Do I need an alignment after new wheels and tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by barch88, Jan 24, 2024.
  1. Jan 24, 2024 at 11:18 PM
    barch88
    barch88 [OP] Well-Known Member
    Michigan, USA
    2022 Tacoma SR utility package
    2022 Tacoma SR - just under 15,000 miles
    I wanted to get rid of these steel wheels and minivan tires. Just placed an order for a set of Method 703 wheels in matte black (17" +0 offset), paired with a set of Toyo AT3 (Load C) 265/70r17, and some new lugnuts for the wheels. I plan to swap the TPMS sensors over from the OEM steelies, I heard you have to install them upside down or something if you try to reuse the steel wheel TPMS? Is this true? Didn't want to spend $150 for another set, plus the reprogramming fee.
    My main question - do I need a new alignment if I'm installing these and upgrading tire sizes from OEM? I'm fully stock, suspension wise, no lift or anything of the sort.
    Thanks
  2. Jan 24, 2024 at 11:24 PM
    Boco10
    Boco10 Well-Known Member
    ADK
    Bigger tires need an alignment. Sensors should work
    barch88[OP] likes this.
  3. Jan 24, 2024 at 11:38 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    At 15k? Couldn’t hurt, but probably not necessary. I would.
  4. Jan 24, 2024 at 11:44 PM
    barch88
    Michigan, USA
    Roger. Was a previous fleet vehicle, picked it up with 13k back on Thanksgiving. Did the usual stuff to do, oil change, new cabin and engine filter, and a tire rotation. Probably due for an alignment anyway, probably was drove hard and not well cared for given that it was a fleet truck. I'll just get it done then. Should only run me like $100-$150, thanks for the input. Don't wanna burn thru my new $1200 tires.
    Chew[QUOTED] likes this.
  5. Jan 24, 2024 at 11:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Ideally, you want to do an alignment anytime you put on new tires.
    If you want to keep the warranty on the tires, you should.
    It’s insurance on your part. If steering and suspension components are worn, you can’t get a good alignment,
    If you can get a good alignment, you have back should you need to warranty the tires.
    skidooboy, barch88[OP] and Chew like this.
  6. Jan 25, 2024 at 12:02 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Nah, it’s probably a great truck, has low miles,, and sounds like you’re doing good addressing maintenance items, so I’d just spend the extra jingle on the alignment. again; that’s super low miles, it probably wasn’t abused, and will serve you well for another quarter million miles.
    Have fun with it!
  7. Jan 25, 2024 at 12:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    Since the hubs are what is being aligned, tires don't matter.
    However, with an unknown alignment history and new tires, I'd spring for it.
    Also the shop installing the equipment *may* require the OE type correct sensors instead of dinking with the wrong style. So ask before you go so you don't get surprised.
    doublethebass and barch88[OP] like this.
