Does anyone know where to find a OEM QI Wireless Button?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GamerGuy, Jan 3, 2018.
  1. Jan 3, 2018 at 5:44 PM
    GamerGuy
    GamerGuy [OP] Well-Known Member
    Casey
    Alabama
    2025 4WD TRD Sport - Terra
    I want to install a QI wireless bad in my 2014 2nd Gen and i wanted it to have the OEM QI button in a blank by my AUX/USB port if it fits. I cant even find one for sale or any measurements though. Anyone know where i can find one or a similar solution?
    I posted this in 3rd gen because i figured some of you guys may have had to replace this before or something.
  2. Jan 3, 2018 at 6:08 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Did you try asking the dealer if they can get you one?
  3. Jan 3, 2018 at 6:11 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Check with @mesojdm I saw a pic he posted and it seemed like the switches he had were way to specific not to be custom.
  4. Jan 3, 2018 at 7:17 PM
    GamerGuy
    Casey
    Alabama
    I went through a lot of @mesojdm's pictures. ill wait and see if he responds to this post tomorrow. Thanks!
    Edit: Does anyone have a measurement of this buttons size?
  5. Jan 3, 2018 at 9:19 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Hi Casey, I’ve got one I removed somewhere in my garage, I’ll be back in town Saturday to look for it.
  6. Jan 3, 2018 at 10:47 PM
    GamerGuy
    Casey
    Alabama
    P'med
  7. Jan 6, 2018 at 9:24 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Mobile Wireless Charger
    861C0-04010
    Switch
    861C6-06011
  8. Jan 6, 2018 at 10:30 PM
    Captqc
    Tigard, OR
    05Taco4x4 likes this.
  9. Jan 6, 2018 at 10:54 PM
    05Taco4x4
    2TR-FE Enthusiast
    Can we see a pic of the pins please
  10. Jan 6, 2018 at 11:06 PM
    Captqc
    Tigard, OR
    Yup!
    BC351D48-F5ED-4633-AC59-E3E1F164C6BC.jpg 252CE5DD-CAC9-40D9-A8A4-47B2B73B58D8.jpg
    05Taco4x4[QUOTED] likes this.
  11. Jan 6, 2018 at 11:24 PM
    05Taco4x4
    2TR-FE Enthusiast
    Thanks, I'm going to try find the connector p/n
    Edit:
    Can't find it
  12. Jan 8, 2018 at 4:54 AM
    GamerGuy
    Casey
    Alabama
    Do you know the pinout ?
    & I see you have an 05. Do you know if this button fits in the cutout under our radio?
  13. Jan 8, 2018 at 5:30 AM
    GamerGuy
    Casey
    Alabama
    Update on Wiring for QI Switch
    https://www.tacomaworld.com/threads/repurpose-qi-charging-switch.496661/page-2
    Seems that this is the purpose for the wire colors but I do not know which pins are which colors and what exactly these descriptions mean.
    White - Ground
    Blue - Switched Power 12V ( Seems that this is only sending out power when button is pressed aka. N/O Switch.
    Grey - ACC 12V ( Im assuming this means this is where your 12v from the battery is coming in )
    Green - Dimmer ---- Any idea what this is referring to?
  14. Jan 8, 2018 at 7:08 AM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    Dimmer refers to the night illumination. Meaning link it to one of the other "Dimmer" lines and when your headlights are on the switch will light up. As opposed to a set-up, like many generic toggles from the parts store, where the switch lights when switched on. in the case of the Qi switch, the Qi lights with headlights while the little amber (I may not remember the color correctly) lights when switched on.
  15. Jan 9, 2018 at 4:56 AM
    GamerGuy
    Casey
    Alabama
    Thank you! i did some research on my head unit and found the coloring code ( Lies below ) I can lint this to the Orange wire off the radio
    Yellow - 12V Constant
    Red - 12V Accessory
    Black - Ground
    Orange - Dash Light Dimmer/Illumination
    Green - Left Rear Speaker (+)
    Green with Black Stripe Left Rear Speaker (-)
    White - Left Front Speaker (+)
    White with Black Stripe - Left Front Speaker (-)
    Purple - Right Rear Speaker (+)
    Purple with Black Stripe - Right Rear Speaker (-)
    Gray - Right Front Speaker (+)
    Gray with Black Stripe - Right Front Speaker (-)
    TC_Mic[QUOTED] likes this.
  16. Jan 9, 2018 at 9:00 AM
    05Taco4x4
    2TR-FE Enthusiast
    Which connector and pin number?
    I’m a visual learner :thumbsup:
  17. Jan 9, 2018 at 12:16 PM
    GamerGuy
    Casey
    Alabama
    I haven't started my project yet so I have no pictures but here's a connector I found these wire colors on and here's a forum on replacing my head unit it looks like you have an 05 though.
    If this looks wrong let me know. im trying to gather as much info as possible before i crack into this.
    https://www.carid.com/metra/wiring-...61.html?singleid=4732994&url=78719627#reviews
    https://www.tacomaworld.com/threads/installing-2012-jbl-entune-nav-into-2012-o-r-non-jbl.285725/
  18. Jan 12, 2018 at 5:11 AM
    GamerGuy
    Casey
    Alabama
    I now have a button but I have some questions about it as I cannot find a harness for it.
    If you are looking at the button and it is faced like it would be mounted in your dash, Coming from the top to bottom what is the color code for the pins? Im going to solder on some wires to the pins and heat shrink instead of using a harness.
    is it Like this? What does the yellow wire do?
    Blue - 12v When button is pressed, Open Contact when depressed
    Yellow -
    Green - Dimmer, turns on when headlights are on
    Grey - 12v Feed
    White - Ground
  19. Jan 15, 2018 at 10:02 PM
    05Taco4x4
    2TR-FE Enthusiast
    Charger
    861C0-04010
    Switch
    861C6-06011
  20. Jan 16, 2018 at 3:14 AM
    GamerGuy
    Casey
    Alabama
    Would you say that this Picture I modified is correct? ( Remember, We are both visual learners )
    I believe I accurately assembled all of the information we have gathered.
