do I need to clean out my scepter fuel containers?
Discussion in 'Off-Roading & Trails' started by You're A Great Guy, Oct 27, 2021.
  1. Oct 27, 2021 at 3:14 AM
    You're A Great Guy
    You're A Great Guy [OP] Well-Known Member
    Washington
    2016 DCSB TRD Off Road
    King 2.5's, SPC UCAs, Deaver Medium duty expedition leaf pack. DD fog, combo ditch and floods, Martin roof rack, Off Grid Engineering Dual Battery setup, SPod Bantam X, ARB summit bumper, ARB recovery point, Warn winch.
    I bought two surplus scepter fuel containers, they've clearly been used. I know the military does not use gasoline, do I need to do anything before I start using them or can I just fill them up with gas and fuel up my Tacoma with it?
  2. Oct 27, 2021 at 6:42 AM
    huachuca
    huachuca Well-Known Member
    Al
    Tarboro, NC
    2012 4WD DC w/TRD offroad
    Congratulations - nice pickup.
    At a minimum, I'd add a gallon or so of gas to each one, slosh it around thoroughly and pour it through a paper towel into another container. That should be a good indication of what debris, if any, was in the Scepters. If the cans were previously used for diesel, there's a chance the cap gaskets could be made of rubber rather than Viton and they should be replaced. The plastic gasket retaining rings inside the caps broke on both of mine after a couple of years of use and I had to replace them with the aluminum cap flanges from this site https://jagmte.com/collections/scepter-mfc-accessories He has the gaskets and most other parts (cap wrench, spout, etc.) you might need to bring your MFC's up to spec.
  3. Oct 27, 2021 at 2:09 PM
    You're A Great Guy
    Washington
    Thank you! I am about to leave on a trip in a few days and won't be able to get in the replacement gaskets in time. What do you think the risk would be if I were to use the cans for gas before getting new gaskets? I believe the place I bought them from might have already replaced the gaskets as they look really good. I filled them each up with a gallon of gasoline today and have been driving around with them in the bed to slosh things around a bit.
    And thanks for the link, funny how there's a whole cottage industry to support these hearty things.
  4. Oct 27, 2021 at 2:20 PM
    Ubaderb
    Ubaderb Well-Known Member
    15 Tacoma TRD OR
    Where did you happen to find them?
  5. Oct 28, 2021 at 5:08 AM
    huachuca
    Al
    Tarboro, NC
    You should be fine for short term use; Worst case would probably be some slight leakage. Viton gaskets are black with a slightly grayish tint while the rubber ones are darker. If you don't have time to get a proper cap wrench, consider picking up a strap wrench for the tops. They can get pretty tight from expansion if exposed to the sun. Hope you have an awesome trip!!
  6. Oct 28, 2021 at 2:15 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    What color are the straps? Red=gas, Yellow=diesel
  7. Oct 29, 2021 at 7:25 AM
    huachuca
    Al
    Tarboro, NC
    Those are the industry standards but mine were purchased from a sailor stationed at a naval base in VA and have tan straps. They were new with viton gaskets so assume they were intended for gasoline.
  8. Oct 29, 2021 at 1:22 PM
    You're A Great Guy
    Washington
    I have two of them, one was painted yellow at one point and I see evidence that the other was painted red at some point. Paint is mostly rubbed off at this point. I filled up the two of them with a gallon of gas each and have been sloshing it around. Now I gotta figure out what Im gonna do with the gas inside of them I'll need to dispose of.
  9. Oct 29, 2021 at 8:11 PM
    Jiveydude
    Micah
    OH
    04Taco
    Both my tanks have yellow straps, I never swapped out the rubber gaskets for the viton's and haven't had any issues. You could use the gas in your lawn mower.
  10. Oct 30, 2021 at 11:01 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    See if your local government has a hazardous waste disposal facility. If so put it in another container and drop it off.
