Do I need leaf springs with a lift kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by supkillah808, Feb 10, 2022.
  1. Feb 10, 2022 at 7:24 PM
    supkillah808
    supkillah808 [OP] Member
    Justin
    06 Black 4D 2WD Tacoma
    3” Lift
    Planning on getting this lift kit. Maxtrac 6.5” lift with fox shocks. Will I be needing leaf springs? If so what kind?
  2. Feb 10, 2022 at 7:27 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    No control arms, but you've got blocks and spindles?
  3. Feb 10, 2022 at 7:32 PM
    Kaleb
    Kaleb Member
    Kaleb
    Indiana
    2012 SR5 DCLB
    Probably UCA's.
  4. Feb 10, 2022 at 7:41 PM
    TacoTuesday1
    FL
    what do you need +6.5” of clearance for
    why are you spending more on a kit without reservoirs when a kit with reservoirs is cheaper
    Why get shocks from a good quality brand (Fox) and then counteract that with a shitty block
    Is it just so you can tell people you have Fox then drive away having it ride like shit?
    Geeves77 likes this.
  5. Feb 10, 2022 at 7:56 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    No, because they are providing the blocks, u-bolts, and longer rear shocks. As has been pointed out, you will need UCA’s in order to be able to align the front end to oem specs.
  6. Feb 11, 2022 at 12:20 AM
    supkillah808
    Justin
    3” Lift
