Do you run bumper shackles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Apr 20, 2020.
  1. Apr 20, 2020 at 1:50 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Does anyone run with shackles on?
    or do you keep them un-installed and inside the truck until needed for recovery?
    They appear to be quick-connect.
    I heard that it's just for looks and does not have as high load rating as the kind that plugs into the tow hitch.
    I'm thinking of buying some black ones to blend in, with the plastic accessory pieces so that they're quiet and don't smack on the bumper while driving a lot
    Supposedly the correct size is 3/4
    is that a good idea?
  2. Apr 20, 2020 at 1:51 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Buy them, keep them behind the seats till you need them.
    Red Mountain, Criera, slomatt and 3 others like this.
  3. Apr 20, 2020 at 2:00 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I don't leave them on only cause of rust and I don't want them perma welded to my bumper
    and people steal them
    whatstcp likes this.
  4. Apr 20, 2020 at 2:00 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    They're quick connect & disconnect for sure! They're there for the taking if someone else wants them more than you.
    Ruffus, El Duderino and whatstcp like this.
  5. Apr 20, 2020 at 2:01 PM
    TacoTuesday1
    FL
    that settles it
    seems like it's best to carry inside the truck so it's there if ever needed
    gonna see if I can figure out which shackle to buy/what size they are, and if it's really as simple as just '3/4" shackle' available anywhere including Wal-mart
  6. Apr 20, 2020 at 2:03 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I keep them inside the cab. My fear they would walk off.
  7. Apr 20, 2020 at 2:04 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    So those are recovery points and are different than safety chain latch points for a trailer. Those are rigging bow shackles they have a rating on them for what they are able to pull or snatch and are plenty strong and aren't just there for looks. Well they are kinda since what they are attaching to is the recovery points in the bumper which all the Bumpers I've seen and dealt with can more than withstand hard recoveries. They are meant to be removed so you can rig recovery gear. Most aftermarket bumpers have the safety chain hook ups behind the bumper attached to the receiver.
  8. Apr 21, 2020 at 7:35 AM
    5150Bronco
    5150Bronco Well-Known Member
    Bay Area, Ca.
    2013 Tacoma 4x4 Access Cab-Special Order.
    I just keep 2 on the front and one oversized in my recovery bag.
    I have the ones on the front a little tight tight just in case...
  9. Apr 21, 2020 at 7:54 AM
    Muddinfun
    Muddinfun Well-Known Member
    I run cheap Chinese ebay polished stainless shackles all the time. They’re plenty strong enough for my Taco and what I do with it. I made delrin washers on the lathe so they’re a tight fit and don’t rattle. I have a long 3/8” bolt that fits perfectly in the hole in the pin to tighten them down tight so they don’t walk away. I take the delrin washers out when I’m going to go offroad. I have strongly considered getting a few soft shackles so the stainless ones never need to come off.
  10. Apr 21, 2020 at 8:00 AM
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    I would say it would depend on the bumper construction. I’ve seen a lot of bumpers where they weld the clevis onto the plate and nothing else. In this case they are not as strong as a hitch that welded into the main structure. My d ring clevis are connected to the main structure that attaches to the frame. This makes them less likely to damage the plate and makes them stronger. However. A hitch tube that’s welded straight back to the center of the main bumper structure is probably the strongest for recovery
  11. Apr 21, 2020 at 1:44 PM
    5150Bronco
    Bay Area, Ca.
    Harbor freight has nice black shackles!
  12. Apr 21, 2020 at 1:47 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I run a zip tie through my shackled to keep them from falling off and as a theft deterrent although someone could easily cut it and remove it.
    nudavinci64 likes this.
  13. Apr 21, 2020 at 1:56 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Yeah you just want the cool look, put them on when you need them (heading out to the trail) or they will grow legs
  14. Apr 26, 2020 at 11:35 PM
    TacoTuesday1
    FL
    What shackles/d-rings does everyone carry?
    I just measured the tabs on my rear bumper and the bore is 1" / 25mm
    I'm guessing the best option for that would be a good load rating 3/4" shackle
    Do you carry more stuff as well, like a snatch strap to pull yourself or others out?
    Am gonna look up how to pull other cars out in snow; not sure if it requires an additional shackle fastened around a pull point of the other car and a snatch strap
    such as a front and rear towing hook that passenger cars usually come with
    Would be interesting if said stuck person in snow for example is facing backwards requiring a front tow hook, which they may or may not be able to find or have accessible
    Like in some cars it's in the trunk, and you pry off a front bumper cap to screw it in a hole;
    which is difficult to find if the person's trunk is full of stuff
  15. Apr 26, 2020 at 11:50 PM
    Muddinfun
    Do not use the eyebolt that screws into the bumper for recovery. That eyebolt is only for pulling a freely rolling vehicle onto a flatbed. You’re likely to end up with an eyebolt through the back window of your truck.
    12TRDTacoma likes this.
  16. Apr 26, 2020 at 11:50 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Tighten them down with a screwdriver and the average opportunity thief can't steal them without using a screwdriver to loosen it.
    M_VanDalen likes this.
  17. Apr 26, 2020 at 11:52 PM
    TacoTuesday1
    FL
    I meant the 2 loops on the back near the hi-lift jack cutouts
    I'm guessing you're referring to that little hook thing that 2nd gens supposedly come stock with under the front somewhere, said to be used for tying down Taco's on flatbeds only
    I haven't figured out the front yet, will search to see what everyone else is doing
    Not sure if it's worth swapping over to a silver colored TRD skidplate and whatever hook those come with
    That or even better depending on how it can be fastened, if it uses less common screws like Torx
  18. Apr 27, 2020 at 12:06 AM
    Muddinfun
    Oh Hell no!
  19. Apr 27, 2020 at 12:15 AM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    There are no legitimate reasons for leaving them on all the time.
    If you go wheeling and think you'll need speedy recovery, then put them on. I'm sure you'll attach one end of a snatch strap then too, because every second matters. Dont forget to pay out a bunch of winch line and have it coiled around the bumper in case you need to winch forward in a hurry. And the front shackle and snatch strap, in case that's an option.
    otherwise, attach when needed and they dont get rusted, lost, stolen, or look like a poser.
  20. Apr 27, 2020 at 12:37 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Good call! I actually use an adjustable large crescent and use the entire surface area of the part exposed and give it a nice cinch down and call it good.
