Does anyone have a programmer/chip on their first gen Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaSR5, Apr 23, 2015.
  1. Apr 23, 2015 at 9:27 PM
    2004TacomaSR5
    2004TacomaSR5 [OP] Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Does anyone have their Tacoma chipped? Is it worth it and is there a notable difference in power or MPG? Looking at maybe doing it to my 04 and need opinions whether or not it's legit or a scam. Would like to add a little more HP and maybe some more MPG without breaking the bank. I'd love to get a supercharger, but don't have 4k laying around atm. Thanks fellas!
    2001nwTacoma likes this.
  2. Apr 23, 2015 at 9:50 PM
    roehoe72
    roehoe72 Well-Known Member
    Dan
    Vacaville, CA
    04 dc prerunner v6 trd
    Ive read bad stuff. And good. I.say fuck it, supercharge that shit! I know i want to! Sorry this is of no help!!
    Tacolover92 and misterkay like this.
  3. Apr 23, 2015 at 9:54 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    They dont make chips for our trucks, sorry to burst your bubble.
    Intake, headers and exhaust make the truck louder and smoother throttle response but add maybe 5 HP.
    Supercharger and a 7th injector with ECU re tune is the only legit way to make power.
    You could also do a Turbo setup but they are illegal in most states while the Supercharger is 100 bolt on 50 state legal.
    If you want a fast truck buy a full-size with a V8.
    Tacolover92 likes this.
  4. Apr 23, 2015 at 11:07 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    This right here.;);)
  5. Apr 24, 2015 at 6:26 AM
    roehoe72
    Dan
    Vacaville, CA
    In all reality, i dont think ive EVER noticed a difference in 11 years with that button. I use it too, andi can't feel a difference.
  6. Apr 24, 2015 at 6:33 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    He was joking :D
    and that button is to hold the shift longer on auto's. use it when towing and your trans will keep from "hunting" gears
  7. Apr 24, 2015 at 7:51 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    The only way to change the program on a gen 1 is to pull your ECU and send it off to have the chip set reflashed. The downside is that you wont have a running truck until you get it back
  8. Apr 24, 2015 at 10:05 AM
    jensenjoe
    jensenjoe Active Member
    Joe
    Bay Area
    2000 XtraCab 4x4 SR5, red
    42" LED lightbar, CB, PA system, sirens, SKL Motorworks KL-PRO1 performance chip, Viper alarm w/keyless entry, Rancho Quicklift Loaded struts, 2.5" Hell Bent Steel front spacers, RuggedLift 2" rear block spacers, Revtek 1" Diff-drop, 4' Firestik w/custom fabbed bed mount, round LED flood/fog lights, Apex 8000k Xenon HID's
    SKL Motorworks makes chips for our trucks actually. I have one. It definitely isn't going to give you much of any significant gains, but I will say what I do notice is smoother accelerating in high rpm's. I realize this is a super controversial topic and am in no way saying they are going to give you 20 extra hp and 20% better mpg like many claim, I am however saying that with the one I have on my truck I do notice SOMETHING (smoother acceleration in high rpm's).
    RA77 likes this.
  9. Apr 24, 2015 at 11:35 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    If it plugs into the diagnostic or OBDII port on a Taco and isn't labeled Toyota TechStream it does nothing. Even if this device did have the intention of changing something, it couldn't as there are no values for it to change on a 1st gen Tacoma. I looked up that SKL brand, they sell snake oil adapters that plug into OBDII ports to fool the uninformed into believing that their vehicle's performance has changed. There are even some (from SKL) that claim to modify the signal from the MAF by having you tap into the wiring loom, but these only tap in with one wire and have no return wire to that specific loom. They are using the placebo effect to fool your butt dyno. They make one for everything, and they are all the same part. Please understand that I'm not making fun of you, I'm just pointing out that it is not possible for this "chip" to do
    anything from the OBDII port or by "injecting" a different PWM signal to the MAF wire. Think about it, vehicles are complex and differ majorly, how could one part work for every vehicle?
    Like mentioned above, the only thing for these trucks is an full EEPROM reprogram which is still rather pointless as it doesn't garner much in the world of gains, it is more to fix a broken ECU. The OBDII port is only for monitoring and diagnostics, there is nothing that can be edited through them unless you have a factory tool (even those don't edit the performance data, they just change things like door lock setting and beep codes).
    For the later Tacos (2nd gens) they can be flashed from a Toyota TechStream for different (adjusted fuel map for supercharger) performance data.
    Tacolover92, RA77 and Hamer95USA like this.
  10. Apr 24, 2015 at 11:44 AM
    offrdmania
    Templeton, Ca
    Toyota would have to release their algorithm codes in order to access the ECU through the OBD2 port. To this day, Toyota refuses to release them. On newer Toyota trucks, essentially 05 and newer, companies have been able to alter the signal downstream of the ECU in order to make performance gains.
  11. Apr 24, 2015 at 11:47 AM
    Speedytech7
    Very true. I'm not sure how much of a difference can be made downstream because the computer can only correct fuel maps and such by +or- 15% but yeah the theory is solid. Would certainly make correcting a real issue harder for the comp if it is already at its correction limit.
  12. Apr 24, 2015 at 8:18 PM
    offrdmania
    Templeton, Ca
    For example, Hypertech offers their Interceptor. Downstream they claim about 15hp on 87 octane and 17hp on premium. This is on the 07-newer Tundra so it is possible. Nothing great but possible. Nothing available for the Tacoma unfortunately other than speedo recalibration.
    http://www.hypertech-inc.com/products-Interceptor.aspx
  13. Apr 24, 2015 at 9:49 PM
    roehoe72
    Dan
    Vacaville, CA
    Not to thread jack, but for what it's worth i installed a Crawford eco block about 2 weeks ago. Haven't noticed much as far as power or MPG, but i have noticed when i go to pass on the freeway it doesn't hesitate as much when I step on the skinny pedal. It seems to be a wee bit torque-y-er to from a dead stop. Plus its only $50! Theres a huge thread on this site, look it up.
    RA77 likes this.
  14. Apr 24, 2015 at 10:00 PM
    jensenjoe
    Joe
    Bay Area
    YUP! Well put. Thats basically exactly what I was trying to say!
  15. Apr 24, 2015 at 10:07 PM
    roehoe72
    Dan
    Vacaville, CA
    Beauty about the ecoblock is it really seems to be backing its claims.lot of guys called it snake oil, then flipped there opinion when they saw actual results. You can even return the damn thing if you want. The company Crawford, i.e. Ken blocks Subaru builders has awesome customer service too. There planning to do dyno tests too.
    RA77 and 2001nwTacoma like this.
  16. Aug 1, 2018 at 3:53 AM
    tacom02
    tacom02 guy with a truck
    Vance
    Colorado
    08 TRD Off-Road 4x4 4.0L manual
    3" Super lift 285/75R17 Toyo Open Country 17x9 Rims some lights in the bumper
    I understand this is old but you said change the lock settings, does that mean that I can add keyless entry to the truck fairly easy? I already have power locks on my 02, just not keyless
  17. Dec 18, 2019 at 3:56 PM
    Tacorojo04
    Tacorojo04 Member
    Frank
    First Tacoma
    None yet
    I’m looking for more info on the eco block for my 2004 Tacoma. Part number maybe
  18. Dec 18, 2019 at 6:50 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    A little nitrous oxide never hurt anyone either....
    :rofl::rofl::rofl::rofl::rofl:
    RA77 likes this.
  19. Dec 18, 2019 at 7:01 PM
    Tacorojo04
    Tacorojo04 Member
    Frank
    First Tacoma
    None yet
    Right! It’s going to be a daily driver just doing small mods nothing crazy.. but I found the answer already. Q1 is the eco block 1st gen can use.
  20. Dec 18, 2019 at 7:21 PM
    Rachelsdaddy
    Southern NH
    I imagine folks whose floorboards are rotted out can push the pedal further :anonymous: ehhhhhhhhh
    RA77 and JShawFSU like this.
