Do I need to extend studs for 1/4 in spacer?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Michael05, Mar 20, 2023.
  1. Mar 20, 2023 at 8:09 PM
    Michael05
    Michael05 [OP] Not-Known Member
    2003 Prerunner
    Driver Skill Mod
    Want 15 in wheels and hear they rub the calipers. People say a 1/4 in spacer will clear it but do I need to extend my wheel studs for that?
  2. Mar 20, 2023 at 8:46 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    rub the calipers? On a 1st gen?
  3. Mar 20, 2023 at 9:19 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    You can use the search, to find your answer, sounds like you haven’t bought anything yet as you want to fit 15s
    but just to save others the time posting they’ll ask why 15” wheels, then say go 16s no wait go 16s make sure they clear calipers for tundra brake upgrade.
    Tundra brake wheels fitment
    https://adventuretaco.com/guide/which-wheels-fit-the-tundra-brake-upgrade-on-a-tacoma/
    See brake section:
    https://www.tacomaworld.com/threads/1st-gen-diy-and-how-to-thread-compiled-list-of-helpful-links.95271/
    Tundra brake write up:
    https://adventuretaco.com/guide/step-by-step-tundra-brake-upgrade-on-a-tacoma-or-4runner/
    Good luck
    treyus30, Michael05[OP] and TACOTU3 like this.
  4. Mar 20, 2023 at 9:24 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I have 15" and it doesn't rub. YMMV.
  5. Mar 21, 2023 at 7:46 AM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    Yes
  6. Mar 21, 2023 at 7:01 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Purely from a safety perspective, the answer is yes to your original question. Those spacers will otherwise rob you of 1/4" of thread for your lug nuts to "bite", and therefore your wheels are less secure to your rig.
    The proper solution is either to buy new rims with different backspacing that won't rub (could mean going up to 16" rims too), or using the bigger hub-centric/lug-centric spacers like Spidertrax or Bora make. I have Bora .75" spacers on mine because when I bought my truck it had the 1/4" spacers on it to prevent the rims from rubbing on the calipers and no tire shop would touch my truck for rotations or balancing because they said how unsafe those are. The spacers are cheaper than new rims
    Michael05[OP] likes this.
  7. Mar 21, 2023 at 8:00 PM
    Bob12321
    Bob12321 Well-Known Member
    Robert
    Or you can get ET lug nuts.......extra thread. Thats what I run.
  8. Mar 21, 2023 at 8:22 PM
    Red_03Taco
    Jerad
    Correct me if I'm wrong but that doesn't solve the problem of the spacer taking up more of the lug stud. You'd want to at least lengthen your studs 1/4" to ensure the same amount of exposed thread is there for the lug nut to grab
  9. Mar 21, 2023 at 8:23 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    You’re correct. I’ll still need extended studs
  10. Mar 21, 2023 at 8:28 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    1/4" is practically nothing. Go to like 1"+ and it should come with it's own new studs. Or like mentioned get wheels with the proper offset. Idk why you'd WANT to run 15" wheels given the option
  11. Mar 21, 2023 at 8:34 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    They don’t give true 33x12.5 on a 16 inch wheel and I like the way 33x12.5 looks on a 15 inch wheel. I plan on getting the proper back spacing but as my dad says hope for the best prepare for the worst so I am doing research in case there is contact on the caliper.
  12. Mar 21, 2023 at 8:36 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    The plan is 33x12.5 on a 15x8 -3.75 bs
  13. Mar 21, 2023 at 8:37 PM
    Red_03Taco
    Jerad
    Fully seated I believe our lugs typically grab about an inch (1") to an inch and a quarter (1.25") of the stud, with no spacer in place. So a quarter inch spacer is at least taking up 20% or as high as 25% of the available stud threads. That seems far more than "practically nothing". Totally agree though that 15" rims don't make much sense, unless you've already got them and don't want to pay for new rims
  14. Mar 21, 2023 at 8:39 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    Why don’t 15 inch wheels make sense? I don’t plan on doing the tundra brake conversion. And the tire size I am planning on getting it’s not available on a 16 inch wheel and I do not want to size up to a 17 inch wheel.
  15. Mar 21, 2023 at 8:39 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    @Red_03Taco is correct, you either need new studs or different wheel spacers. I have had a good experience with my 1.5” Spidertrax. It’s not worth the risk of what could happen if you loose a wheel at speed.
    Don’t ask how I know :anonymous:. But I got really lucky and only had to replace a wheel, rotor, LBJ, & LCA on the ‘92 SR5 I owned at the time.
    Red_03Taco likes this.
  16. Mar 21, 2023 at 8:41 PM
    Red_03Taco
    Jerad
    There's far less tire options for the 15" rims overall, as less and less people run them. So given the option to buy either, I'd just go with 16" and it leaves open the possibility to do the tundra brake upgrade if you find yourself changing your mind on that down the road.
  17. Mar 21, 2023 at 8:41 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    I’ll just get extended wheel studs. Problem solved right
  18. Mar 21, 2023 at 8:43 PM
    Wadar
    Wade
    A few.
    Yet… I recently installed big brakes on my ‘02 and it was an improvement with my other mods and weight.
    Michael05[QUOTED][OP] likes this.
  19. Mar 21, 2023 at 8:45 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    You'll be spending more on studs + spacers than just getting a 16 or 17 inch wheel. Idk why the tires you want are that important. Like Red said, I've seen more options that exclude 15" and more for 16". These had better be some really special tires
    And I've never pressed out studs, but sounds like a royal PITA depending on how seized they've become
  20. Mar 21, 2023 at 8:45 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    The only weight I plan on adding is a 85lb tube bumper. I’m not getting a rtt or a rack stuff so it’s not like I’m hauling around 600lbs of extra stuff. Ofc 33’s will be harder to slow down slightly but I don’t drive like a manic so I don’t see the need as of now for a tundra brake.
