Door ajar ding
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBlanco4x4, Aug 27, 2019.
  1. Aug 27, 2019 at 4:40 AM
    TacoBlanco4x4
    TacoBlanco4x4 [OP] Member
    2018 White TRD OR
    2018 Tacoma...does anyone know if you can turn off the door ajar ding? With the truck off, and my driver door open, the ajar warning sounds. If i open any other door, or close and reopen the driver door, the ding stops. Any ideas?
  2. Aug 27, 2019 at 4:51 AM
    TX_Taco88
    TX_Taco88 IG: 4lo_taco
    Jeremy
    WA
    '18 4x4 TRD-OR DCLB
    KINGS, Bruteforce armor, Falcon wheels
    When the door is open, just push and release the little rubber “button” on the door frame located on the right side in the middle once the door is open.
    That should cancel the sound. Perfect for when you’re cleaning your truck or just don’t want to hear that annoying ass sound lol.
  3. Aug 27, 2019 at 6:22 AM
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
    You have the push button start/stop? Try shutting the engine off before you open the door. My theory is that people have died from CO poisoning when they leave the engine running in the garage; the ding is to remind you the engine is running. Why it doesn't stop when you turn the engine off with the door open is something only Toyota can answer.
    If yours is a keyed ignition, then totally disregard my answer.
    http://www.safetyresearch.net/blog/...yless-ignition-related-deaths-takes-no-action
  4. Aug 27, 2019 at 6:29 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Good tip, didn't think of that, I'm always annoyed when my little one is asleep and im trying to get her out of her car seat into the house and it keeps dinging
    TX_Taco88[QUOTED] likes this.
  5. Aug 27, 2019 at 6:51 AM
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    Techstream
    MaTaco_4x4 likes this.
  6. Aug 27, 2019 at 7:18 AM
    MaTaco_4x4
    MaTaco_4x4 Well-Known Member
    2018 Tacoma Sport DCLB
    x2 on techstream.
    Or Carista.
  7. Aug 27, 2019 at 12:03 PM
    TacoBlanco4x4
    2018 White TRD OR
    So I can't find a way to turn off the ding with Carista - if anyone knows what I'm missing there, that'd be helpful too.
  8. Aug 27, 2019 at 12:06 PM
    TacoBlanco4x4
    2018 White TRD OR
    Yeah, this is something I didn't think of. Thanks! Easy enough.
  9. Aug 27, 2019 at 12:12 PM
    sdfuller88
    sdfuller88 Well-Known Member
    Reno, NV
    I unscrewed the plunger and disconnected the connector to it. Never dings. By doing this it also wont show that your door is open anymore but that’s pretty obvious in my opinion. You can always reconnect if you want the ding back.
    AxisCab, Kolohe07 and Anton338 like this.
  10. Aug 27, 2019 at 12:14 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Techstream and Carista won’t be of any help. Pushing the button does not seem to work on Access cabs. Every other method I’ve come across to silence it also disables the turnsignal noise.
    AxisCab and tonered like this.
  11. Aug 27, 2019 at 12:15 PM
    TacoBlanco4x4
    2018 White TRD OR
    Sounds like the way to go! Also, duh - if the door is open on the driver side, I think I'd know...
    jonnytacoo likes this.
  12. Aug 27, 2019 at 12:15 PM
    VB25
    2018 TRD OR ACLB AT
    Best method available, but it disables the interior lights coming on with door open.
  13. Aug 27, 2019 at 12:18 PM
    sdfuller88
    Reno, NV
    Yea I leave mine off and manually turn them on if I need them. Also if you open the rear door real quick they come on. I’m an access can as well.
  14. Aug 27, 2019 at 12:21 PM
    MaTaco_4x4
    I never tried. I assumed, because it's settable that Carista would do it.
    Isn't Techstream 14 still free? Mine was.
  15. Aug 27, 2019 at 12:21 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is the key cylinder mod that removes the plunger for the chime switch. But in mine, I hear something prime when my key hits it. So I am not sure if I want to lose that.
  16. Aug 27, 2019 at 1:22 PM
    Charles135
    Charles135 Well-Known Member
    LA-Orange county
    19 cement trd
    If you do this will the truck still shut off when you open the door after it has been “remote started” ?
  17. Aug 27, 2019 at 1:40 PM
    TX_Taco88
    Jeremy
    WA
    '18 4x4 TRD-OR DCLB
    Glad it worked
    was the vehicle on or off ? I know it works for sure when the vehicle is off, can't remember about when it on and im out of town right now otherwise i'd check for you. but that is for my DCLB
  18. Aug 27, 2019 at 1:54 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Not an option in Carista for my '18 AC CB, on or off. Wish it was..
    tonered likes this.
  19. Aug 30, 2019 at 12:09 AM
    sdfuller88
    Reno, NV
    I have an sr5 cause I like how it is still 90s tech. ie I still have a key for the ignition. Remote start works fine for me, push button models I don't know but I would assume that since it can’t tell the door was opened it shouldn’t turn off. It’s literally 30 seconds to unscrew the switch from the door and unplug the connector. Give it a try and let us know your results
  20. Jul 21, 2022 at 7:07 AM
    jonnytacoo
    jonnytacoo Well-Known Member
    Jonny
    So Cal
    2018 TRD Off-Road 4x4
    OEM
    My car won’t lock from outside and I can see it says door ajar & all the doors are closed. I read a leak from windshield could cause wire to short out and cause this and the windshield was replaced when I bought it. So I can just turn this feature off completely by unplugging it?
    JJ Diablo likes this.
