Does leaving the key fob in the truck drain the battery?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AleutianTaco, Mar 21, 2022.
  1. Mar 21, 2022 at 7:58 PM
    AleutianTaco
    AleutianTaco [OP] Active Member
    Searched a bunch and could only find conflicting information. 2022 TRD, push button start. Do not have smart key.
    If I left a key in the truck permanently (theft not a concern), will the truck "sense" the key and keep it out of sleep mode or cause a pre-mature drain or draw on the battery?
    Is there any difference if it is the fob or the actual key? The actual key itself would have a chip in it anyway so I would assume no difference between the two.
    Can't find anything in the manual. I did ask the dealer and the service tech said he was not sure.
  2. Mar 21, 2022 at 8:00 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    If it’s not a smart key, I’m inclined to believe it wouldn’t have an affect.
    TnShooter likes this.
  3. Mar 21, 2022 at 8:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I would tend to agree.
    And if it is Smart Key, you can turn the Smart Key OFF.
    It will reactivate once you press any button.
    musicisevil likes this.
  4. Mar 21, 2022 at 8:11 PM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    Yea it does. Unless you deactivate it.
  5. Mar 21, 2022 at 8:18 PM
    AleutianTaco
    This is my key fob. I dont think its a smart key because I said no when the dealer wanted $400 extra. But if its in my pocket and I open the door handle from the outside, the truck will unlock.
    If it is a smart key, how do you turn off?
  6. Mar 21, 2022 at 8:22 PM
    overlimit
    overlimit Well-Known Member
    BC C, Eh! N, Eh! D, Eh!
    '21 DCSB TRD OR Premium.
    To shut it off, press and hold the lock button while you press the unlock button twice. A press of either button will turn it back on.
  7. Mar 21, 2022 at 8:28 PM
    TnShooter
    Deogee
    STOCK
    This ^^^
    And Yes, you have smart key if the door unlocks on its own when your hand is near the door handle.
    musicisevil and Skydvrr like this.
  8. Mar 21, 2022 at 8:30 PM
    AleutianTaco
    Trying to leave the key in the truck and forget it. Just push button and go.
    Turned smart key off.
    Brought out this real key. Apparently it will not start the truck, just unlock it.
    So no way to leave keys inside, truck unlocked, with the ability to start it without draining the battery over time. Unless you disable smart key everytime you get out.
    Does anyone know about how long it would take with the keys left inside to drain the battery to the point it would have trouble starting?
  9. Mar 21, 2022 at 8:39 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I’m not even so sure it would drain the battery. But the possibility seems high. Maybe @Jeff Lange can shed some light. Seems pretty keen on these things. Maybe even @caribe makaira has some insight.
    bigmw likes this.
  10. Mar 21, 2022 at 8:42 PM
    TnShooter
    Deogee
    STOCK
    I don’t know what will happen.
    But apparently you can switch smart key Off in the settings option of the truck.D166525C-09C2-4E6C-A617-00C2F73B0894.jpg
  11. Mar 21, 2022 at 8:44 PM
    TnShooter
    Deogee
    STOCK
    Never mind my above post.
    Evidently the DEALER can turn it off.
  12. Mar 21, 2022 at 8:45 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Long time. Weeks, probably. The system is running whether the key fob is in proximity or not. And there are other on board systems that have a bigger draw than that, so the fob sensors aren't even a major percent of the battery draw.
  13. Mar 21, 2022 at 8:47 PM
    TnShooter
    Deogee
    STOCK
    All I can tell you is that you can leave the smart key in a Lexus RX350 for about 48 hours.
    The car still started.
    Does that help you? No, but you “should” have about 48 hours or so anyways :rofl:
  14. Mar 21, 2022 at 8:55 PM
    AleutianTaco
    From what I've read, the other higher draw systems will go to "sleep" after a certain period of time, however with the smart key left in the vehicle it will prevent those systems from going to sleep. Just what I've gathered from Google
    Skydvrr likes this.
  15. Mar 21, 2022 at 8:58 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    You might be right. I could very well be wrong. :anonymous:
    I've never tested it out to it's full extent, but I have left it over a three day weekend while camping, no problems.
  16. Mar 21, 2022 at 9:11 PM
    TnShooter
    Deogee
    STOCK
    I believe Toyota says you have to place the key X amount of feet away from the vehicle, and wait X amount of time, to preform a Parasitic Draw Test on the battery. But that’s not exactly what we’re after here. However, it might be a clue?
    I bet one of the Techs on this forum knows. We’ll see what they say?
    Rock Lobster[QUOTED] likes this.
  17. Mar 21, 2022 at 9:24 PM
    chrlsone
    chrlsone Well-Known Member
    Charles
    2022 TRD OFFROAD 4x4
    I had a 2018 Tacoma before trading it in on a 22. I left the key in the console for 4 years and only changed the battery in it 1 time in the 4 years.
  18. Mar 22, 2022 at 8:25 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I leave mine in the truck all of the time. The only time I take it out is when I am leaving the truck in a parking lot at the mall. I can still start the truck from the house with the other FOB when the other one is still inside.just saying.
  19. Mar 22, 2022 at 8:29 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    It makes no difference. I have left my key in my truck for more than four years if that is of any comfort to you.
