Door harness pins?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 5nahalf, Apr 29, 2019.
  1. Apr 29, 2019 at 7:18 AM
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Anyone have a part number or know a good place to get the door harness pins?
    Im looking for the ones that go on the body side plug that the harness plugs into. Replacing some speakers and want to use the factory plugs, but with my own harnesses.
    The parts department at the local dealers always give me the deer in headlights look when I ask about wire harness parts.
  2. Apr 29, 2019 at 7:32 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Waytek and Mouser are great for components but it takes work to determine what exactly you will need. Many OEM connectors are proprietary (or special at the least) with keying and the like to prevent being plugged in to the wrong loads.
    You'll also likely need the tools to crimp pins and create the connectors.
  3. Apr 29, 2019 at 9:12 AM
    caribe makaira
    Caribbean, Puerto Rico
    Got a pic of said connector?
  4. Apr 29, 2019 at 9:27 AM
    5nahalf
    Erik
    Minnesota
    This is one of the rear doors (not my picture)
    I need to remove the factory wires from the plug (body side) to install my wires that will plug into the harness dirrectly
    Front doors I need to repin the 2 factory wires, plus add 2 more wires to each door plug.
    So, I need -
    4 rear pins (body side)
    8 front pins (body side)
    4 front pins (door side)
    Little background to give to better idea of what im doing. I made new wire harnesses to my radio. I have 3 way components up front, and coax in the rear.
    Front has woofers and tweeters in the doors, mids in the dash. I want my harness to integrate with the factory harness with NO wire cutting.
    I have 10 channels worth of amps in the back, so each speaker is getting its own channel.
  5. Apr 29, 2019 at 9:36 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
  6. Apr 29, 2019 at 9:38 AM
    BigWhiteTRD
    Ted
    5nahalf[OP] likes this.
  7. Apr 29, 2019 at 9:49 AM
    caribe makaira
    I can't find the connector in what I have, so I have no idea what pins you'd need...the large ones could be 2.3II (090) or 1.5. Unpin one large one and take pic...same for a small one.
  8. Apr 29, 2019 at 10:48 AM
    5nahalf
    Erik
    Minnesota
    The wires I need are the bigger ones, the black and white on the left side of the plug. Im going to pull the plug out tonight after work to see what it looks like.
  9. Apr 29, 2019 at 11:17 AM
    caribe makaira
  10. Apr 30, 2019 at 11:48 PM
    caribe makaira
    :popcorn:
  11. Jan 1, 2020 at 9:26 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I wonder if these are the same as the heater plug pins.
