Do I need 650/700lb coils with King 2.5 coilovers?
Discussion in 'Suspension' started by cementnotgray, Feb 15, 2021.
  1. Feb 15, 2021 at 9:01 PM
    cementnotgray
    cementnotgray [OP] Well-Known Member
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    AccuTune has consistently recommended to go with 14" 600lb springs but that doesn't seem right for the weight of my truck. I have a hidden winch mount, 10k warn evo, sliders, skids, roof rack, roof top tent, decked system, awning, full size spare. Pretty much the works without bumpers. Everything I read on here tells me I should be looking at 650lb or 700lb springs (3rd gen OR looking for 2.5in lift).
  2. Feb 15, 2021 at 9:07 PM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    If you're ordering from them they'll ask you for your list of armor and weight. I just ordered Fox 2.5s and Deaver packs from them and they chose 650 lb springs for my front and stage 2 for my leaf packs based on my weight which was as follows:
    Front:
    Demello Steel Bumper w/ Single Hoop - 125 lbs
    Smitty 9.5 Winch - 80 lbs
    BAMF 1/4" Steel Front, Trans, IFS skids - 200 lbs
    BAMF LCA Skids - 23 lbs
    Total - 428 lbs
    Rear:
    Pelfreybilt Sliders - 100 lbs (guess this could add to either front or rear weight?)
    Mobtown Rear High Clearance Bumper w/ Swingout, Carrier - 180 lbs
    Leer XR Cap w/ Rack - 200 lbs
    Full Spare & Hilift - ~80 lbs
    Total - 560 lbs
    Total additional weight = 988 lbs
  3. Feb 15, 2021 at 9:11 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have a similar setup and run 700lbs with no issue. Had a plate bumper which is why I went 700 but went to a hidden winch instead. I think 650 would be good but I’m happy with my 700s
  4. Feb 16, 2021 at 5:09 AM
    Jared8907
    Jared8907 txtaco07
    Texas
    2015 DCLB 4x4
    Weathertechs Tint Led Interior Method NV TRD Pro Bilstein Suspension Icon AAL CaliRaised sliders
    I’d trust them on their recommendation...I asked them the same questions, which they basically responded by saying most people try to improve handling with springs instead of valving. Most everyone uses heavier springs because they have standard off the shelf valving, which accutune greatly approves upon to have better ride and control characteristics. I’m roughly the same weight and I’ve got a DCLB. I’ve got a full plate bumper, but no winch so our front end weight should be similar. They said If I added a winch, I would probably still be fine on the 14# 600s (stock fox is 13” 600#)...however if I did add a little more weight after that, the valving would still work just fine if I decided to go to a 14” 650#. I think from what I’ve read on the fox owners thread and what I’ve seen from accutune so far the 14/600 would suit you fine. I’ve got my rear fox dsc and deaver u402 stage 2 on and they’re fantastic. I was going to put the fronts on this weekend but texas is a freezer...
  5. Feb 16, 2021 at 5:27 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    AccuTune has a reputation for knowing their shit.....
    FWIW, I have 2.5s with 600lb springs and a stock front end, no armor whatsoever - with your setup I’d definitely get more opinions, but it sure would seem a heavier spring is warranted.
    AccuTune Offroad and SR-71A like this.
  6. Feb 16, 2021 at 5:30 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This x100. So many people are oversprung because the valving that comes stock in these shocks is so damn soft. If they're recommending 600 lbs, then I would listen to them. It sounds like you don't have that much front-end weight anyways.
  7. Feb 16, 2021 at 5:33 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    You need to consider weight distribution. Unless everything you listed including RTT is on your hood :rolleyes:
    TVH475 and cementnotgray[OP] like this.
  8. Feb 16, 2021 at 6:56 AM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    So valving helps with sag? o_O I have OME 887s and 5100s on there now and have noticeable rake since I put the winch/mount on the front.
  9. Feb 16, 2021 at 7:04 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    No, spring length and tensile strength (lb/in). Valving would help with dampening the heavier loads, reducing the risk of bottoming to some degree. Some guys add weight to lower spring rates and find that the ride becomes under dampened and harder to control at speed.
  10. Feb 16, 2021 at 9:08 AM
    Jared8907
    Jared8907 txtaco07
    Texas
    2015 DCLB 4x4
    AccuTune Offroad likes this.
  11. Feb 16, 2021 at 4:41 PM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    Even though I'm sagging on 600lb springs right now?
  12. Feb 16, 2021 at 4:53 PM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    I'm just gonna chalk it up as they know more than me and not think about it anymore :spending:
    rollin904 and SR-71A like this.
  13. Feb 17, 2021 at 7:30 AM
    Jared8907
    Jared8907 txtaco07
    Texas
    2015 DCLB 4x4
    What do you have the 13” stock fox springs?
  14. Feb 17, 2021 at 7:52 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Here is an off the wall thought.
    Go to a CAT scale. Weight the front, weigh the rear, weigh the whole truck.
    Should be a bit more accurate than guessing how much weight you've added.
