Dometic PLB40 and Solar
Discussion in 'Technical Chat' started by campvibes, Jun 24, 2019.
  1. Jun 24, 2019 at 11:48 AM
    campvibes
    campvibes [OP] Well-Known Member
    Tim
    CA
    I have been running the Dometic PLB40 for a couple months now and I really love it. It takes care of my power needs no problem. However I would like to run a solar panel to keep it charged while stationary for longer periods of time. Are any of you running a solar panel with the PLB40?
    Also its needs to have anderson connectors and none of the solar panels that I have seen have the anderson connector. Is there something I am missing or if there some type of adapter?
    Thanks
    PNWTacoma likes this.
  2. Jul 3, 2019 at 7:36 AM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    I'm looking into this as well. My assumptions are that any solar panel will charge this, as long as there's a charge controller in between. I'm curious on what size anderson connector is on as I'm sure the cables from the solar controller can be outfittted with the corresponding connector.
  3. Jul 3, 2019 at 11:35 AM
    campvibes
    Tim
    CA
    My understanding that there is a built in controller in the plb40? Should just be able to plug in one with no issues.
    PNWTacoma[QUOTED] likes this.
  4. Dec 29, 2019 at 6:22 AM
    Shellshock
    Iowa
    Not running one currently but I’ve been considering it. There’s a charge controller built in (AC / DC / Solar) so you just need a panel to input power.
    There are a few out there with Anderson connectors or you can get an adapter or chop off what’s there and add an Anderson plug.
    Here’s one you can get with an Anderson plug, should be more than sufficient
    https://overlandsolar.com/products/bugout-120-solar-charger
  5. Feb 2, 2020 at 8:08 AM
    brywebb11
    brywebb11 Active Member
    Bryson
    White Tacoma TRD Offroad Access Cab
    msegal55 likes this.
