Do 2022 Tacomas come with auto on/off headlights?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eric04401, Nov 22, 2021.
  1. Nov 22, 2021 at 11:45 AM
    Eric04401
    Eric04401 [OP] Member
    Maine, USA
    2022 4x4 TRD Sport
    I can't find a definitive answer to this question. I'm considering a 2022 Tacoma Limited and it does not list auto on/off headlights and the specifications sheet. The only Tacoma models where I see auto on/off headlights is in the premium package w/ the TRD Pro or Off Road. I'm not referring to automatic high beams, but the headlights.
    In the 2022 manual (screen shot attached), it shows 3 types of headlights, type A and C have AUTO and it appears that type B does not, but I don't know what type the Limited has. Nobody at my local Toyota dealership was sure either and of course there are no 2022 Tacomas on the lot.
    Montana_Actual likes this.
  2. Nov 22, 2021 at 5:12 PM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    My 2022 TRD OR does (my 2019 did not)
    Eric04401[OP] likes this.
  3. Nov 22, 2021 at 10:02 PM
    Lcfj60
    Lcfj60 Active Member
    2022 Tacoma AC MT 4x4 TRD Sport
    My 2022 TRD sport has auto headlights and auto highbeams too
  4. Nov 22, 2021 at 10:05 PM
    Montana_Actual
    Montana_Actual ;)
    My 22 TRD OR does. I don't know anyone who uses that auto high beam feature tho. Even the dealer was like "that thing is stupid". If you are looking at a limited, you should have it.
  5. Nov 22, 2021 at 11:35 PM
    GatorAintBoutDat
    GatorAintBoutDat Well-Known Member
    19 TRD OR DCSB Cement
    My 2019 TRD OR + Premium had it. The auto high beam feature was worse than useless, but the auto headlights worked great. The Limited should absolutely have it unless the chip shortage caused them to start deleting features (read an article about new GM LTZs not including heated seats, steering wheels, etc)
  6. Nov 23, 2021 at 5:36 AM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    My '21 SR has automatic headlights.
  7. Nov 23, 2021 at 8:49 AM
    yinster
    yinster Active Member
    2021 Tacoma SR5, 2004 Infiniti G35, 2007 Toyota Camry, 2008 Sxion xB
    pretty sure type B is for Canada, cause Canadian headlight system is a little difference from the state ( for instant, their DRL cannot be shut off while e brake is done)
  8. Nov 23, 2021 at 9:04 AM
    Snoman002
    Snoman002 Well-Known Member
    Sno
    21 DCSBORSWMT
    Non-Premium 2021 OR (with advanced tech) has the Auto HEADLIGHTS as well as auto high beams (I also echo the comments about the auto high beams)
  9. Nov 23, 2021 at 9:06 AM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    My 21 trd off road has the auto hi beam button and ive used ut a few times up in canyons at night where you cant see cars until they hook around the blind corners… yes you can see their lights… but the auto hi beam button at least for me does seem to work great as I don’t have to continually enable and disable my hi beams. Just my experience with it. Turns on when no one in front of you and off before they’re gonna be blinded by it.
  10. Nov 23, 2021 at 9:11 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    On an SR, you sure it has auto headlights and not just auto high beams?
  11. Nov 23, 2021 at 9:14 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    My Canadian Pro has Type C. Type B still has a DRL "off" setting.
  12. Nov 23, 2021 at 9:20 AM
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    My 2019 w/Premium + Tech package does.
  13. Nov 23, 2021 at 10:35 AM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    I believe my 2019 TRD OR….have a high beam auto function…turns off when it sees a on coming car…Does NOT work if on a turn…and you see lights…only turn off on direct contact…too late…you just blind the other guy…
    As far as auto turn off because of sun lights? NO
    The best feature is if you leave your lights ON…after you turn off your truck..it will automatically turn off…One of best thing Toyota did for its vehicles…
    Aloha
  14. Nov 23, 2021 at 11:12 AM
    Haole Toy
    Mauna Kea, AZ
    '21 SR 4x4
    It has both.
    shakerhood[QUOTED] likes this.
  15. Nov 23, 2021 at 11:17 AM
    Haole Toy
    Mauna Kea, AZ
    '21 SR 4x4
    My '06 TRD Sport lights would shut off when I opened the doors. I used it all the time in Hilo.
  16. Nov 23, 2021 at 11:18 AM
    shakerhood
    Southern Ohio
    Wow that is really interesting as SR's are usually stripped, I had to get the Premium and Tech Package on my OR to get them.
  17. Nov 23, 2021 at 12:18 PM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    SE MI
    LT, triple locked, 35s, custom aluminum utility bed with FWC
    some welding required
    SRs are getting better base features like AHL, intermittent wipers, and even dual zone climate control now
  18. Nov 23, 2021 at 12:21 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    It's because it's across all trims and easier than having another configuration on the manufacturing line. If everything is auto climate control then it's less parts they have to order, stock, and pick to the manufacturing line. And machines can be removed etc.
    From a manufacturing standpoint there's really only like 5 tacoma options. Everything else is split off on the manufacturing lines and annoying. Reduce overhead and costs by actually upgrading the base trims.
    If I had to buy again now I'd be in an SR hands down. Especially if they still have manual seats. I hate the power seats.
    Red Alert and Sandfox86 like this.
  19. Nov 23, 2021 at 12:32 PM
    Red Alert
    Red Alert Well-Known Member
    CT
    2020 Tacoma SX 3.5 4x4 BRM AC
    My SX is the first vehicle I've owned without power seats in 25 years. When I took it for a test spin I was surprised how comfortable the seat was, not to mention the smoothness of the ride. Power seats are no different from manual seats for me. Set it & forget it. But should they go south it's a lot more $$$.
  20. Nov 23, 2021 at 12:35 PM
    GarlicFarts
    Lil Rhody
    As long as you're comfortable in them - the only time you need to adjust seats is to (a) recline to sleep, sure, and (b) recline them or move them all the way forward/back to clean/vacuum, and then they're just a pain in the arse.
    I don't regret buying the OR trim that I did, but if I had to do it again, I would be in an SR (Or a frontier)
    Red Alert[QUOTED] likes this.
