Do "D" or "E" load tires affect ride?
Discussion in 'Wheels & Tires' started by moosey52, Mar 6, 2020.
  1. Mar 7, 2020 at 5:20 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I have E rated. They are great tires. It’s a truck not a Prius.
    Junkhead and Inferno! like this.
  2. Mar 7, 2020 at 5:23 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Hello engineer. :cheers:
    Tacman19 and 0xDEADBEEF like this.
  3. Mar 7, 2020 at 5:38 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    What? No. Not at all. You can get ELoad tires and live with it. The trade off in tire selection and how much side wall protection is a compromise that's up to owner to decide.
    But let's not start spreading lies that they're even close in the ride feel. 10/10 drives will know a c vs e load in a blind test.
    Fact.
    Suspension determines how fast you can take a corner without drifting to the outside due to bumps and lack of traction. Or to control slow body roll when negotiating difficult terrain that you can't afford to slide around on. Or to save you (a little) when you hit that collapsed drain pipe at 70.
    It does not negate the stiffness in tire. My suspension doesn't even start to butter up until I'm past 45mph.
    OP, no need for anything more than a C unless it's a specific tire you want (which I'd say get a different one) or you need the extra protection. In which case I'd still talk to others to see if you really need it.
  4. Mar 7, 2020 at 5:44 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I'd also tell the OP to check out the sidewall protection on C Load Duratracs. Especially around the rim, it's got great protection.
    m603holden[QUOTED] likes this.
  5. Mar 7, 2020 at 5:53 AM
    m603holden
    Marteeen
    New England
    Yup. They had a reputation to shred. And whether it was an old bad wrap or they did something to change it, certainly not the case now.
    I've got 3 years of rolling around on trails at 17psi no problem. They do get squishy at 15 around the bead. I've got a few thousand miles at 25psi ripping backcountry with zero issues.
    Point being, tires rip, but mine haven't yet and I've thrown everything at them. My local trails are rock gardens. Didn't need E load and I have way more comfort driving. I won't go back to E unless it's a dedicated trail rig.
    Tocamo[QUOTED] and P-Dawg like this.
  6. Mar 7, 2020 at 5:54 AM
    CorbinDallas
    CorbinDallas Well-Known Member
    Corbin
    Tacoma
    16 MT OR
    Yes. E rated are heavy ply on sidewall, thus helping with the wieght loads usually associated with it. Stiffer sidewall, will effect how much it can flex, thus effecting ride.
  7. Mar 7, 2020 at 6:01 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    That's my experience. I went from BFG KO2 in load range E to Wildpeak A/T3W also in load range E and thought they had mistakenly installed SL since they were noticeably softer. I never tried the SL to know if they actually ride the same, though. BFG uses 3-ply sidewalls and are pretty tough while my Falkens use a 2-ply sidewalls. So construction must factor in.
    If you look at inflation charts, such as Toyo's, you usually need to increase tire pressure going from P-metric to LT for a given load and they specifically say due to this the ride may be harsh. But whether the ride is actually harsher at the same pressure for two tires, again, I dunno. I think it's just the individual tire design and construction more than anything that can be said generally about load ranges.
    https://www.toyotires.com/media/2125/application_of_load_inflation_tables_20170203.pdf
    wi_taco and o313[QUOTED] like this.
  8. Mar 7, 2020 at 6:53 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    The people that say it does not effect ride are the ones that slow down to a crawl over train tracks and take turns as 0mph.
    wi_taco, 05chaos, mallege and 4 others like this.
  9. Mar 7, 2020 at 2:56 PM
    Walkdog
    Walkdog Member
    2017 TRD OR
    aah yes - rotational mass vs unsprung mass!
    I wouldn’t know how to quantify the effect, but I suppose the added unsprung weight would put marginally more stress on suspension components, theoretically reducing their performance in addition to the reduced acceleration via increased rotational mass.
    Yet another reason to stay away from load E unless necessary.
    mallege, Tocamo and splitbolt[QUOTED] like this.
  10. Mar 7, 2020 at 3:42 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Unsprung weight; you can work around with suspension.
    Rotational mass; not so much.
    wi_taco and hiPSI like this.
  11. Mar 7, 2020 at 4:03 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Except there is no workaround for loss of efficiency lol.
    mallege and splitbolt[QUOTED] like this.
  12. Mar 7, 2020 at 4:14 PM
    splitbolt
    NW Arkansas
    Tacman19, stun gun and hiPSI[QUOTED] like this.
  13. Mar 7, 2020 at 4:14 PM
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    Huge difference in my opinion, but our roads are also shit here. I ran E rated General Grabber and had my teeth rattled out, now back on P rated Falkens.
    wi_taco and Tocamo like this.
  14. Mar 7, 2020 at 4:15 PM
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    rlx02 and thedriza like this.
  15. Mar 7, 2020 at 9:56 PM
    #35
    Miggyman18
    Miggyman18 Active Member
    Miguel
    18 Tacoma TRD OffRoad DCLB 4X4 White
    well im thinking on Toyo AT2 SL (standard load) since the AT3 are not available yet. BFG K02 E Load have 50,000 but look aggressive. Since i only do city, highway driving leaning on Toyo's.
  16. Mar 8, 2020 at 10:58 AM
    #36
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Of course it does. They are substantially less pliable, resulting in a harsher ride. Don’t be fooled.
    wi_taco likes this.
  17. Mar 8, 2020 at 11:03 AM
    #37
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Yes
    vicali likes this.
  18. Mar 8, 2020 at 11:16 AM
    #38
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    stiffer sidewalls makes for a much more stable ride (and are so much better for towing/hauling significant weight). They don't feel much rougher over smooth graded bumps. However the thicker/stronger/heavier layers below the tread make you feel little cracks and breaks and lines in the road much more sharply.
    I run P rated Michelins in summer and get a smoother ride, and a flat from a road screw every couple years. I run E rated Michelins in winter and never get flats, but feel sharper, more jarring feedback from the tires over rough ground.
    If you run LT rated tires, you should be running more that the stock recommended PSI.
    LT rated tires come with more tread depth do they will last longer on your truck.
    You're brakes won't work quite as well, and you will pay a little more at the pump. If you start hard and stop hard you will notice more difference. Once you're going, I don't think there's much difference. Rolling resistance from tread pattern and PSI would have more of an impact on MPG.
    Also.... the TRD Sport and Off-Road have different suspensions. (or at least they used to). The Sport is stiffer (corners better). Off-Road is softer (flexes better to keep rubber on the ground when articulated)
  19. Mar 8, 2020 at 11:18 AM
    #39
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    And you should think about some 255/75r17 tires in a load C. It's a Jeep size. It works really well on a Taco. Taller than stock, but a little narrower to track better on the road and trail and it also shaves off some weight to offset the kick from the LT weight
    WillT11 and o313 like this.
  20. Mar 8, 2020 at 11:54 AM
    #40
    JG358
    JG358 Well-Known Member
    Jake
    Colorado
    16 Tacoma TRD OR DCSB
    Sure e's ride rougher. Just kinda depends on what your used to as to if its tolerable or not. If your used to driving a 1 ton with training wheels, e's on a Tacoma may seem just fine to you.
    wi_taco likes this.
