Does a heavy duty bumper affect MPG.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTaco09, Mar 24, 2013.
  1. Mar 24, 2013 at 7:56 AM
    NCTaco09
    NCTaco09 [OP] Well-Known Member
    Central North Carolina
    09 Tacoma SR5
    bumper
    So I just bought my 09 Taco. It's my dream car that I wanted for a long time. I am very happy with her. She came with a heavy duty bumper and as of today I'm on track of only getting 300 miles out of a full tank. If my math is right I should be getting 400-450 on the highway. Do I need to change the plugs, only has 65k on them. Or is my bumper to blame. I drive like an old man, piss off all behind me, so a heavy foot is not to blame. So.....?
    CLARIFICATION: IT'S A 4 CYL. Apologize for any confusion.
    Any suggestions?
  2. Mar 24, 2013 at 7:59 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    I might have lost 1 to 1.5mpg after adding my bumper.....not sure if its due to the weight or aerodynamics.
  3. Mar 24, 2013 at 8:00 AM
    Large
    Large Red
    Bumper adding weight and taking drag would probably be the main culprit.
  4. Mar 24, 2013 at 8:03 AM
    NMW 4x4
    NMW 4x4 Wheels With Moose.
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    Yes, primarily from weight. However, if the bumper has a high-clearance approach angle, as most aftermarket ones do, it'll greatly decrease your aerodynamics by allowing more air to pass under the truck.
    I lost about 1.5 MPG adding my JCR to my old Cherokee.
  5. Mar 24, 2013 at 8:06 AM
    BradyT88
    BradyT88 Well-Known Member
    I think the aerodynamics hits it the hardest. I added a few hundred pounds to my Tacoma and my mileage was basically unaffected. My bumper only added about 50-60lbs but cost me a little fuel economy.
  6. Mar 24, 2013 at 8:08 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Yes, you're turning an aerodynamicly challenged vehicle into a brick on wheels. Not a big loss though. Maybe average 1-2mpg
  7. Mar 24, 2013 at 8:08 AM
    gdry06
    gdry06 Well-Known Member
    Gary B
    PNW
    06 TRD SPORT
    3Link'd with trailgear rock assault housing, 295x75x18 Nitto m/t shackle flip kit w/ omd spring refurbs, roof rack, toyota toolbox
    300 miles to a tank is pretty dam good to start with. i dont think it would be much of a difference with it as warputer says, if you plan on lifting it, dont bother worrying about the mpgs. on a side not let me know if you decided to sell it. as i wanna go with a different bumper.
  8. Mar 24, 2013 at 8:10 AM
    PLC721
    Patrick
    Chandler, Az
    Yes you need to probably change your plugs if it hasn't been done. As well as some other maintanence.
  9. Mar 24, 2013 at 8:10 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    yep, the aerodynamics of the front end are destroyed with that big bar sticking out.
    On the bottom you now have lots more air directed under the truck into the suspension instead of around the front.
    The bug deflector doesn't help either.
  10. Mar 24, 2013 at 8:11 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Is there a little notch pointing upward under your headlight? If so I think that bumper is for a 12+
  11. Mar 24, 2013 at 8:57 AM
    NCTaco09
    09 Tacoma SR5
    bumper
    That's what I figured. The maintenance schedule makes it look like they are 100k mile plugs, but I don't know I believe that. Just did the rear diff. Planning on front diff, transfer case and transmission.
    Anything else I should change?
    Also, not to change subject, but I keep reading about tightening the drive shaft propeller every 5K....what does that mean?
  12. Mar 24, 2013 at 8:58 AM
    NCTaco09
    09 Tacoma SR5
    bumper
    No, it's a custom from Elite Off Road.
  13. Mar 24, 2013 at 9:01 AM
    NCTaco09
    09 Tacoma SR5
    bumper
    Will do. Thought about selling it, but it's growing on me. I got a body shop to price how much it would cost to take it back to stock, which totalled over $1300 due to all the "little" things it would need....so as of right now, I think I have to keep it. About the only option I would have is if I found someone with a stock bumper to trade.
  14. Mar 24, 2013 at 9:08 AM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    looks like you have a lift and more aggressive tires than stock too?
    300 miles to a tank sounds pretty good to me
  15. Mar 24, 2013 at 9:14 AM
    worthywads
    The plugs are iridium, the schedule is 120k, I don't think you'll see any change with new plugs.
  16. Mar 24, 2013 at 9:27 AM
    NCTaco09
    09 Tacoma SR5
    bumper
    No lift that I know of. Would be a nice surprise though. Tires are BFG Rugged Terrain....look more aggressive than they are. :D
  17. Mar 24, 2013 at 9:57 AM
    NCTaco09
    09 Tacoma SR5
    bumper
    What else does it affect?
  18. Mar 24, 2013 at 12:21 PM
    JKD
    JKD Well-Known Member
    You should be on your second set of replacement plugs. If they've not been changed, it's WAY past due.
  19. Mar 24, 2013 at 12:25 PM
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    im sure someone on here would be thrilled to trade you even or even give you some $ for your bumper plus their stock parts... if you wanted rid of it that is.
  20. Mar 24, 2013 at 12:27 PM
    worthywads
    Wrong, he has I4, 120K.
