Dome Light Fuse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrdbrn, Oct 13, 2016.
  1. Oct 13, 2016 at 6:27 PM
    jrdbrn
    jrdbrn [OP] Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    Is the dome fuse under the dash the fuse for the dome light in the center of the roof?
    I changed all my bulbs to LED and now the center dome doesn't work with the new bulb or old. I checked the 7.5a dome fuse under the dash and it's good.
  2. Oct 13, 2016 at 6:47 PM
    InSight Retrofits
    InSight Retrofits Closed
    Sometimes when something is out I just check every fuse in the panel. I have done it for customers before when they complained one thing didn't work, one time I found 4 bad fuses.
    Initially I was going to say flip the LED bulb around because they usually only work one way, but you said the old bulb doesn't work either. You're sure the switch is on and you didn't bend the contacts out of place?
    kgb4187 and jrdbrn[OP] like this.
  3. Oct 13, 2016 at 7:31 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    I flipped both bulbs around
    The switch is on
    The only thing I didn't do was bend the contact in...
  4. Oct 13, 2016 at 9:09 PM
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    Its the 7.5 i think 3 up from the bottom on the right side. I blew mine when i put in leds. If you cant get it working change the fuse.
  5. Oct 13, 2016 at 9:38 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Fuse is in the under dash panel. It's labeled in the cover. Most LED bulbs are polarity sensitive. Meaning they only work one way. If you have it the wrong way it will blow the fuse.
  6. Oct 14, 2016 at 6:37 AM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    I bent the contact back in... reinserted bulb.... GOOD TO GO
  7. Aug 10, 2017 at 4:08 PM
    ECH
    ECH Member
    2017 Tacoma TRD
    None
    I'll add the embarrassing caveat-- before replacing bulbs that you don't think work, make sure that the master switch (OFF-DOOR-ON) above the rear view mirror isn't OFF...
  8. Aug 10, 2017 at 7:07 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    There's been several dudes on here that have fried the circuit board inside thier overhead console by installing LED bulbs. Try to search out those threads
  9. Sep 4, 2022 at 4:55 PM
    Cdnguy
    Cdnguy Member
    Five years later, this comment is worth its weight in gold!
    davidstacoma likes this.
  10. May 24, 2024 at 8:58 PM
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    :anonymous: Make that 7 years later :facepalm:
