Dome light
Discussion in '1st Gen. Tacomas (1995-2004)' started by SquadPics, Sep 20, 2017.
  1. Sep 20, 2017 at 10:41 AM
    SquadPics
    SquadPics [OP] Active Member
    Casey
    Tampa Florida
    2002 Silver Tacoma TRD off road
  2. Sep 20, 2017 at 10:44 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
  3. Sep 20, 2017 at 10:49 AM
    SquadPics
    Casey
    Tampa Florida
    Jeeez I guess I gotta push harder lol
  4. Sep 20, 2017 at 10:50 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Gentle now! Use finesse
    Jerry311SD likes this.
  5. Sep 20, 2017 at 10:54 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Thats what she said
  6. Sep 20, 2017 at 3:17 PM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    I put my but it flashes any ideas ??
  7. Sep 20, 2017 at 4:49 PM
    SquadPics
    Casey
    Tampa Florida
    Same lol it flashes when the truck is off but if it's on it's fine?
  8. Sep 20, 2017 at 6:47 PM
    taco03Trd
    Carlos
    Riverside ca
    Havent try with the truck on ill try that one tomorrow .
  9. Sep 20, 2017 at 7:04 PM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    I slmost snapped mine in half putting it in. I ended up bending the clip so it goes in easier
  10. Sep 20, 2017 at 8:49 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Same here. Easiest if you unscrew the light, then you can easily bend the contact points with a pair of small needlenose pliers. Just did it a couple of days ago while I was putting Frost King on my roof panels.
    SquadPics[OP] likes this.
  11. Sep 20, 2017 at 11:37 PM
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    Google led dome light resistor, very common and easy fix for the flashing/flickering. Sorry I don't have any pics or remember the exact resistor that I used.
  12. Sep 21, 2017 at 5:51 AM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Here is what I used. https://www.amazon.com/gp/product/B00PZYO11K/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 You only need to solder one across the contacts of the dome light bulb. It serves to take care of the map light ones, without adding one to them.
  13. Sep 21, 2017 at 8:58 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    While it still might work, the resistor is either not enough rated power or it needs to be higher resistance. At 12V the 100 ohm resistor will use 1.44W while it is rated only for 1W.
  14. Sep 21, 2017 at 10:49 AM
    SquadPics
    Casey
    Tampa Florida
    So would that resistor work or do I need a different one?
  15. Sep 21, 2017 at 3:09 PM
    RysiuM
    Rysiu
    If it was tested it will probably work, but my not last the lifetime. I don't know if you can get away with bigger resistance (less power wasted), I guess this is the Master Body ECU dimming circuit that doesn't like LED. I don't have any dimming in my very first gen truck so I did not need any stinking resistors.:)
    On the other hand I have this dimming feature in 5th gen 4Runner and LEDs are not flashing. So maybe different kind of bulb will work better. I'm quite sure this bulb https://www.amazon.com/YOOSEN-White...031253&sr=8-72&keywords=festoon+3175+LED+bulb would not flicker as it has simple diode/resistor setup not a Buck type driver. Or even better chipset bulb (same setup) https://www.amazon.com/Huizen-CanBu...31612&sr=8-270&keywords=festoon+3175+LED+bulb
    The Driver likes this.
  16. Sep 21, 2017 at 5:17 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Just one is working for me, but when I was researching the issue, I did see where someone had used two on one LED. By the way, I did try one of the CanBus Error Free bulbs, and they did not work in my situation, until I added the resistor. YMMV
  17. Sep 21, 2017 at 6:32 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    I set my dome to OFF bc i didn't shut my door all the way and it killed my battery over the weekend...i hope you enjoy your new light and won't be a dumbass like me.
    It was really the seatbelt catching in the door but there's a thread for that elsewhere..I'm just lazy.
  18. Sep 30, 2017 at 9:26 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Lucky Son of a gun... I ordered them, installed them, and they didn't work. Tested both, bright as heck, so they do work. Installed them again, no dice! :/
  19. Sep 30, 2017 at 9:29 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I put an LED in the dome light on my 2nd gen and ended up giving it away. It was too harsh. I enjoy the mellow old school vibe of a filament bulb for that application - everything else on my truck will be led though.
  20. Sep 30, 2017 at 9:41 PM
    The Driver
    Raph
    ^ Nah, I wantz BRIGHTNEZZ! :help:
