Door Ding is driving me crazy!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AZ Kid, Nov 25, 2021.
  1. Nov 25, 2021 at 10:51 AM
    AZ Kid
    AZ Kid [OP] New Member
    21 Tacoma Off Road
    New to TW and looking for help with 2021 Tacoma.
    When I turn truck off and open drivers door it starts beeping. It makes feel like I’m forgetting something. Can’t figure it out!
    I tried Carista and their customer support.
    Pressing and releasing
    the toggle in the frame when the door is open turns it off. But that’s only good if I’m planning on leaving the door open.
    Thanks you for your consideration
    AZ
  2. Nov 25, 2021 at 11:02 AM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Welcome to Tacomaworld. Are your Headlights switched to the on position? They truck will let you know they are on but will eventually shut them off.
  3. Nov 25, 2021 at 11:06 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    When it’s beeping, look under the dash to find it and unplug it
  4. Nov 25, 2021 at 11:26 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Do you open the driver's door and THEN shut it down? If you do that it will bing at you every time. Shut it down, then open the door, and it won't bing. Unless of course your lights are on.
    Mark77 likes this.
  5. Nov 25, 2021 at 11:28 AM
    bigbadbarty
    bigbadbarty Well-Known Member
    Granite Falls, WA
    2021 Tacoma OR DCLB
    is your sunroof open?
    Thatbassguy likes this.
  6. Nov 25, 2021 at 11:32 AM
    Snoman002
    Snoman002 Well-Known Member
    Sno
    21 DCSBORSWMT
    I currently own three Toyotas and they are the most dingy cars I have ever had. Most of the time you cannot even tell what it is dinging for.
    I was under the impression that Carista could shut the various dings off, to even include the seatbelt warning. If it isn’t Carista tech stream may
    Paddy1337 and brandon78lusch like this.
  7. Nov 25, 2021 at 11:40 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Carista can shut off your seat belt dinger but the key in ignition/door open no.
    2nd gens you could disable it if you had the gauge cluster out for an led swap - I’m not sure where the 3rd gen noisemaker is but if I recall it’s more labor intensive to remove altogether
    Snoman002[QUOTED] likes this.
  8. Nov 25, 2021 at 11:43 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    This
  9. Nov 25, 2021 at 11:44 AM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    ?? My 2021 tacoma never dings at me. It does one long beep on start up and thats it. Do you not wear a seatbelt or something? What would the car even ding for?
  10. Nov 25, 2021 at 11:48 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm pretty sure the Toyota Tech stream software can make the changes you want.
    I own my own copy and have turned off the dings and turned down the key minder to the lowest setting(that tone comes from the factory at its highest setting).
  11. Nov 25, 2021 at 11:55 AM
    A-ron
    A-ron YotaWerx Authorized Pro Tuner - Colorado
    Aron
    Colorado
    21 TRD Sport - Cement
    YotaWerx Blackhawk 2.1 Tune, TRD Lift, DV8 front bumper, DD SS3 Pro Fog Lights, DD Stealth Light Bar, 4Runner Wheels, Leather Seat Covers, Morimoto Tails, Meso sequential mirror lights, Ect button relocated to shifter,
    As far as I know there isn't anyway to turn this one off. I also push the button on the door pillar anytime my door is going to be open for any length of time after I shut off the truck. Unfortunately there is nothing in Carista or Techstream that shuts off the annoying beep, at least not in my 2021.
  12. Nov 25, 2021 at 12:23 PM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    My door ding is also driving me nuts. Some a-hole dinged my door on a parking lot. Wait... you're talking about door chime?!
    Skydvrr likes this.
  13. Nov 25, 2021 at 12:27 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Have you tried turning your Taco off (headlights off or on Auto) BEFORE unlatching the door?
    Works on my '21 TRD OR.
  14. Nov 25, 2021 at 12:29 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Yeah these things beep and ding like crazy. Super annoying.
  15. Nov 25, 2021 at 1:43 PM
    Snoman002
    Sno
    21 DCSBORSWMT
    nope, always wear the seatbelt
    between the three they are always making sound. The kids Prius is usually the headlights being on (no auto lights). My truck I think I open the door before shutting the key off all the way. The push button start on the Highlander I know I push the button at the same time as I pull the door handle. It also dings if one of the kids unbuckls, a rare thing but not unheard of.
    Obviously my fault in all cases but still always making noise
  16. Nov 25, 2021 at 9:54 PM
    AZ Kid
    21 Tacoma Off Road
    Thanks for the thoughts. I have lights on auto and no sunroof and turn the truck off take my seatbelt off before opening door.
    Still ringing!
  17. Nov 25, 2021 at 9:55 PM
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    What is this high tech you suffer for?
  18. Nov 25, 2021 at 9:56 PM
    bigbadbarty
    Granite Falls, WA
    2021 Tacoma OR DCLB
    When mine beeps, it displays something in the cluster screen. But that only happens if the sunroof is left open. And it may also happen if the windows are down.
  19. Nov 27, 2021 at 9:40 PM
    AZ Kid
    21 Tacoma Off Road
    Can someone inform me how to remove a thread when I’m done. Thanks
  20. Nov 27, 2021 at 9:41 PM
    Woodini
    Ray
    89 Pickup 22RE 4wd
    Edit -> delete?
