Do I need hub centric rings?
Discussion in 'Wheels & Tires' started by Ccrames2018, Mar 26, 2020.
  1. Mar 26, 2020 at 9:15 AM
    Ccrames2018
    Ccrames2018 [OP] Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    I'm getting some new wheels with a 108mm bore, and the Tacoma has a 106.1mm hub bore. I have ET lugs, but do I also need hub centric rings? I want to avoid any vibrations.
  2. Mar 26, 2020 at 1:17 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    They are not "needed" per se, but if the wheels you're purchasing accept a hub ring (some wheels don't) then might as well :thumbsup:
    Ccrames2018[OP] likes this.
  3. Mar 26, 2020 at 2:03 PM
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    You definitely don't need them, especially with only 2mm of gap.
    I had custom aluminum ones made since my wheels are 112mm cb.
  4. Mar 27, 2020 at 10:02 AM
    Drifter001
    Drifter001 Well-Known Member
    I run 108's without rings and haven't had any issues after a year and 20k+ miles.
  5. Mar 28, 2020 at 4:56 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I'm assuming a hub centric balance and conical lugs...no.
    As long as the interface between the lugs and lug seats and/or manufacturing tolerances allow the bolt circle of the wheel to coincide with the bolt circle of the hub, it should be gtg.
    Otherwise, you'll need to have a bolt centric balance and/or re-examine the lug to lug seat interface.
    Hub-centric doesn't inherently have less vibration.
    The vibes come from the majority of balance jobs being hub-centric and something else is 'off', as mentioned above.
    If anything, bead seat contour and tire dimensions are more important (i.e. match marking).
