Do I need to buy a scan tool to bleed the brakes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ThreeBeers, Sep 18, 2022.
  1. Sep 18, 2022 at 10:51 AM
    ThreeBeers
    ThreeBeers [OP] Well-Known Member
    Ron
    2020TRDOR
    I have a ‘20 OR with the crawl control. I have searched this site and looked on YouTube but cannot find a specific answer to my specific truck.
    There seems to be two different opinions about bleeding the brakes. One says because of the ABS and the crawl control system, that the old have someone pump and push down on the pedal while opening the bleeder screw doesn’t work. You need a relatively expensive scan tool to disable the ABS.
    The other says simply crank the engine and bleed the brakes starting with the farthest and working your way back to the closest wheel. No special tools needed.
    Anyone do this the old way with no problems?
    Just thinking down the road when I flush the old fluid out.
    thanks
  2. Sep 18, 2022 at 11:36 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    ThreeBeers[OP] likes this.
  3. Sep 18, 2022 at 12:35 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    it really depends on if you pumped air into the system to the actuator. If you are simply changing pads or perhaps opened a line or two by the caliper then the old method is fine. If you ran the master dry or evacuated the whole system then you would need to modulate the actuator in order to purge all the air out of it via the ABS ECU.
  4. Sep 18, 2022 at 12:36 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    this is called thread jacking and kind of rude. You should create a new thread and not just tag along to similar or related thread unless you know the OP. Sounds fine to me but I would start a new thread and specify 4Runner since you may just get what everyone’s Tacoma does.
  5. Sep 18, 2022 at 12:44 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Sorry for the problem, I deleted it.
    zippsub9[QUOTED] and wrightme43 like this.
  6. Sep 18, 2022 at 1:17 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    I personally prefer to purge the ABS of old fluid when doing a brake fluid change. If you don't have a tool that can do ABS bleeding, I wouldn't buy one just for that though. The manual bleed is probably enough, the old fluid in the ABS will eventually mix throughout the new.
    If you have a few things on the list that a scan tool can help, add ABS to the list of usefulness.
    ThreeBeers[OP] and zippsub9 like this.
