Does a new exhaust really add Horsepower
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dyna962007, Nov 4, 2017.
  1. Nov 4, 2017 at 1:32 PM
    dyna962007
    dyna962007 [OP] Well-Known Member
    Edwardsville IL near Saint Louis MO
    Tacoma 2016 TRD OffRoad / Previously 2007 4wd
    3" lift kit. 17" wheels and tires, custom grill, full technology package, Early model running boards, Push bar.
    If I were going to add a new exhaust and new intake, does it actually make a difference and if so, what is the best verified brand for doing so?
  2. Nov 4, 2017 at 1:33 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Subbed because in this thread we get to the bottom of this once and for all
  3. Nov 4, 2017 at 1:34 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    If you believe that I have a Bridge For Sale, it's all Snake Oil. Supercharger is the only way. You already have a Cold Air Intake, and if you add an aftermarket one you will get nothing but noise. Exhaust nothing but new noise. Save your money and put it into something you will get something out of.
    shakerhood, Casper66, Tcoma16 and 3 others like this.
  4. Nov 4, 2017 at 1:35 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    No you won't as this is discussed all the time. You get no performance gains, no mpg gains, no hp gains. Nothing but noise noise noise
  5. Nov 4, 2017 at 1:36 PM
    stun gun
    Aaronski
    Tacomas.
    Yeah but that’s not what someone else might say....
  6. Nov 4, 2017 at 1:44 PM
    dyna962007
    so id this is not the route to go, what can I do to increase performance, this 3.5 sucks compared to my older 4.0 tacoma
    TXpro4X4 likes this.
  7. Nov 4, 2017 at 1:45 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Then I'll say it too. They don't do anything but make noise.
    TXpro4X4, Kyitty and Unchained 5150 like this.
  8. Nov 4, 2017 at 1:46 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Wait for the SC to come out
    shakerhood and TXpro4X4 like this.
  9. Nov 4, 2017 at 1:46 PM
    la0d0g
    Nothing besides buying a different truck.
    specter208 and Unchained 5150 like this.
  10. Nov 4, 2017 at 1:46 PM
    Lovci
    Lovci Well-Known Member
    2017 White Tacoma SR AC 4cyl M/T
    Yes you do. Minimal, if actually designed properly for it through testing.
    Now if your truck had FI. The gains could be fairly noticeable.
  11. Nov 4, 2017 at 1:48 PM
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    Having worked for the largest aftermarket exhaust manufacturer in the us I can say that is not true.
    A better breathing exhaust whether from down pipe or cat back can free up some hp. Will it be enough to feel. No. Can the combination of sound and moved power output make you think it has made a bigger difference. Yes.
    Depending on models exhaust and how the new exhaust is made (ie x or y pipes) there’s always some power to be made. While peak output might barely change, what often does is somewhere in the total rpm range it can make more power over stock.
    Modern exhausts however are fairly good flowing so don’t expect much net gains compared to say an 80’s stock exhaust.
    12TRDTacoma likes this.
  12. Nov 4, 2017 at 1:48 PM
    stun gun
    Aaronski
    Tacomas.
    coma toy and 12TRDTacoma like this.
  13. Nov 4, 2017 at 1:48 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I have long tube headers. Cat delete. Customs muffler, crossover. Had a K&N air intake.
    Gained 16HP total (verified on a dynojet)
    Ditched the K&N so I could enjoy my truck and stereo again.
    Added a URD maf calibrator. Accelerate is smoother now. But MPGs lower.
  14. Nov 4, 2017 at 1:49 PM
    stun gun
    Aaronski
    Tacomas.
    Thanks for saying it too
  15. Nov 4, 2017 at 1:50 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    what about on the butt dyno?
    Unchained 5150 likes this.
  16. Nov 4, 2017 at 1:51 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    ....gtfo with your truth. This forum is no place for that nor will it be tolerated.
  17. Nov 4, 2017 at 1:51 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Meh. Throttle RESPONSE might be better. But I drive an automatic.... so it engages if and when it pleases.
  18. Nov 4, 2017 at 1:52 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    12TRDTacoma and hiPSI[QUOTED] like this.
  19. Nov 4, 2017 at 1:52 PM
    stun gun
    Aaronski
    Tacomas.
    This! Now someone post screen shots of screen shots of dyno results!
    hiPSI[QUOTED] likes this.
  20. Nov 4, 2017 at 1:52 PM
    fatfurious2
    David
    Ashburn, VA
    everytime I go over 3k rpm, I go into warp mode
