Dome lights won't turn off!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jadoiron, Nov 22, 2015.
  1. Nov 22, 2015 at 6:13 AM
    jadoiron
    jadoiron [OP] Well-Known Member
    2016 Tacoma 2x4 Access Cab Barcelona Red Metallic
    Here's a weird one:
    So yesterday I went to replace my dome light bulb with an LED... ended up putting it in backwards (stupid mistake) and blew the 7.5A fuse. So I put in a new fuse, and great, no problems. Now, the dome lights won't turn off automatically with the doors being shut or when I start the engine. I put the original bulb back in and same thing. Any ideas!?
    16 trd or likes this.
  2. Nov 22, 2015 at 6:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    does the fixture have an 'on' feature? As in off, on, door?
  3. Nov 22, 2015 at 6:21 AM
    jadoiron
    The main dome light has ON and DOOR. The second dome lights by the rearview mirror have ON, DOOR and OFF. This OFF switch also controls the main dome light. It's OFF right now because whether it's on DOOR or ON, all the lights stay on.
  4. Nov 22, 2015 at 6:25 AM
    jadoiron
    The lights remain on in every condition (door open, door closed, engine on, engine off). They'll only turn off if I set the switch to OFF.
  5. Nov 22, 2015 at 6:30 AM
    jadoiron
    Yeah the first thing I did was put in another 7.5A fuse. Checked all the door switches etc. They only go out after 20 mins.
  6. Nov 22, 2015 at 6:30 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    The lights are probably programmed to stay on for a few seconds when the switch is set to door. They should turn off automatically after 30 or if you have the key fob hit the lock button twice and they'll shut off. At least that's how my Runner works.
    ToyoTaco25 and Dryfly24 like this.
  7. Nov 22, 2015 at 6:32 AM
    jadoiron
    That's how they worked up until now. Now they all stay on no matter what. ONLY when I physically turn the switch off do they turn off. Even when I'm in gear, or if I lock with the fob, they remain on.
  8. Nov 22, 2015 at 6:41 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Should've bought a Colorado/canyon
    Alfred and nickj604 like this.
  9. Nov 22, 2015 at 6:52 AM
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    Try this, start Taco, turn on headlights, doors closed, overhead interior light switch in middle position. Turn off Taco, leave lights on, exit Taco, close driver door and wait. Headlights and interior lights should go off after about 60 seconds. I thought things were wonky on mine until someone told me to try this. If your interior lights are still on after a minute and the overhead switch is set to middle position, then there must be a separate module for interior lights. The fuse does NOT make a difference on continuity, only by amperage of the load, a higher amp rating means danger to the circuit if overloaded.
    If I use the FOB to lock doors everything turns off immediately.
    Also check your dimmer control to see if sonething is wonky there.
    Hope it is something simple
    chemjab and Bachosalazar like this.
  10. Nov 22, 2015 at 8:38 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  11. Nov 22, 2015 at 8:39 AM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    I would disconnect the battery for 15 minutes and see if something resets.
    ToyoTaco25, MOC221_ and CusterFan like this.
  12. Nov 22, 2015 at 8:43 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I would not suggest that to no one. Been there done that.
  13. Nov 22, 2015 at 8:49 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Better yet, don't mess with perfection.
  14. Nov 23, 2015 at 6:22 AM
    lilldill
    lilldill Well-Known Member
    Dylan
    Myrtle Beach
    2016 White TRD Sport
    I have the EXACT same problem with my LED lights. blew the fuse and now the EXACT same thing happens
  15. Nov 23, 2015 at 6:25 AM
    SamChieftan
    Dallas, Texas
    Holey Flippin Bananas Batman ... I better the Hell be careful when I change the rest of mine
    :eek:
    Dryfly24 likes this.
  16. Nov 23, 2015 at 6:27 AM
    lilldill
    Dylan
    Myrtle Beach
    If the switch is off, the lights are off.
    If the switch is on the doors open, all lights are on.
    If the switch is on, all lights are on. So every time I get in my truck it is dark. please help
  17. Nov 23, 2015 at 6:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    Your first 3 'conditions' sound exactly right to me.
    So you left out a 'condition' or two to jump to the last sentence?
  18. Nov 23, 2015 at 6:39 AM
    ekron
    ekron Well-Known Member
    Emily
    Long Island, New York
    2014 Tacoma 4x4
    Toytec/Boss Coilovers, Icon 2.0 with AAL in the rear. General Grabber A/T 2 ARB front bumper
    I'd try disconnecting the battery for a bit like frito suggested. Usually that resets the computer after about 15-30 min. Just take the negative off first..
    KY_Rob and scottalot like this.
  19. Nov 23, 2015 at 6:58 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I had something similar happen once; lasted a day.
    When the lights stay on, are they at half dim? Flickering?
  20. Nov 23, 2015 at 7:06 AM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    Short to ground , maybe you melted a ground wire so as long as there is a ground your lights stay on when you have power running through the circuit
    remember
    It takes 1 amp to push 1volt throught 1 ohm of resistance
