Do I need to grease my wheel bearings before install?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XXXX, Dec 17, 2012.
  1. Dec 17, 2012 at 11:04 AM
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    YES, they need to be greased with BEARING GREASE unless you bought the bearing and hub pre-assembled from Timken and spent hundreds of dollars. You DID NOT buy a hub and bearing for $100 so if you think you did you didn't....you will only be receiving the bearing.
    See here....http://www.timken.com/en-us/products/lubrication/Pages/faq.aspx
    I think 1/2 the people who own Tacoma's don't clean out the shipping grease and pack the bearings with bearing grease. Properly installed bearings with good grease and good seals should last just as long as the original set.
    If your only getting 10k out of your new bearings before failure your doing it wrong... IMO.
  2. Dec 17, 2012 at 11:29 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    My wheel bearings sounded like hell, and that changed after the new ones. However, I took them all apart. IIRC on both sides the out (or was it the inner?) races looked good but I found some dirty dark looking grease, no pitting spalling etc... though. Same with the matching rollers and plastic cage. The other races also looked good but they still had the factory white grease in there, not a huge amount mind you.
    After inspecting I didn't really find anything that lead me to believe they had any problems but they sounded like ass so ???
    That was at 40 something thousand miles.
    What does it all mean?
    IDK
  3. Dec 17, 2012 at 11:36 AM
    XXXX
    sKiP
    05 Prius
    Poor design?
    Poor quality?
    Engineered perfectly to cost the owner money and make the dealer money?
    :notsure:
  4. Dec 17, 2012 at 11:52 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Well I think the grease on two of those bearings burnt up. However the rollers, cage, and races looked perfect still. How long they would have lasted that way? IDK
    On the other hand, the other two bearings still looked perfect and still have small amounts of the shitty white grease they come with.
    I don't think they come with adequate grease but I think Toyota probably intended them to come this way, just cheap more than anything. Probably works "okay" for a lot of trucks that see light duty use, which is most of them.
    I'd still pack them. I'm just saying...
  5. Dec 17, 2012 at 12:02 PM
    XXXX
    sKiP
    05 Prius
    Yours both look much better then my originals at 70k.
    Well at least now we have a thread to send people links to or maybe (and I know this is crazy) they will do a search and find the answers themselves :D
    My new ones got plenty O grease when I put them on....prob to much
    (no pics of bearings greased up before hub install)
  6. Dec 17, 2012 at 12:05 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    lol I guess that works
  7. Dec 17, 2012 at 12:42 PM
    XXXX
    sKiP
    05 Prius
    So far so good. Got about 20k on them.
    Would be more but my engine needed more lube then I gave it :D
  8. Dec 17, 2012 at 1:09 PM
    Rocketman
    Rocketman Member
    Downingtown, PA
    2007 DC TRD Off Road
    The Tacomas wheel bearings are sealed and should not be taken apart to apply more grease...while I agree with slightly greasing the seals and things I disagree with you saying you need to pack these bearings with grease. Packing a bearing with grease does not mean slathering it all over the front and back of it.
  9. Dec 17, 2012 at 1:17 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Hmm..my last front wheel bearing on the driver looked and sounded like ass, no question that they needed to be replaced. Now my passenger side is making noise. Sometime this week I will tear it down and go from thefe
  10. Dec 17, 2012 at 1:23 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I gave my bearing (sealed in it's packaging) and hub to a shop to have the old pressed out and new pressed in. Do you think they would have packed the bearing?
  11. Dec 17, 2012 at 2:34 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Very doubtful
  12. Dec 17, 2012 at 2:53 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Please tell me more.
    Please tell me how I'm wrong. Please tell me how these are "sealed" bearings.
    Please tell me why they shouldn't be packed with grease or taken apart.
    Cite your experiences and reasoning.
    Edit: Also, maybe you missed his post where he said he had packed his bearings but only had those pictures. While I certainly don't think greasing the outside is needed I see no reason it would do any harm and it may help to prevent corrosion and water intrusion if water passes the seals. Though I'd have probably cleaned off the lip of the seal where the CV enters so as to prevent buildup of crud.
  13. Dec 17, 2012 at 4:51 PM
    XXXX
    sKiP
    05 Prius
    Thanks for the insight LOL. I was not actually asking a question. I already knew the answer and what to do.
    very hard to take pics of packed bearings when ball of grease is in hands. I also needed to keep those suckers clean so they got packed and put right back into the box.
    I wiped it all down after it was installed. I just have those pics from general assembly (on my kitchen table lol). I always over grease :D
    it's a problem I have :eek:
    Hell no.
  14. Dec 17, 2012 at 5:43 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Doh... Guess I'll be redoing that at some point.
  15. Dec 17, 2012 at 5:53 PM
    XXXX
    sKiP
    05 Prius
    All depends on the quality of the employees at the shop. A guy who knows his shit knows the difference between lithium grease and bearing grease.
  16. Dec 17, 2012 at 6:55 PM
    battleyota
    battleyota Well-Known Member
    David
    Oahu, HI
    Beast of Destruction
    OME suspension, All-Pro UCA, rear locker, 4.56 gears front and rear diffs, rear dif locker, 32x11.5 BF Goodrich Mud Terrians KM2, 15x8 Mickey Thompson classic lock, ARB bumper, K&N Air filter. Safari Snorkel.
    Ok after reading this over, I'm getting conflicting advices. The Bearing I have (pic will be posted) seemed to be packed already and I'll have to disassemble them and pack more grease. (according to a few on here) or should I just put it in as is.
    Mind you this will be my first time putting wheel bearings in. so any info would be greatly appreciated
  17. Dec 17, 2012 at 6:57 PM
    MonkeyProof
    SoCal- SGV
    You think that's a sufficiently packed bearing?
  18. Dec 17, 2012 at 6:58 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    This bearing is junk dont install it :eek: rubber seal is missing
  19. Dec 17, 2012 at 7:03 PM
    battleyota
    David
    Oahu, HI
    Hell I don't know. lol, Is it???
  20. Dec 17, 2012 at 7:05 PM
    battleyota
    David
    Oahu, HI
    are you sure? I got two of those and they look the same. and when I looked up online the pics match up to what I have.
    here is another pic
