Does the 2gr-fks have engine counter balance shafts?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, May 17, 2024.
  1. May 17, 2024 at 3:52 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Does anyone know if the v6 in our tacomas have engine counter balance shafts?
  2. May 17, 2024 at 4:32 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Not that I am aware of.
    Usually I4 have them, like 2az-fe
    Gfenza89[QUOTED][OP] likes this.
  3. May 17, 2024 at 4:33 PM
    Gfenza89
    Intersting still chasing down the roughness in my truck .
    Junkhead likes this.
  4. May 17, 2024 at 4:36 PM
    Vlady
    Issy, WA
    Have you inspected engine and tranny mounts?
  5. May 17, 2024 at 4:37 PM
    Bishop84
    Bishop84 Well-Known Member
    Honestly you need to work on accepting it or trading the truck in for another vehicle. I'm not trying to be toxic but you complain a lot about this truck and don't seem to be very happy about it.
    auskip07, RicerRabbit, Chew and 5 others like this.
  6. May 17, 2024 at 4:39 PM
    Gfenza89
    Best I can, can’t visually see much. You can see the engine shaking and transmitting that into the cab. Along with engine vibrations coming through the gas pedal and floor board when accelerating. The vibration app I downloaded detected the vibrations and if the engine doesn’t have counter balance shaft it’s saying to inspect the engine mounts
  7. May 17, 2024 at 4:40 PM
    Gfenza89
    I’ve owned 5…. I can tell the difference between this one and my last 4. So yeah I have a valid complaint. Does the engine have counter balance shaft ? You would know considering you’re a tech ?
  8. May 17, 2024 at 4:42 PM
    Bishop84
    No, it doesn't use one, only 4 cylinders have counter shafts.
  9. May 17, 2024 at 4:50 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Lighten up Francis.... Sell it if you don't like it. It's not that hard geez....
    BabyBilly likes this.
  10. May 17, 2024 at 4:58 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Toyota puts weights on the driveshaft to balance the engine. Is there a chance you out your driveshaft on backwards?
  11. May 17, 2024 at 4:59 PM
    Gfenza89
    Why would I do that when I can try and fix it?
  12. May 17, 2024 at 4:59 PM
    Gfenza89
    Thanks
  13. May 17, 2024 at 4:59 PM
    Gfenza89
    Trucks new
  14. May 17, 2024 at 5:03 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Maybe it's time for another truck...6th time's a charm?
  15. May 17, 2024 at 5:05 PM
    Vlady
    Issy, WA
    I know you have been chasing the issue for a while. I would try to eliminate mounts 1st. Could be a bad fan? Unlikely, but it is a possibility.
    If you lightly support a corner of the engine at the time with a jack, you should see a trend in the vibration.
  16. May 17, 2024 at 5:08 PM
    Gfenza89
    Who knows yeah not a bad idea. My buddies tacoma is so smooth not mine that’s how I know it’s not normal not to mention past ownership
  17. May 17, 2024 at 5:08 PM
    Gfenza89
    Not really. If you were feeling what I’m feeling you’d be chasing it down too
  18. May 17, 2024 at 5:19 PM
    BabyBilly
    Billy
    2020 TRD
    I have to ask. Why did you trade in the other 4 trucks?
  19. May 17, 2024 at 5:22 PM
    Gfenza89
    Well my 2022 had a bad cylinder head and 3 separate oil leaks. The other ones I got a killer trade in deal
  20. May 17, 2024 at 5:35 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    If you had one that was leak free and trouble free that was the one to keep
