Do you put weight in your bed for winter driving?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maine_Tacoma13, Oct 31, 2019.
  1. Oct 31, 2019 at 5:15 AM
    Maine_Tacoma13
    Maine_Tacoma13 [OP] Well-Known Member
    This is my first time owning a truck. I remember back in the day my dad always put bags of sand or some sort of weight in the bed of the truck for winter. How many of you do this? Is there a specific reason why? I live in Maine so winters can be pretty brutal here and there are no "snow days" for my work so I'm driving in all conditions. Just looking for some input - thanks!
  2. Oct 31, 2019 at 5:18 AM
    FJ-Dan
    FJ-Dan Well-Known Member
    Minnesota
    Army Green 2020 Tacoma TRD Pro
    I'm in the same boat as you, this will be my first winter with my Tacoma. I'm thinking about throwing 3 50lb bags of sand in the front of the bed above the axel. When spring comes, I'd have to buy about that much to replenish the kids' sandbox anyway. My FJ had enough weight in the back that it didn't matter, but I'm going to try the sand this year.
    bbrown and theredofshaw like this.
  3. Oct 31, 2019 at 5:21 AM
    Ranger Dave
    Ranger Dave Well-Known Member
    Cross FLOT
    2015 White TRD Off Road 4X4
    Fold a cover, Spacers, Scan Guage II, Weather Tech Vents, All weather floot mats, mod sideview towing mirrors, tow package, mod differential. LED back up lights, Flyzeye console/glove compartment lights, heavy duty farm seat covers, TSC bed mat.
    I live on a farm, so I use my Tacoma as a truck. I put in a Tractor Supply Horse Mat. It protects the bed, deadens road noise, limits stuff sliding around, and adds rear end weight. Easy to cut to fit with the use of WD-40 and a razor knife.
    Additionally, I did the ABS disconnect switch mode to disable the ABS for icy roads. That works wonders. Instructions for that DIY project are posted on the TW.
  4. Oct 31, 2019 at 5:25 AM
    su.b.rat
    su.b.rat broken truck
    I'm on road mostly and have E tires which are hard and not complaint when cold. so i have two 50lb bags, one over each wheel. it helps noticeably before the tires warm up. I'm normally spinning tires endlessly on cold mornings, and this is a perfect fix.
  5. Oct 31, 2019 at 5:26 AM
    Mikenewgun87
    Mikenewgun87 Active Member
    Sparta, Wi
    19 Cement DCLB OR
    I've had to put 2x 40lb tube bag of sand in the back of my 05 Prerunner for the last 2 winter's here in Wisconsin.
    Now I have a 4wd OR with a ARE camper shell and bed mat, so we'll see how it handles the snowy roads and trails.
  6. Oct 31, 2019 at 5:27 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    If and when the roads get treacherous here, I put about 6 sand bags in the bed of the truck over the rear axles. About 250lbs.
  7. Oct 31, 2019 at 5:28 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I am waiting to see.
    My 1985 SR5 RWD. Mandatory.
    My 2019? Unsure. Probably though.
  8. Oct 31, 2019 at 5:28 AM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    Yup. I put 300 pounds of bagged dirt in the bed. In the spring Ill then use them around the house. Living in Ohio they do help with traction. I seldom have any problems getting around.
  9. Oct 31, 2019 at 5:32 AM
    Maine_Tacoma13
    Sounds like it might be the right way to go. Do you think having dedicated winters versus all seasons would lessen the need for the weight? I'm assuming the tires really would impact braking more than anything. I ice fish a decent amount in the winter so sacrificing some bed space is kind of brutal but if it's the right move I'll likely do it.
  10. Oct 31, 2019 at 5:33 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Take a look at Duratrac's, they are rated for snow and are a good AT/MT hybrid tire.
    ozpall likes this.
  11. Oct 31, 2019 at 5:33 AM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    First winter with a pickup but in thinking my camper shell should be enough weight
    Hoff likes this.
  12. Oct 31, 2019 at 5:41 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    GTBCKUP likes this.
  13. Oct 31, 2019 at 5:43 AM
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    I put (6) 50 lb bags of gravel all the way front of the bed with straps holding them in place.
    Too far back lifts the front, and if not secured the weight can move around.
    We use the gravel after winter.
    I have a cap, and do not think it is enough.
  14. Oct 31, 2019 at 5:44 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    First time pickup driver in a harsh winter region- yes, you absolutely should add weight to the back, above the rear axle.
  15. Oct 31, 2019 at 5:44 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    I have a regular cab 5 lug 2wd so weight is a must. The older lighter models are a bit ridiculous in the snow, but weight helps a ton. I put 200lbs of tools and sand plus my topper on that. I think the total weight must be something around 400lbs. I would definitly recommend weight on any RWD vehicle that is not in 4wd all the time
  16. Oct 31, 2019 at 5:47 AM
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    That's kinda neat but seems awfully expensive to just add some extra weight. Bags of solar salt/ sand/ dirt are cheap and can be used after the winter is over.
    I didn't add any weight last winter but I think I might grab 5-6 bags of solar salt from the basement and throw them in the bed if we get any decent snow this year
    Lt. Dangle likes this.
  17. Oct 31, 2019 at 5:47 AM
    jayuu
    jayuu Well-Known Member
    Central Maine Highlands
    2017 Black TRD Sport DCSB 6 sp manual
    No.
    Sungod, MinookaBlues and badkids like this.
  18. Oct 31, 2019 at 5:52 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    I use 2 50 lb bags of sand. Actually does help.
    Hoff likes this.
  19. Oct 31, 2019 at 5:54 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    It is expensive, but two reasons made me want to spend the money. The first is that using salt, sand, or gravel would be fine, but I had nowhere to dispose of, or store it after winter was over. I had "borrowed" sand bags from work the year before and was able to return them, but the next year they weren't available. I also had little desire to clean the bed out afterwards. It causes a freaking mess.
    My second reason (that sort of ties into the first) is that having all that sand in the bed would keep me from using the bed. The ShurTrax is able to be loaded on top of. And I tested it by moving furniture a few times the year I had it. It is also easy to remove in case it's needed.
    GTBCKUP and Minimag95[QUOTED] like this.
  20. Oct 31, 2019 at 5:55 AM
    Coronerrpm
    Coronerrpm Well-Known Member
    Bob
    2017 Tacoma sport
    X2 on duratracs
    GreyBaldTaco[QUOTED] likes this.
