Do OEM plastic bed liners cause rust?
Discussion in '1st Gen. Tacomas (1995-2004)' started by dms90, Jan 26, 2024.
  1. Jan 26, 2024 at 12:44 PM
    dms90
    dms90 [OP] Well-Known Member
    Dirk
    2004 Tacoma Double Cab 4x4
    My 2004 DC has an OEM plastic bed liner. The liner is in good shape but I am worried that moisture which get trapped beneath the liner will cause rust. Should I remove the liner and get have spray in bed liner installed?
  2. Jan 26, 2024 at 12:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Can you lift up the liner and take a look? If it hasn't rusted by now after two decades, it will probably be OK until gas pumps disappear.
    wilcam47 and Andy01DblCabTacoma like this.
  3. Jan 26, 2024 at 1:23 PM
    dms90
    Dirk
    That is a good point. I have not looked under it. It is pretty stiff and I might wait until it warms up a bit before I try to bend it too much.
  4. Jan 26, 2024 at 1:32 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Yes, they trap water between the liner and the bed.
  5. Jan 26, 2024 at 1:43 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    In several ways… dirt will eventually get in there and act as a grinding paste to remove the paint and primer, water will get trapped, and if you live someplace where corrosive salt is a problem that will get trapped too. Drop in bedliners causing rust are the main reason that just about all of the truck manufacturers have switch to polymer beds or spray liners.
    ControlCar and Old metals like this.
  6. Jan 27, 2024 at 4:46 AM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    All I can tell you is what I have seen from personal experience. I pulled the OEM liner on my 96 taco in 2022 and did a DIY spray in liner. I didn't find much wear and tear after 25 years of use, and after always being parked outside in the elements. Maybe it helps to live outside the rust belt and not getting salted roads every winter.
    And she lived hard the 7 years as a farm truck before I decided to restore her. I don't intend to treat her like that anymore.
    Cloud99, sittingbull and jwctaco like this.
  7. Jan 27, 2024 at 7:17 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    I can't trust anybody who photoshops extra door handles onto Chevy trucks, just sayin' :p
    Rusty Taco 11 likes this.
  8. Jan 27, 2024 at 7:57 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I like the final result! Which bedliner did you use?
  9. Jan 27, 2024 at 8:48 AM
    THatt
    Upstate SC
    That’s a work truck. Prudence.
    3JOH22A[QUOTED] likes this.
  10. Jan 27, 2024 at 8:55 AM
    THatt
    Upstate SC
    I used bully liner. It’s ok for my purposes but if I had it to do over again I would have likely gotten a linex and put plastic rail and tail gate caps. The reason I didn’t is because they would not guarantee the string tape wouldn’t pull the clear coat on the repainted truck. I’d just had it repainted about 2 months prior. I was adamant I wanted over the rail so I did it myself. The bully liner will gouge if you hit it hard with a sharp metal edge. The good thing is it’s easy to touch up. I put 6 coats on, prob 3/8” or more. Can add to it if needed in the future. Holding up fine so far two years in.
  11. Jan 28, 2024 at 5:23 PM
    redtaco2001
    redtaco2001 Member
    Fernando
    2004 xtra cab 4x4
    My truck had a drop in liner and underneath was beat up pretty heavily from the previous owner. I jumped the gun and got line-x and it was one of the best things I did.
