Do you/should you rotate in your spare?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SouthernFried, Aug 11, 2020.
  1. Aug 11, 2020 at 10:53 AM
    SouthernFried
    SouthernFried [OP] Well-Known Member
    South Carolina
    2020 TRD OR DCSB
    Input?
    averagejp likes this.
  2. Aug 11, 2020 at 10:56 AM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    If I had a full size spare I would. That way the whole set gets worn down evenly.
  3. Aug 11, 2020 at 10:56 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is personal preference. The spare on mine was a different type (Firestone Destination spare versus Toyo A30s) mounted on a steelie with no TPMS sensor.
    I believe the OR has the same GY Wrangler for the spare, but you'd still be on a steelie with no TPMS.
    With the Carista App and OBD adapter or TechStream and a Tactrix USB adapter, you can easily update the TPMS sensor IDs.
    My preference is for four tire rotations. I cross rotate every 10k.
  4. Aug 11, 2020 at 11:08 AM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    This is correct. What would happen if there was a TPMS in the spare? I thought I read a thread where a dude had one but can't remember how the system sorted it out.
    As far as rotations go, I'm at 18k and have not cross rotated yet. Maybe at 20k I will just do a double-cross! :cool:
    Never used the spare in my rotations but I probably would if it wasn't on a steelie with no TPMS....
    StayinStock and tonered[QUOTED] like this.
  5. Aug 11, 2020 at 11:11 AM
    robie_0n3
    robie_0n3 Well-Known Member
    David
    Scott AFB, IL
    2018 Tacoma TRD Off Road
    I read that the ECU can only hold 4 TMPS sensors at a time, so each time the 5th wheel gets rotated in, it'd have to be programmed again.
    I have an OR with a matching spare wheel and tire and added TPMS, but I haven't rotated it in yet, so I can't speak from personal experience.
    G8R_Taco[QUOTED] and tonered like this.
  6. Aug 11, 2020 at 11:11 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That thread was a mess. They got in a circle jerk about the aftermarket scanner / programmer that still didn't do what they wanted.
    Basically, the system doesn't care about the fifth TPMS. It will just live back there until you manually swap it in.
    Malvolio likes this.
  7. Aug 11, 2020 at 11:13 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Since I have a full-sized spare on a matching wheel and don't need to deal with TPMS, then I rotate mine in so they wear evenly. I switch up tire size/brand every time so there's no sense in having a brand new one that will no longer match the next set.
    edit: I only have a matching spare because I go wheeling and it's a necessity. It's saved me 3-4 times now because I'm always tearing sidewalls apparently. If I didn't need one, then I wouldn't have one nor rotate anything in.
    RobP62 and Jojee117 like this.
  8. Aug 11, 2020 at 11:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is correct. Also, you will see five slots in TechStream. That fifth slot does nothing on the 3rd Gen as TS is a universal tool.
    Note that position is not important when programming other than knowing which sensor is in which tire. The TPMS Reset button will relearn each position while driving. Amazingly, @Jeff Lange said that it measures signal strength to determine the positions.
    robie_0n3[QUOTED] and G8R_Taco like this.
  9. Aug 11, 2020 at 11:14 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Seems like you're paying for an extra tire that you may not need if you're rotating all 5. A decent tire, stored under the bed and out of the sun ought to be good for quite a while before it dry rots out, probably longer than the set of tires being worn I think.
    I usually just a get a mediocre used tire for the spare anyway, so replacing it every 6-8 years is no big deal.
    StayinStock, whatstcp, AKGSD and 2 others like this.
  10. Aug 11, 2020 at 11:18 AM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    So I could manually swap the spare TPMS in using TS as long as I know the ID's of all the sensors? Does the ID come displayed on the packaging when you get a new sensor? Don't want to buy another scanner/tool....:crapstorm:
    tonered[QUOTED] likes this.
  11. Aug 11, 2020 at 11:20 AM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    It would be a significant increase in the PITA factor! :thumbsup::cheers:
  12. Aug 11, 2020 at 11:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. You can read the Sensor IDs physically. You can screenshot your existing ones.
    That's the problem. LoL! The scanner / programmers are like $250. Why bother when TS is free and you already have a Tactrix. :D
    Smacky2020 and G8R_Taco[QUOTED] like this.
  13. Aug 11, 2020 at 11:29 AM
    SweatyBiscuit
    SweatyBiscuit Well-Known Member
    Paul
    Northern AZ
    2016 Taco TRD OR
    Katzkin leather, heated seats, Popnloc, bed lights, remote start, bhlm....
    I had discount put a sensor in my spare. I just drop it off and the do the 5 tire rotation, easy and effective. And I have a real tire/matching rim in case of emergency. They reprogram the sensors each time to keep the computer happy
    JStarr and tonered like this.
  14. Aug 11, 2020 at 11:30 AM
    joeydurango
    joeydurango Nightfall Overland
    SW Colorado
    Heavily modified 2015 TRD w/Drifter
    I do a five-tire rotation on my truck. Bought five of the same wheels/tires when I upgraded from stock. No 5th TPMS sensor. The one rubber valve just cruises through the rotation pattern and has never given any issues. I could care less about the TPMS system anyway, although if it was flashing an idiot light at me I'd get annoyed. It doesn't.
    If you wear four of your tires down significantly and never use the fifth, then when you need to use it you might get a wheel speed sensor error if you have to travel far at speed. This is because the unused tire is literally larger in diameter by a significant amount and will rotate more slowly than the worn, used tire on the other side. I know this sounds nuts, but it is true.
  15. Aug 11, 2020 at 11:37 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I bought a used, near-mint OR wheel and an extra TPMS sensor b/c I don't like the "look" of the spare. Planning to stick with stock tires for a few years though but contemplating going a little bigger in the future. Not sure yet on 5 tire rotation vs 4. But my perspective is, since the truck allows a full size spare, why not have a setup ready to get up and go if you do destroy one tire/wheel. Granted it'd be highly unusual to trash the actual wheel itself but it _could_ happen. And isn't it nice to _not_ feel an obligation to swap back once the spare is on? Or at least have 100% confidence that all your wheels are good to go?
    I had a donut for my prius, had to swap it in twice, and I was always tentative about driving on it. Granted the stock steel spare is fully capable but still, it looks UGLY so no way you're going to just leave it on after you swap right?
    The only thing I can't decide yet is, should I buy a new tire for the new wheel and have 6, keeping the stock spare in my storage locker for a super oh-s sort of situation? Or just swap the tire, sell the stock spare and be done with it?
    I suppose there may be some argument against carrying a nice clean wheel clamped in the spare location? But I would expect any scratches would be on the inside and not visible?
    Mostly I wanted a legit spare just because and I figured might as well get the TPMS while I'm at it, but not gonna pony up for a tool nor am I planning to do my own rotations b/c my driveway isn't safe enough for that.
  16. Aug 11, 2020 at 11:37 AM
    joeydurango
    SW Colorado
    Also true, I agree. But I often travel in areas where it takes hours to get, well... anywhere. So I may be a little paranoid. :)
    I think Toyota mentions (can't remember in what publication but I swear I've seen it) the warning light taking 10-20 minutes of driving to activate?
    tonered likes this.
  17. Aug 11, 2020 at 11:37 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's why I am living with 265/70R17 ATs and the 265/65R17 stock spare. When I swap these out, I will keep one and spoon it on.
  18. Aug 11, 2020 at 11:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is a perfectly reasonable situation. If I was truly out like that, I'd have a different scheme.
    No. The TPMS updates near real time. Some folks use that screen when airing up / down.
  19. Aug 11, 2020 at 11:40 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    No, never have.
    vicali likes this.
  20. Aug 11, 2020 at 11:41 AM
    JStarr
    JStarr Life Off the Road
    Jonathan KH6X
    Kaupo Southeast Maui, Hawaii
    Tacoma 3rd Gen 2017 quicksand TRD OR, T4R 5th Gen TRD ORP silver , Tundra 2000 TRD OR silver, Deere 5300 4wd, Wrangler 1994 ARB air lockers, 1998 BMW R100RTL.
    I used to rotate 5 of same tires/wheels, but times have changed. TPMS issue makes this a royal pain.
    Until around 10 years ago I had the expectation that I would be using the spare with some regularity. I live in a place where there is lots of sharp lava rock on and sticking out beside the roads, and I am often in and out of construction sites with nails and sharp metal. All OEM and most other tires would create on road drama. Now I switch out the OEM tires right away and look for some fool who will buy them.
    Running KO2's in E Range (and the Michelin LTX Defenders on my wife's previous ride) and changing them out at 30K miles, it's been more than a decade since we've used a spare.
    So we rotate 4, and make sure to check the air in the (OEM) spare twice a year or so, just in case.
