Don't use engine oil additives
Discussion in 'General Tacoma Talk' started by DeuceDeuceBravo, May 13, 2024.
  1. May 13, 2024 at 6:51 AM
    DeuceDeuceBravo
    DeuceDeuceBravo [OP] Well-Known Member
    New England
    I've been telling friends and family this for years. Standalone engine oil additives are not only a waste of money, they can be harmful for your engine. You're much better off buying a good oil and leaving it alone.
    From a true expert:
    I-Give-Up, DocJ, 0xDEADBEEF and 2 others like this.
  2. May 13, 2024 at 7:00 AM
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
  3. May 13, 2024 at 7:01 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    BG MOA is good stuff
    TnShooter likes this.
  4. May 13, 2024 at 7:04 AM
    DeuceDeuceBravo
    New England
    Yeah, but recommended based on what? Marketing? Anecdotes? The science says they're almost all bad, or at very least a waste of money.
  5. May 13, 2024 at 7:06 AM
    DeuceDeuceBravo
    New England
    BG is an absolute racket. I worked at several dealers over the years and the only reason they use it is because BG sales reps convinced them it was an upcharge that the customers would pay for.
    I-Give-Up likes this.
  6. May 13, 2024 at 7:20 AM
    bfonic
    bfonic Well-Known Member
    2023tacoma
    motor honey is the stuff, pours out like a no. 7 gear oil, kinda like king syrup.
    Steves104x4 likes this.
  7. May 13, 2024 at 7:28 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Why is that good?
    SR-71A and DeuceDeuceBravo[OP] like this.
  8. May 13, 2024 at 7:29 AM
    saajanpatel1
    Saaj
    MA
    2022 Tacoma Limited
    None
    I use Project Farm's videos for determination on how good products are
  9. May 13, 2024 at 7:32 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    If I ever add anything, it's Marvel Mystery Oil. Been around since 1923 for a reason.
    My dad used it all the time & was a head mechanic for over 50 years.
    He hated everything, including me, lol :)
  10. May 13, 2024 at 7:38 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    That's the mystery.
    To OP: are random YouTube videos actually reputable sources for making decisions on vehicle care?
    I have an engineering degree, been driving and working on Toyotas for over a decade, and I'm good at BSing technical shit. Do you want some unsubstantiated recommendations from me as well?
    Edit: goofy face in a thumbnail actually removes any expert credibility the guy might have. Whatever credentials he had, he is now reduced to an entertainer. (It's like Top Gear: some good information I'm sure, but most of it is for show)
    Squirt, ridefreak and saajanpatel1 like this.
  11. May 13, 2024 at 7:40 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    additives such as ZDDP are beneficial for a flat tappet engines . During cam break in on a flat tappet cam and without ZDDP you can lose cam lobe or flat tappet Lifter in a matter of minutes
    Nothings worse than watching your expensive engine being destroyed in minutes because of lack of proper oil additives
    This is my $14k 600hp 427sbc roller cam engine that has ZDDP Grease on all the bearings and ZDDP break in oil . After initial break in everything checked out okay with very little to no metal glitter found on the oil filter media
  12. May 13, 2024 at 7:55 AM
    DeuceDeuceBravo
    New England
    Marvel Mystery Oil might have been useful in those old oils. But modern oil is VERY different.
    The guy is basically an oil scientist. He worked for Joe Gibbs racing and has formulated oil for race cars, among other things. He's also worked with places like LN Engineering which is highly reputable in the Porsche world. Don't judge a book by its cover (or a video by its thumbnail).
    Agreed. ZDDP is highly beneficial for many engines, especially older ones. I use a high ZDDP formula in my 1979 Volkswagen. But the point is that adding ZDDP to an oil that isn't designed to work with it can do more harm than good. More isn't always better. (And high ZDDP with kill catalytic converters.)
    Break-in oil is a completely different conversation.
    0xDEADBEEF and Steves104x4 like this.
  13. May 13, 2024 at 8:12 AM
    0xDEADBEEF
    When I think about maybe running an additive in my engine, I also think about the millions of them that work perfectly fine with no special treatment whatsoever.
    DeuceDeuceBravo[OP] likes this.
  14. May 13, 2024 at 8:21 AM
    saajanpatel1
    Saaj
    MA
    2022 Tacoma Limited
    None
    I am no expert but doesn't oil already have additives in it? Depending on the conditions, how you drive, and what brand/type of oil you use, you may need to add additives? Maybe additives were needed before but they can be used now.. over using them can do harm but i don't think once in a while should...
    Schlappesepple likes this.
  15. May 13, 2024 at 8:33 AM
    DeuceDeuceBravo
    New England
    Yes, engine oils have additives already. They are very specific additive packages with formulations of chemicals that are designed to work together. The oil companies have spent an enormous amount of resources on getting these formulations to work correctly and pass rigorous testing to meet OEM standards.
    The point is that adding an off-the-shelf additive will likely screw up the balance of chemicals and cause unwanted consequences.
  16. May 13, 2024 at 8:38 AM
    saajanpatel1
    Saaj
    MA
    2022 Tacoma Limited
    None
    What sort of consequences
  17. May 13, 2024 at 8:47 AM
    DeuceDeuceBravo
    New England
    Watch the video. :) He goes into great detail about why they're bad.
    But if you need a tldr....
    - reduce the effectiveness of the original oil
    - cause higher wear
    - make the oil acidic
    - change the viscosity of the original oil
    - reduce the lifespan of the original oil
    - they will take your hard earned money while providing no benefit
  18. May 13, 2024 at 9:06 AM
    TacoTuesday1
    FL
    Oil. Free
    Filter. $5
    Some additive if you feel like it. Max around $10
    whoa $15 oil change so expensive
    US Marine likes this.
  19. May 13, 2024 at 9:34 AM
    saajanpatel1
    Saaj
    MA
    2022 Tacoma Limited
    None
    Where do you get free oil
  20. May 13, 2024 at 9:38 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    From those 2000 mile oil change guys
