DIY Winch bumper Build
Discussion in '1st Gen. Tacomas (1995-2004)' started by tthalman, Dec 5, 2017.
  1. Dec 5, 2017 at 8:18 PM
    tthalman
    tthalman [OP] Member
    tyler
    1997 Tacoma 4x4
    LIft/ wheels/ tires
    I tackled the Idea of building my own bumper. I think it turned out great. Mostly used 1/4 plate with a little bit of 3/16 and some square tubing I had Laying around. I just used a welder and a great saw I have for cutting steel. No bending on this thing. I used the factory cross member and welded it to the bumper, and I also made braces that mount to the original bumper mount.
    I think the weak points are the recovery points. I am going to trade them for grade 8 bolts. Also I am converting the winch to synthetic and still waiting the arrival of the fairlead. Really fun build. and i think it is very strong. BUT WE SHALL SEE!!!
  2. Dec 5, 2017 at 8:22 PM
    tthalman
    tyler
    1997 Tacoma 4x4
    LIft/ wheels/ tires
    Oh also, you may see that at first the bumper was just stitch welded together, but later (with the help of a much better welder) I welded all of the seams solid.
    Dangorah and INBONESTRYKER like this.
  3. Dec 6, 2017 at 1:00 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As long as your happy and it does the job .
    That is all that matters
  4. Dec 7, 2017 at 10:50 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    I found that the weak points were the original bumper mounting points on the frame, along with the recovery hook mounting points, on the frame. Hardware held fine. I ended up plating and adding a box cross member after bending all of the bumper mounts in one trip.
  5. Dec 7, 2017 at 11:07 AM
    tthalman
    tyler
    1997 Tacoma 4x4
    LIft/ wheels/ tires
    Ya. The original bumper mounts are just a secondary support on the bumper the main winch point is directly to the frame. I guess we will see. Thanks for the help.
  6. Dec 7, 2017 at 1:13 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I would consider beefier D-ring mount locations. Those look like they are bolted to the front plate.
    Grade 8 bolts or not, most bumpers use like a 1/2" thick piece that is either directly part of the primary structure of the bumper, or at least welded to primary structure.
    like this (pic from nwtrailinnovations):
  7. Dec 7, 2017 at 6:24 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    don't recommend using those as a tow or recovery point. they will deform or rip right out of your bumper.
  8. Dec 7, 2017 at 7:04 PM
    tthalman
    tyler
    1997 Tacoma 4x4
    LIft/ wheels/ tires
    Thanks for the help guys I was really thinking they were the weak point and you have convinced me! I have ordered some 1/2 inch shackles and there is a great place to weld them so they will go all the way to the bumper mount points. Thanks for all the help
