Do I need TPMS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pearing, Sep 25, 2020.
  1. Sep 25, 2020 at 5:00 AM
    pearing
    pearing [OP] Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Wheels coming in today. Tires already here. Don't really want to spend more, or wait to take out the old ones... what to do, what to do? Advice?
  2. Sep 25, 2020 at 5:02 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I managed to survive 65 years without it. You should be fine as long as you check your tire pressure and condition regularly.
    And learn to live with the TPMS Light on the dash.
    ABNFDC, sabasarge, Drainbung and 10 others like this.
  3. Sep 25, 2020 at 5:23 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    ^^^same.
    Like I mentioned in the other post about all the sensors going bad at once, my TPMS module went bad and didn't want to spend the coin to replace it. Screw the sensors and use an air gauge.
    Drainbung, BMH and koditten like this.
  4. Sep 25, 2020 at 6:23 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I lived with the TPMS light on. There are ways to keep it off without the sensors. Stuff the sensors in a wheel barrow tire or an air tight pipe, cover the light with tape or there's an electrical mod on here somewhere. Even if you only cover the light, it won't show up on the inspection report through the ODBII port.
  5. Sep 25, 2020 at 6:27 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Are you planning on getting rid of the old wheels or swapping them every winter/spring?
  6. Sep 25, 2020 at 6:51 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If you want to reuse your existing sensors, you should get a fit kit / service kit for it (new valve stems and O-rings). Otherwise there's a 30% chance the sensors will leak when transferred to new wheels.
    Typical battery life of TPMS sensors is 7 years, give or take a couple. If the sensors are original to your truck (i.e. 5 years old), they will fail before your new tires wear out.
  7. Sep 25, 2020 at 6:58 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    If the original TPMS are still working, just transfer them to the new wheels, DIY and free! No reprogramming required.
    06Tacooo likes this.
  8. Sep 25, 2020 at 7:10 AM
    replica9000
    2019 T4R ORP
    That can't be good for the tire. Couldn't that ruin the belts on some tires?
  9. Sep 25, 2020 at 7:12 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    How will you know if there is air in your tires?
    TacoEspecial and Drainbung like this.
  10. Sep 25, 2020 at 7:21 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Just another thing to fail and annoy me. I keep a tire pressure gauge in my truck and check the tires myself.
    ABNFDC, michael roberts and BMH like this.
  11. Sep 25, 2020 at 7:50 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Appx. 18 mo. ago installed new wheels, tires, & tpms. Last wk. the stupid light came on, all tires, including spare, still at, or very near, 35 psi. Can't get light to go off. Aggravating bashterds!!!!
  12. Sep 25, 2020 at 9:36 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    TPMS is built into the valve stems. It is a simple job to replace valve stems when installing tires. You can simply remove the old ones and put them in new rims. But the batteries on TPMS typically last 7-10 years. In some cases longer, they are still working on my 07.
    If the old ones are over 5-6 years old I'd just buy new ones and have them installed. They run $15-$30 each on Amazon. You can usually get a discount if you buy a 4 pack and if the spare doesn't need one you should be able to get a set for $60-$80. Tire stores won't charge any extra to install them at the time you mount tires. They have to put a valve stem in anyway. If they have to break down a tire and install them later it will cost $10-$20 per tire extra. That's why I advise replacing them when you get new tires even if they are still working if they are close.
    TPMS isn't designed to replace an air gauge. They are there to warn of a rapid tire deflation while driving. Lots of people lived without them, lots died when tires blew out while driving at highway speeds too. For no more than it costs, ($60-$80 every 7-10 years) it seems like cheap insurance. About the price of a meal at McDonalds once per year.
    How do you manage that at 70 mph
    In 2011 I was driving 70-75 on an intestate highway when my warning light came on. I was able to get to the shoulder and stopped in under a minute. By the time I was stopped the right rear was completely flat from a 1/2" hole in the tread. With TPMS I had a few seconds warning to get stopped. Without TPMS I'd have had a tire come apart at 75 mph.
  13. Sep 25, 2020 at 9:45 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'll never be convinced the TPM system is a safety feature.
    I'm more inclined it's in place to insure the listed mpg is maintained for that vehicle.
    I figure if I spend north of a grand for new rubber on a vehicle I intend to keep for 10+ years, I'm damn well going to watch my tire pressure closely.
    Drainbung likes this.
  14. Sep 25, 2020 at 9:49 AM
    replica9000
    2019 T4R ORP
    I was talking about the way they broke the bead on the tire to get access to the sensor.
  15. Sep 25, 2020 at 9:52 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    To jimmyh's point - I drove a 1950 Chevy in high school and somehow managed to live w/o TPMS. If you live in a state that requires it to pass inspection, then you'll need it.
    Until recently, none of my other vehicles had it either.
    For older people like myself, TPMS and ABS are unnecessary. I wonder how much longer it will be before we have automated anus wipers installed in toilets.
    Jimmyh and BMH like this.
  16. Sep 25, 2020 at 9:55 AM
    koditten
    Kirk
    Central Michigan
    Mine is bypassed thru the TPMS ECU. The computer is fooled into believing all are present, but there are non in any of my wheels.
    I don't know if this can be done on a 3rd gen, though.
  17. Sep 25, 2020 at 10:24 AM
    Muddinfun
    Muddinfun Well-Known Member
    There will always be people that say, "When I started driving we didn't have TPMS and I'm still alive". I'll agree that you have a much higher chance of dying from covid than dying from a flat tire, but there is still a good possibility that having TPMS could mean the difference between airing up a tire and driving to get it repaired vs. blowing out the tire on the freeway, putting on the spare on the busy freeway, and then buying a new tire. I would bet that more than 1/2 of low/flat tires are from something stabbed into the tire causing a slow leak overnight. Do you get out your tire gauge every morning and check the pressure in the tires? I seriously doubt it. If you have a Scangauge, all you have to do is look at it and see what the pressures are in each tire. But, people that believe that TPMS is a nanny for dumb people, will not be convinced otherwise.
    koditten likes this.
  18. Sep 25, 2020 at 10:35 AM
    jowybyo
    Joe
    Baltimore, MD
    That's exactly what it is. Most people are completely incompetent. That's why stupid nanny laws keep getting passed.
  19. Sep 25, 2020 at 10:45 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Need it? No. Is it nice to have? Yup.
    On two separate occasions the system notified me of a rapid leak thanks to picking up construction debris on the highway, and that absolutely meant the difference between a patch job and a new tire.
    If your truck is already equipped with it, why not take advantage of it? :notsure: Keeping the truck operating like it should is more important to me than my tough-guy ego of "I'm smarter than the machine." It's like asking "my tach quit working, do I really need it to keep driving?"
    771Doug likes this.
  20. Sep 25, 2020 at 10:50 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this. i have a tire pressure gauge in every vehicle. i still love the sound of a a properly used gauge..that double "pffth" sound.
    having said that, i dig the new system. i like the warning advantage. we had an oil pressure indicator for decades..doesnt mean i dont go and check the oil with the dipstick..bit it is nice to know if things have gone awry while driving. i love redundancy.
    if if got new wheels, i would move heaven/earth to get TPMS on the new shoes.
