Does a tonneau cover help with gas mileage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dieseldan9, Dec 25, 2021.
  1. Dec 25, 2021 at 6:27 PM
    Dieseldan9
    Dieseldan9 [OP] Well-Known Member
    Always thought it did?
  2. Dec 25, 2021 at 6:30 PM
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
    How? I doubt it does.
  3. Dec 25, 2021 at 6:31 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Nah not enough to make a huge difference. Most of the air is going over the bed due to airflow from your hood and windshield. The only time you'll see air hitting your bed is when you are going downhill.
    When they test these trucks to get real world MPG it's without bed covers
    Kyebasse likes this.
  4. Dec 25, 2021 at 6:47 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It depends on how many places you go to the right of the decimal point when calculating fuel mileage.
    Nothing new here. When gas prices doubled in the 1970's going from $.45/gallon to over $1/gallon almost overnight everybody was looking for ways to get better fuel mileage. This was when trucks got single digit fuel mileage. My 1975 Jeep truck got 6 mpg city/11 mpg hwy. Yea, $1/gallon sounds cheap, but with that fuel mileage and people today making more today/month than most made in a year gas was much more expensive than today at $3/gallon.
    Every truck and 4X4 magazine in the day conducted tests on every imaginable modification to trucks including caps, tonneau covers, tailgates up, down, and off. The results were mixed. In some cases fuel mileage did improve, in some it got worse, and in others it made no difference. But it was never more than a small fraction of 1 mpg.
    Since then the tests have been replicated multiple times including at least 3 times on Mythbusters. The 2nd best way to get better fuel mileage is to drive conservatively and keep the truck well maintained. The best way is to drive something that gets 35 mpg+ until you need the truck.
  5. Dec 25, 2021 at 6:49 PM
    Pinion
    Pinion Well-Known Member
    Drew
    Brookings Oregon
    2020 DCSB limited 4x4
    Yes, you have less money to put in the tank
    tuktoyaktuktoyota and Jimmy92870 like this.
  6. Dec 25, 2021 at 6:54 PM
    Trail Limo
    Trail Limo Well-Known Member
    Nothing significant. If you want better gas mileage, about the only thing that will have a significant value would be a cover that started at the top of the cab, and sloped down to the tailgate.
    Would look uglier than sin, but would help the air keep laminer flow across the bed. Vortex generators would help as well, to keep the air attached in laminer flow.
    Now, just need to find a mfg to make it... Wait...
  7. Dec 25, 2021 at 6:55 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    put a big wing on the tailgate it helps with down force and makes the truck go faster
    I dont think it would matter tbh, if youre having mpg issues its a truck it is what it is
  8. Dec 25, 2021 at 6:56 PM
    Trail Limo
    Turbulent air is terrible for fuel economy. The only way to make it better it to get the air to follow the body, in a laminer fashion. Any right angle (think back of cab) is going to cause massive turbulence, and cause terrible gas mileage.
  9. Dec 25, 2021 at 6:57 PM
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    No.
    TRD2021SPORT likes this.
  10. Dec 25, 2021 at 7:16 PM
    HUTCHRED
    HUTCHRED I can ride my bike with no handlebars.
    2022 Black Tacoma Limited
    Trying to be chrome free
    Negligible.
  11. Dec 25, 2021 at 7:32 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Ran it for a year and saw no deference.
    Shocked likes this.
  12. Dec 25, 2021 at 7:37 PM
    kpinthebay
    kpinthebay Well-Known Member
    Hawaii ==>>SF Bay Area
    I think Myth Busters or similar did an experiment on it. They found no difference. They chalked it up to aiflow up and over the cab and enough stagnant air pressure to keep most of the wind out of the bed. Something like that
    Racerx159, PhogDog and SSMTRDOR like this.
  13. Dec 25, 2021 at 7:40 PM
    SouthernFried
    SouthernFried Well-Known Member
    South Carolina
    2020 TRD OR DCSB
    I notice no difference. If it does, it’s so minimal it doesn’t even matter. Maybe you will save 25-50 cents per tank of gas.
  14. Dec 25, 2021 at 7:43 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    No it does not.
  15. Dec 26, 2021 at 4:48 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I ordered my cover right after I bought the truck. Took about 3 weeks to come in so I only had a couple of tanks to compare, but there was no real difference.
  16. Dec 26, 2021 at 4:56 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Wheres myth busters when you need them?
  17. Dec 26, 2021 at 5:18 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Probably, yes only at speeds faster than the truck is capable.
  18. Dec 26, 2021 at 5:24 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Might save you a few bucks in gas money over the life of the vehicle, but otherwise not really! But they do keep stuff in the bed (relatively) secure and dry which is their primary function.
    zoo truck likes this.
  19. Dec 26, 2021 at 5:35 AM
    MGB
    MGB Well-Known Member
    2017 manual TRD Sport
    A cap might help. The square back is good for mileage; station wagons can be better than the sedan equivalent, however, modern wagons with more rounded ends may not be as favorable. Alfa Romeo changed their 1960s SZ race car with a round tail to the TZ with a square tail after wind tunnel tests showed that resulted in better aerodynamics. This is not an intuitive result....
  20. Dec 26, 2021 at 5:38 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Absolutely. Anyone who knows anything about aerodynamics will tell you that the bed area uncovered, with the tailgate up, is horrendous to the aerodynamics. Just lowering or opening the tailgate is a help, but even that is not as good as either a tonneau cover or a shell. Now, obviously this is not a big deal for around town driving, but on long trips on the interstate, it DOES make a difference and I can attest to it. When I had my old 96 Xtracab, I was going to do a cross country from the San Francisco Bay area to FL, NC, and then back across to the west coast again. I needed a tonneau cover because I was going to be carrying a bunch of stuff that I wanted somewhat protected from the elements, but I didn't want to spend a lot of money because with the exception of this trip, I didn't want a cover on the truck. So at that time, I found a nice one online from someplace in AZ, for $175 [this was 2005], no tax and free shipping. It installed easily and I went on my trip. Almost right away, I could see that I was getting better gas mileage, but I just thought I was seeing things or something. But with every fill up, and this is calculating via good old mathematics, as the truck had no electronics on it back then, I constantly got between 28-30MPG, which I never got on local freeways on short trips without a tonneau cover. So by the time I made the whole trip, I figured it out and my dollar savings in gas alone, actually ended up PAYING for the tonneau cover! I only used the tonneau cover one other time, and when I sold the truck in 2019, as part of a great deal I swung, I included the cover with the truck when I sold it. The bottom line is that on basic around town or short interstate trips, you are not going to notice any difference, but on long trips like my cross country trip, the improved gas mileage is very much noticeable...
