Do I need extended wheel studs??
Discussion in 'Wheels & Tires' started by Jefferywhite223, Sep 2, 2016.
  1. Sep 2, 2016 at 12:24 PM
    Jefferywhite223
    Jefferywhite223 [OP] Well-Known Member
    Jeffery
    Near fuquay varina, NC
    06 Tacoma
    None
  2. Sep 2, 2016 at 12:27 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Looks like very little thread is in contact. Are the wheels suppose to be used with shank style lug nuts instead of acorn style. Or do you have spacers behind the wheels.
  3. Sep 2, 2016 at 12:37 PM
    Jefferywhite223
    Jeffery
    06 Tacoma
    None
    That is the lug nuts they sent me with the wheels so I dont know
  4. Sep 2, 2016 at 12:38 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    The lug nuts are practically empty. You feel safe driving on that?
    Get extended for sure.
  5. Sep 2, 2016 at 12:43 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Where the lug nut sits in the wheel, is there a curved steel insert for the lug but to sit, or is it more flat like a flat washer should be against it.
    You need one of two things if there isn't a spacer behind those wheels. Correct lug nuts if they aren't the right ones (yes, they could have sent you the wrong ones), or extended lugs. Either way, what you currently have is no good. That little bit of thread contact could fairly easily lead to failure.
  6. Sep 2, 2016 at 12:44 PM
    Jefferywhite223
    Jeffery
    06 Tacoma
    None
    Yea I haven't drove it I was just wondering if there was a simpler fix that replacing studs but I guess that's what I'll have to do
  7. Sep 2, 2016 at 12:46 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    What model wheels?
  8. Sep 2, 2016 at 12:47 PM
    Jefferywhite223
    Jeffery
    06 Tacoma
    None
  9. Sep 2, 2016 at 12:48 PM
    Jefferywhite223
    Jeffery
    06 Tacoma
    None
    Moto metal mo962
  10. Sep 2, 2016 at 1:01 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    The acorn lug nuts like you have will have a corresponding curve on an insert in the wheel. If your wheels were made for acorns, you need extended lugs. If your wheels are flat where the lug nuts sit, they most likely need shank type nuts. See pics to know what I mean about shank type. The smaller hole lines up the wheel on the lug, the shank fits inside the larger hole with the washer being the hold point.
  11. Sep 2, 2016 at 1:55 PM
    Jefferywhite223
    Jeffery
    06 Tacoma
    None
    Just called the wheel and tire company and they think they sent me the wrong lugs so they are sending the right ones on Monday so we will see when they get here
  12. Sep 2, 2016 at 2:15 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Cool. Hopefully they get it right with the new ones.
