Do our front brake pads have wear indicators or squeelers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PbrTallboy, Jun 17, 2024.
  1. Jun 17, 2024 at 2:31 PM
    PbrTallboy
    PbrTallboy [OP] Member
    David
    Minnesota
    2014 Tacoma V6 Access Cab 4WD TRD Sport
    Hey all,
    Maybe a dumb question thats been answered before.
    2014 Tacoma V6 4WD. Do our trucks front pads have audible wear indicators? "Squealers" they are sometimes called. You know, the loud squeal from the pad to tell you its time to replace brake pads?
    We do not have a dash light for pads, like a Euro car, right?
    I'm at 102,000 miles and have never replaced my brakes. Yeah. I am getting concerned.
    No issues, no squeal, no problems..but 102k. Wow.
    I may just replace front pads / rotors.
    Thanks
  2. Jun 17, 2024 at 2:51 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    You could always get a set of calipers and measure how much is left on the pads. That's how you know if they need replacing or not. Either way it's time for some new brake fluid too whenever you do put on fresh pads and rotors.
  3. Jun 17, 2024 at 3:10 PM
    TacoTuesday1
    FL
  4. Jun 17, 2024 at 3:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes usually squealer tabs on inside pad, sometimes both pads
    Pull your wheels off and look. You can easily see pad life through the back of the caliper
  5. Jun 17, 2024 at 8:29 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Yeah just remove the wheel and check, the calipers have an inspection slot that doesn't require removal.
  6. Jun 18, 2024 at 3:27 AM
    Goldielocks
    Goldielocks Well-Known Member
    Squealers are bent portions of a backing shim that when the friction portion of the disk pad is worn produce a 'squealing' sound when driving the truck and applying the brakes!
    Please don't ignore and skip the rear brake. The WHOLE system properly functioning is important and your life depends on it!
