle, but it now swings a tiny bit farther. I wonder what product I could spray in there to hold and seal? I think taking the hinge or door off would be hard.
  8. Sep 8, 2013 at 10:00 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    This.
    Many body panels are bonded, rather than welded or bolted. The adhesive is VERY strong, but if it starts to let go, it needs to be repaired by a pro.
    The adhesive, where it squeezes out, appears to be nothing more than a filler.
  9. Sep 8, 2013 at 11:00 PM
    nvtaco
    Vancouver, BC
    Very good points, see a bodyman and get some advice. I will do that. Thnx
  10. Sep 9, 2013 at 8:49 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And this reinforces my "cringe factor" when it's windier than expected and the door gets yanked out of my hand when opening it.
    Last time that happened, the door was prevented from overextending.... by my wife's fender :mad:
  11. Sep 9, 2013 at 9:14 PM
    offroadwonder
    offroadwonder Well-Known Member
    Jared
    Aurora, CO
    '10 Tacoma DCSB 4x4 TRD Off-Road
    Chopped mud-flaps (yup, I'm hardcore)
    Seriously? Our doors are glued on?
  12. Sep 9, 2013 at 9:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Opps.
  13. Sep 9, 2013 at 9:33 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No, The door hinges are not glued on. There are bolts that hold the hinge to the body and also the door. There is a sealant in between the door hinge and the body, but The bolts are what holds it together. The sealant is just to prevent moisture from collecting in the seam.
    Go look.
