Do I have a timing belt or chain?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyboy718, Apr 26, 2017.
  1. Apr 26, 2017 at 7:17 AM
    flyboy718
    flyboy718 [OP] Well-Known Member
    Dallas
    05 Prerunner 4 cyl manual 226,000 miles
    2005 PreRunner 2.7L 4 cyl. I have 191,000 miles on her without a timing chain/belt change. Do I have a belt or a chain and should I get this changed or not?
  2. Apr 26, 2017 at 7:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Chain.
    You can use the Gates site to find parts available for vehicles. If a TB isn't listed, it's a chain. They'll also call out interference vs non-interference engine designs
    http://www.gates.com/all-search-tools/search-by-application
    You might change it at that mileage when you go in after something else, like a water pump or other things in that area. Otherwise, if it's not noisy, leave it alone.
  3. Apr 26, 2017 at 7:35 AM
    flyboy718
    Dallas
    I haven't noticed any noise with the chain but on cold start up I can hear that little bit of valve rattling for about 30 seconds or so. The chain just makes me nervous. I had a 93 regular cab 4WD that the timing chain broke on me.
  4. Apr 26, 2017 at 7:40 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    I would be more nervous with a belt,than a chain.
  5. Apr 27, 2017 at 1:14 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I have never seen a timing chain break. I have seen worn timing gears and a chain jump a tooth or two, but never a broken chain.
    Oh you silly flybpys... ( joking)
    I think you are confused, or I am old and crazy... never mind that last part...
    The 1993 T100 Trucks had the 3VZ-E V6 engine? That engine has a Timing Belt and not a Chain. So you must have broken a timing belt. As a general rule timing chains do not break and should last as long as the truck. The biggest issue would be a chain guide wearing.
    Lester Lugnut likes this.
  6. Apr 27, 2017 at 2:41 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    That Gates site is slick!
  7. Apr 27, 2017 at 3:03 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    had a chain break on a 2003 accord
    ajmogen likes this.
  8. Apr 27, 2017 at 3:34 AM
    Clearwater Bill
    Billy
    Largo Florida
    Both the 4 and the 6 had belts, no chains.
    Both are interference fit engines.
    That must have been ugly!
  9. Apr 27, 2017 at 4:10 AM
    JPT4x4ac
    JPT4x4ac Well-Known Member
    Jon
    Broadalbin , NY
    2012 Grn Tacoma AC 2.7 MT
    Ran my '07 to about 300k never changed the timing chain. You should be good for at least another 100k! The 2.7 has more than one timing chain because of the vvti.
  10. Apr 27, 2017 at 6:31 AM
    flyboy718
    Dallas
    It was a 1993 4WD single cab toyota. I was in a parking lot back in my college days and just started my truck and heard a loud bang come from under the hood and my truck shook and quit. I pulled the dipstick and it looked like white milk. Towed it to my mechanic who is a Toyota expert and said timing chain broke. It damaged rods,rings and other stuff. $1,800 later I basically had a new engine with the exception of the pistons.
  11. Apr 27, 2017 at 7:19 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    The 4 cylinder Accords started using chains in '03, 6 cylinders all used belts in that generation.
    Durnaia likes this.
  12. Apr 27, 2017 at 9:18 AM
    coffeesnob
    VA
    Ya it's a chain
  13. Apr 27, 2017 at 10:47 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I you keep clean oil in the motor and drive like a reasonably sane person the chain will last the life of the car be it 200K or 500K miles.
  14. Apr 27, 2017 at 12:19 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I've only heard of one timing chain issue. My buddies dad still has an 08 or so Suzuki XL7, which has had the timing chain replaced 4 times! Other than that I have never heard personally of timing chain issues with any brand.
    I wouldn't worry about changing it if it were my truck.
  15. Apr 27, 2017 at 12:26 PM
    Jeffs68
    Stock
    It's all about the maintenance (oil and filters), the variable timing engine oil passages used to operate the camshaft actuators are so small now, it doesn't take much dirt or debris to plug them up. Some makes are more tolerant to low or dirty oil, some are not...Nissan and Infiniti motors are the worst I've seen, run it low and dirty for just a few thousand miles and the chain stretches beyond the ability of the tensioner to keep it tight. Causes drivability issues and worst case no starts and engine damage. Mazdas are bad too...I could go on and on :cool:
  16. Apr 27, 2017 at 3:09 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That was my point, in 1993 3VZ-E engine in the Toyota T100 Truck had no chain to break.
    It was a belt
    . No discussion needed.
    https://www.youtube.com/watch?v=CedKVmEnc-M
  17. Apr 27, 2017 at 3:13 PM
    BamaToy1997
    Bill
    Navarre, FL
    All Toyota 3RZ-FE engines used a double-chain set. 1 timing chain, and 1 balance shaft chain.
  18. Apr 28, 2017 at 5:35 AM
    ColoradoTom
    ColoradoTom Team Velveeta™
    Colorado
    2014 Tacoma 4x4 Access Cab
    Well, he never once said it was a T100. He said it was a 93 regular cab 4x4. I assumed he was talking pickup (hilux) not T100. If it was a regular cab hilux, very likely a 22RE. With a chain.
    Sorry, I guess I needed some discussion.
  19. Apr 28, 2017 at 5:43 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Also the 22re was famous for wearing out chain guides and jumping timing. Not to mention most Toyota regular cabs come with a 4cyl from the factory.
    ColoradoTom[QUOTED] likes this.
  20. Apr 28, 2017 at 7:26 AM
    taco206
    taco206 Well-Known Member
    No. 2003 Accord 2.4 is K series. Has a chain. The V6 J series have the belts.
