Does a 2nd Gen 2.7 Head gasket replacement walkthrough exist?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WPDAWG11, Apr 12, 2023.
  1. Apr 12, 2023 at 12:20 PM
    WPDAWG11
    WPDAWG11 [OP] Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    I had toyota confirm I it was the head gasket. I got in a fender bender which broke the coolant bypass pipe, and it never over heated but I definitely ran it while it was low. After installing the metal bypass my oil started to disappear, but the coolant held pretty steady. Now three years down the road I'm experiencing all of the head gasket failure symptoms.
    I bought the gasket, head bolts, and got the schematics from toyota and am looking for other parts I will want to replace. I bought a haynes manual, but I would really love a walk through to see what tools are needed. My bro will need to bring them home for the long weekend project. I found the walkthrough for the 1997 2.7 gasket replacement, but don't know how how much that would help with my 2005. Any help would be greatly appreciated, I've always had luck with this site. Also doing the fuel pump the same time RIP:annoyed::spending:
    Need to know crucial parts needed
    Need to know tools needed
  2. Apr 12, 2023 at 12:26 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Head gasket replacement parts/info:
    - Toyota Coolant Compatible Seal Packing 08826-00100 - Where this is used
    - Mahle .030" MLS gasket - (my stock gasket was .020" thick and I had the machine shop remove .010" so I could use this .030" gasket. Your replacement head gasket should account/add back for the material removed when having your cylinder head resurfaced)
    - Useful links/threads:
    - 2TR-FE 2.7L dirty coils
    - 2TR-FE Rebuild/Refresh
    Additional info near the bottom of this post
    https://www.tacomaworld.com/threads/2tr-fe-performance-thread.636292/#post-21902910
    TnShooter and WPDAWG11[OP] like this.
  3. Apr 12, 2023 at 5:07 PM
    tacotruck 2.7
    tacotruck 2.7 Well-Known Member
    Katy TX
    09 cab and a half 2.7
    With 205k My 09 2.7 was quoted 27 hours for the labor to replace the head gasket from 3 diffrent shops.
    I got it done & overwith. They tore it down quite a bit.
  4. Apr 12, 2023 at 5:09 PM
    BassAckwards
    Here’s the o-rings and such you’ll need for the timing cover. missed these on my original post
    Timing Cover O-rings & FIPG:
    - Lower oil o-ring 96723-35028
    Two o-rings in the middle of the timing cover on each side
    - 90301-25014
    - 90301-25020
    - Lower pass side of timing cover o-ring 90301-19021
    - Camshaft oil delivery pipe o-ring 96723-19011
    - Seal packing/FIPG for timing cover/oil pan/valve cover 00295-00103
  5. Apr 19, 2023 at 1:06 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    This was for the 2.7 second gen? Just double checking, not seeing these numbers on the schematics toyota printed for me. Appreciate the help, Im so dreading this job.
    Also any odd tools you used that you can remember?
    BassAckwards[QUOTED] likes this.
  6. Apr 19, 2023 at 1:17 PM
    BassAckwards
    Yes this is for the 05-15 2.7L 2TR-FE engine. They were a bear for me to find as well
    WPDAWG11[QUOTED][OP] likes this.
  7. Apr 19, 2023 at 2:12 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    I wrote all these parts down and am gonna head back to the dealer tomorrow. I really appreciate it, you will be saving me a ton of time. I edited my comment too late, but were there any special tools that stood out in your memory. My bros gonna have to bring a lot of them home, and I am trying to be as prepared as possible.
    Also what did you do to get the harmonic balancer off?
  8. Apr 19, 2023 at 2:43 PM
    nightcrawler
    nightcrawler Well-Known Member
    ‘17pro
    WPDAWG11[OP] likes this.
  9. Apr 19, 2023 at 2:53 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Ya I watched this, it was the truck that was probably being used to snow plow. I think 05 had a weak gasket to begin with, and when I cracked my coolant bypass pipe, though I never over heated, it likely put more stress on it. Plus the 80k before my truck could have been rough, and I offroaded the piss out it when I first got it lol
    nightcrawler[QUOTED] likes this.
  10. Apr 19, 2023 at 3:59 PM
    BassAckwards
    I believe you need a 14mm 12pt socket to remove the head bolts. You’ll also want to order new ones of those since they’re torque to yield. I opted for ARP head studs, but that’s overkill for an NA motor.
    for the harmonic balancer, I used a stubby impact and removed it that way. One time I do remember needing a 3 jaw puller to get one off that was stuck. You can borrow one of those from autozone if you don’t have one
  11. Apr 19, 2023 at 4:15 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Already got the head bolts from the dealership. No impact, might see if I can borrow one somewhere. Does the AC have to come off?
  12. Apr 19, 2023 at 4:25 PM
    BassAckwards
    Compressor has to be removed from the timing cover but not disconnected. Same for the power steering pump. Leave all of that connected and just move it out of the way
