Does wheel balancing machine have to be bolted down
Discussion in 'Wheels & Tires' started by Swamp Donkey, May 15, 2017.
  1. May 15, 2017 at 2:23 PM
    Swamp Donkey
    Swamp Donkey [OP] Well-Known Member
    Fort St John B.C
    2011 4cyl SR5 auto 4x4
    Hey. Anyone work at a tire shop? Is your wheel balancing machine bolted down solid to the floor? I see on mine, there are three separate contact points that makes me think some movement is good. I bought a wheel balancing machine used and am trying to learn how to use it without a manual. I can't find a manual for it on the internet either.
    I did read some other brands user manual and it said nothing about it being bolted down solid.
    scottalot and Phoosa like this.
  2. May 15, 2017 at 2:26 PM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    The one at our shop is not and no issues with it. I assume for larger heavier wheel tire combos you would want it bolted down
  3. May 15, 2017 at 2:37 PM
    Swamp Donkey
    Fort St John B.C
    Thanks. I kinda figured it did not have to be bolted down. The guy who I bought it from only had it sitting a couple of 2x6's and I skidded it right out of his shop that way.
    My nephew has worked at a tire shop for years and is coming over to give his poor senile old uncle some training on the machine! LOL
    Maybe calibrate it up and al that jazz
    scottalot likes this.
  4. May 15, 2017 at 2:39 PM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    calibrated:yes. Ours gets done every year or two I believe
  5. May 15, 2017 at 2:46 PM
    musher
    musher Well-Known Member
    Alabama(born) >(the world)>Alaska(now)
    2017 Tacoma
    I'd rather not think of all the $ spent :(
    Ours isn't bolted down but it does sit flat on the concrete floor and does not move. x2 on calibration
    On this note, anyone tried the airsoft tire balance method?
  6. May 15, 2017 at 2:55 PM
    Swamp Donkey
    Fort St John B.C
    I put in the ceramic balancing beads and have run them for a lot of years with good success. But these duratrac tires needed like 8.5 oz on one side and 4 oz on the other side after removing the balancing beads. So needless to say the balancing beads did not work. And now my struggle learn how to use a machine by YouTube! Lol
    Well, actually I gave up on YouTube and will wait till tomorrow when my nephew can teach me
  7. May 15, 2017 at 2:58 PM
    Swamp Donkey
    Fort St John B.C
    The ceramic balancing beads that I have had good success with have been used on my dodge with 35" tires. I think the bigger the tire, the more success you will have with beads or airsoft pellets
  8. May 15, 2017 at 5:34 PM
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD on 37s
    Rear full long travel including upper and lower rear control arms. 37s Mickey Thompson Baja boss MT,
    No it dose not have to be
