Does fuse size matter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sterling13, Apr 7, 2022.
  1. Apr 7, 2022 at 10:46 PM
    Sterling13
    Sterling13 [OP] Active Member
    2013 spruce mica Tacoma TRD
    My 7.5amp fuse blew in my Tacoma. I bought a replacement but the “prongs” are longer, does that matter? I apologize I’m uneducated when it comes to fuses or anything electrical. Will post pictures
  2. Apr 7, 2022 at 10:47 PM
    Sterling13
    This is what my old fuse looked like
  3. Apr 7, 2022 at 10:47 PM
    Sterling13
    And this is what the new one I’m replacing it with looks like
  4. Apr 7, 2022 at 10:55 PM
    SamS
    SamS Well-Known Member
    Vancouver Island, BC, Canada
    06 Access cab 4x4
    Most important is the numbers must match. The length of the contacts only matters if the electrical connection will jiggle free. Or if the exposed part of the connection had a lot of bare metal there is an increased chance something loose could short it, like if you had a pair of pliers pulling out another fuse and they touched it.
    Key-Rei and Sterling13[OP] like this.
  5. Apr 7, 2022 at 10:58 PM
    Sterling13
    Thank you! I felt silly asking but really wanted to be sure.
  6. Apr 7, 2022 at 11:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You're fine
    Sterling13[OP] likes this.
  7. Apr 7, 2022 at 11:20 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    the longer tab fuses will fit. its just an older style.. they should work fine in the engine bay box. but they wont fit the cabin box if you want to put the cover on.
    Dm93 and Sterling13[OP] like this.
  8. Apr 8, 2022 at 5:01 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes the mini fuses will fit in place of the low profile mini's in most cases.
    The main thing is to use the correct amperage fuse and not more, if a fuse is blowing without reason you have a problem and putting in a higher amperage fuse will only create bigger problems.
  9. Apr 8, 2022 at 8:08 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yes, no prob using the longer one. Taco OEM fuse is called a low profile mini ATM; the one with longer blades is a mini ATM. I’ve seen some vendors refer to the low profile as a micro fuse. Toyota calls them Type A fuses. For the voltage boost fuse, I am using the mini ATM version because it is cheaper than the low profile version.
  10. Apr 8, 2022 at 8:36 PM
    HuskerTrucker
    HuskerTrucker Well-Known Member
    Tom
    O,NE
    2013 DCSB
    Turned it into a 2023 SR5P 4Runner
    My wife has assured me from the beginning it does not
  11. Apr 8, 2022 at 10:14 PM
    Sterling13
    Thank you! I learned something new I appreciate the information
