Door check, can it be welded?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimmydabaws, Mar 21, 2024.
  1. Mar 21, 2024 at 4:09 PM
    Jimmydabaws
    Jimmydabaws [OP] Well-Known Member
    James
    2017 Grey Tacoma TRD
    2.5 eibach lift 2 inch rear block 33/
    Gust of wind took my door today and it looks like it broke the door check mount. Is it possible to kinda tack weld it? It seems like where the door check is bolted to the door. I’ve attached a pic
  2. Mar 21, 2024 at 4:35 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Yes…..that can be welded
  3. Mar 21, 2024 at 4:40 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    it can be welded , they would have to unscrew it to see the extent of the damage
  4. Mar 21, 2024 at 5:30 PM
    Jimmydabaws
    James
    Just did 2 fender bolts in it, seems to be holding better and doesn’t make as much noise in that last inch or 2 when closing the door
  5. Mar 21, 2024 at 5:34 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Damn straight. Quick fix and inexpensive as well.
  6. Mar 21, 2024 at 9:23 PM
    Jimmydabaws
    James
    Welding might be the way to go lol
    wilcam47 likes this.
  7. Mar 21, 2024 at 10:22 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga STRONG Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    I would remove the nuts and grind those cracks clean and down to bare metal. A dremel will get in there fine. If the cracks can be compressed together, I’d do that before stitching. If not, weld the cracks, grind flush to sit washers. And tack the washers down also for extra insurance.
    EDIT: you can use smaller washers to be able to weld around the washer. Otherwise, you’ll have to open up the factory hole a bit.
  8. Mar 21, 2024 at 10:56 PM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Just FYI, those washers won't be a permanent solution. Those cracks have exposed bare metal, it will be begin to rust quickly. You need to get it repaired or at least sealed ASAP.
  9. Mar 22, 2024 at 2:33 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Also need to stop drill cracks so they don’t continue
  10. Mar 29, 2024 at 6:48 PM
    Jimmydabaws
    James
    Truck is always oiled so not overly worried about it, but I’ll probably try to find a smaller washer and weld
    Topanga Taco likes this.
  11. Mar 29, 2024 at 6:50 PM
    ill ay
    ill ay I DO MAN STUFF
    The Valley
    2012 Pre Tacoma & 2017 4x4 SR5 Tacoma
    How about sanding it down, clean it and then JB weld it? Then add those washers on top as you did?
  12. Mar 29, 2024 at 6:54 PM
    Jimmydabaws
    James
    I’ve used jb weld in the past and I’ve found it doesn’t do well with flex. Its strong when not needing to flex if that makes sense lol
    MannyS, Big tall dave and wilcam47 like this.
  13. Mar 29, 2024 at 8:59 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    no, jb weld, despite the name, is just an epoxy. it doesn't actually weld the surfaces together, and won't last long-term in a flexing situation.
  14. Mar 29, 2024 at 9:14 PM
    Jimmydabaws
    James
    +1 to that. I used it to fix my gel coat when I skimmed a rock with my old seadoo. It couldn’t handle the flex the gel coat and Fiberglass would give
  15. Mar 29, 2024 at 9:42 PM
    ill ay
    The Valley
    Thanks, learn something new every day. I've used jb weld a lot but you're right, nothing that actually flexes.
  16. Mar 30, 2024 at 6:29 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    You do know the check strap assy is replaceable and not astronomically priced, correct? Ski
    turbosnail and hiPSI like this.
  17. Mar 30, 2024 at 6:56 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    its not the check thats broken. It's the mounting point it bolts to.
