Don't disconnect the battery?????
Discussion in 'Technical Chat' started by Sky King, Dec 13, 2012.
  1. Dec 13, 2012 at 7:44 PM
    Sky King
    Sky King [OP] Well-Known Member
    Sam
    Memphis, Tn
    07 PreRunner SR5
    Serious sound deadening in the cab and extensive audio system.
    Ok, this is my first Toyota period. Being an experienced aircraft mechanic with MANY years under my belt and having done all the maintenance on all my prior vehicles, I am the type that reads the manuals.
    I have a lot of plans for this "new" Tacoma. Most involve aftermarket audio, (the factory system sucks). Multiple amps, signal processing, speakers, subs, satellite radio, blue tooth and aftermarket head unit, a CB radio, possible aux driving lignting and so on.
    I noted a yellow boxed warning in the owners manual about NOT disconnecting the battery. WHAT IS WITH THAT??? Needless to say, making these additions to the vehicle will require having the battery disconnected as all these items will require running power.
  2. Dec 13, 2012 at 7:59 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Hmmmm, i've disconnected the battery on my '12 a few times already. No issues. Know what head unit your looking into? Pioneer DEH-80prs is a solid option :)
    ~M
  3. Dec 14, 2012 at 4:49 AM
    Sky King
    Sam
    Memphis, Tn
    07 PreRunner SR5
    Well my "new" Tacoma is an '07 but new to me. I couldn't figure any good reason you shouldn't disconnect the battery.
    As for the audio. I am going to try to utilize as much of the equipment I had in my previous vehicle. The reason I got this truck is that it replaces a 99 Saturn that a 175 lb, 8 point buck totaled when I hit it on the interstate at 75 mph.
    The head unit is a Kenwood, (don't remember the model right off hand). It is a CD changer controller, AM-FM with CD. It is Satellite and Blue Tooth ready. The amps are both Kenwood, one a four channel 360 watt which drives 4 MB Quart co-axials with outboard crossovers. One in each corner of the car, one channel of the amp going to each speaker. The other amp is a Kenwood 600 watt, two channel amp driving two Boston Acoustic dual voice coil subs, one channel of the amp going to each sub. The signal goes through a Audio Control EQS six channel, 13 band equalizer with dedicated sub out put. I also have a Sirius Satellite receiver which is directly controlled by the Kenwood head and a Blue Tooth module for the head. This is all tuned using pink noise and a real time analyzer (RTA).
    I am confident that all the electronics will be usable but I don't know yet if the speakers I have will fit. The factory stuff in the truck really sounds muddy. I don't know yet what I can use to replace the factory speakers in the doors, with the separate tweeter in the front doors and just where I can fit my subs right now.
    But all this is going to take some experimentation and the battery is going to have to disconnected while I wire all this up. There were also multiple warnings about after market electronics interfering with the truck systems. Any input any of you have about this would be appreciated. These are probably Toyota disclaimers just to cover their asses when in reality there will be no problem but I thought I would ask.
  4. Dec 14, 2012 at 4:53 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i have disconnected mine a few times. most recent was when i put a new pioneer avh p4400BH head unit in.
    i also have a ’07 i got mine last year. also FYI depending on the head unit. you may really need speakers. i get dad distortion when volume is at like 25 to 28+. (unit goes up to 40 on volume) i really need new better aftermarket speakers.
  5. Dec 14, 2012 at 4:58 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    It's probably in reference to something. What else did it say?
    I highly doubt it just says, Don't disconnect the battery ever for any reason.
  6. Dec 14, 2012 at 5:03 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Disconnected my '07 PLENTY of times. Your good. :thumbsup:
  7. Dec 14, 2012 at 5:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2.
    I have a 2007 and have disconnected the battery several times. In fact, if you get an error code or do any kind of major maintenance to the vehicle, disconnecting the battery for 20 minutes is how you can reset the ECU. There's no harm in doing so as long as you do it correctly.
  8. Dec 14, 2012 at 5:57 AM
    oldstick
    oldstick Medicare Member
    GA
    I imagine what they really mean is "only an authorized Toyota dealer disconnect the battery so they can charge you $125 to do it"
    Sort of like "DANGER - CAUTION, never operate vehicle with worn or damaged wiper blades - contact Toyota dealer immediately for servicing."
  9. Dec 14, 2012 at 5:57 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    also when i take the + off i wrap a towel around it or a shop rag, it does not like to site far a way(just the way the wires are) so i wrap a shop rag around it so that if it does touch the battery it wont do anything. i don’t think you HAVE TO do this but i do and most my friends that care about their cars/ trucks do this as well.
  10. Dec 14, 2012 at 11:23 AM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    :smack:
    This is why it says not to disconnect the battery! Negative first, there is no need to remove positive cable unless changing or servicing the battery. If you ground out your wrench when removing the positive you can cause damage to your vehicle or yourself. If you are wearing a ring that is touching the wrench you will cause serious burns to that finger. aslo can blow main fuse, ecu's, ground wires....
    Op there is no issue disconnecting your battery if done correctly.
  11. Dec 14, 2012 at 11:33 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    My 2006 gets disconnected every time I park the thing for any length of time. No harm done.
  12. Dec 14, 2012 at 11:52 AM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    They could be talking about it resetting the ECU. Some people have mentioned that thier truck runs rough or whatever after leaving the battery disconnected because the ECU has reset and is having to learn your engine again.
    Who knows. They gotta put something in there to make it look like they actually have some useful info....
  13. Dec 14, 2012 at 12:06 PM
    Pugga
    Massachusetts
    So you're saying your battery never gets connected? :laughing:
    :anonymous:
  14. Dec 14, 2012 at 12:15 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    HAHAHA
    jackstand boi!
  15. Dec 14, 2012 at 12:19 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've wondered about this. When disconnecting to re-set the ecu all that's required is disconnecting the negative correct?
  16. Dec 14, 2012 at 12:22 PM
    Pugga
    Massachusetts
    Correct. Disconnect for 20 minutes and it'll reset.
  17. Dec 14, 2012 at 12:35 PM
    mjp2
    NJ
    It's not far from the truth. :eek:
  18. Dec 14, 2012 at 12:39 PM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    It MAY have something to do with an alarm or anti theft. I remember reading a post where somebody had a HUGE problem after disconecting his battery. A lot of dash lights were on and the AC blow but not cool.
    Anyway, thats what came to mind..... good luck Sir.
    BTW SkyKing, good to see another local on here. Im right down the road from ya in Hernando
  19. Dec 14, 2012 at 12:43 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I disconnect the battery every time i weld on a truck and i wouldn't weld on one without disconnect the battery I'm sure your good.
  20. Dec 14, 2012 at 12:50 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Never disconnect the battery!!!!! ...when it's running.
