DIY Tailgate Storage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Overland&UpMoutains, Apr 14, 2022.
  1. Apr 14, 2022 at 8:23 AM
    Overland&UpMoutains
    Overland&UpMoutains [OP] Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Warning this is very DIY. Not the prettiest but its cheaper than what's out there (seen some $550+ options). Also I have a horrible streak of why do it right when you can finish the project now so I often use materials I have lying around that aren't alway optimal but work. Anyway I just like trying/building stuff so here it is.
    PS I've seen @MESO post on IG stories that he is building one. From what I have seen it looks super clean and like all his stuff I am sure will be top notch. I had wanted to do this project a while back but abandon it. Big shout to him for getting my juices flowing again. For those who are DIY folk defiantly follow him for that release and send your $ that way so he keeps making awesome gear!
    Materials:
    - 1/8+ Aluminum Panel*
    -ABS Plastic
    -Foam
    -Marine Deck Hatch
    -Fasteners (Rivets or bolts)
    -Steel cable (I used a spare coated steel jump rope cable)
    -Ferrule (ring terminal ends can be used in a pinch)
    *This replaces the stock tailgate panel, I had a @AL Offroad Products Trailgate so I canabolized that. I think the @RelentlessFab is panel is even better because it wraps around. You need a good strong panel because your going to cut away the supports to open up the tailgate. If you want to stand on it you'll need a solid piece of metal. Obviously you could get raw stock and cut yourself. Since I had the pre fab item I didn't measure but I belive it is roughly 55x17 looking some stuff up online.
    Tools
    - Saw (I used Jig saw)
    - File/Deburring Tool (Optional but recommend)
    - Heat Gun
    - Tupperware container (to hold the bolts so you don't loose them)
    Safety:
    - Glasses
    - Gloves
    1) Remove the tailgate panel (t30 Torx bit), don't be a dumbass put your screws in a bowl or something
    2) Unplug the camera and unclip the wires. If your a real champ you can pull it all out the bottom of the tailgate so you know you won't cut anything. But if your like me you will just unclip and move it so you can cut around it.
    3) Mark and cut the Tailgate supports. Only cut the supports in the center, leave the edge supports. Leave a generous amount around the edges. Your tailgate
    panel still needs something to sit on.
    4) Clean out the shavings and deburr the edges.
    5) Remove the lock mechanism tie rods. To remove pull the clip back and then they should slide right out. I left the clips in, incase I need to reinstall and so I don't lose them.
    6) Replace Tie Rod with cable. I used a spare coated steel jump rope cable I had lying around (Crossfit).
    6a Thread the cable through the lateral locking mechanisms first (its easier that way).
    6b Add a ferrule to the end of the cable to keep it from pulling through. I didn't have any actual ferrules but I used a yellow wire retinal connector and crimped it around the cable.
    6c Run the cable behind the supports along upper edge of the tailgate.
    6d thread cable through the central locking mechanism.
    6e pull tension on the cable and add another ferrule. Before you crimp it test it, unlock the tailgate and then pull the handle. Make sure you can see the lock being pulled. If nothing happened make sure the tailgate is actual unlocked, when locked the mechanism is total disengaged.
    6f Repeat on other side
    7) Protect the locking mechanism/wires. I took some ABS plastic and moldeded it with a heat runaround the locking mechanism. Then I used Sounds Deadening Mat (which has a very sticky side and a soft side) to hold it to the tailgate and form barrier between what would be the storage boxes and the lock.
    7) Create a storage box.
    Options 1: Mold ABS plastic, rivet to the tailgate (don't rivet to the outside parts). Best solution but takes a lot of patience with heat gun (more than I had) and probably some experience molding the stuff, its not the easiest.
    Option 2 build a wooden box, might loose some storage but would be solid, also be sure to add foam beneath to protect the tailgate
    Option 3 Use left over Sounds Deadening Mat (Sticky Sided Foam backing with + Foil; Noico or Kilt): So I had ABS plastic but I was having some issues and wasn't patient with the heat gun so I tried this. I lied the whole tailgate with Sounds Deadening Mat. This was kind of odd at first but turned out really well. It is soft so will protect the tailgate and the stuff inside. It is also pretty thick/has some form to it so you can actually use it to create makeshift walls. Even better I had some corrected plastic so in some places I combined them and it all worked out. Other plus is you can easily shape it s you can push it under the edges and get what would otherwise be lost space back (if you were using a hard box). Will report on the longevity of this solution.
    **Almost locked my tail gate shut. Be sure to mask any of the sticky side that isn't in direct contact with the tailgate. Some of the exposed sticky side was preventing the cable from pulling the lock, pulled the material and reapplied but covered the exposed area. Lock is working fine**
    INCOMPLETE WILL POST PICTURES WHEN I FINISH
    8) Cut the Tailgate panel. Take your deck hatch and mark the placement on the panel. Drill holes at the corners and then use a jig saw to cut the rest.
    9) Drop in your hatch and rivet/bolt to the panel. Most marine hatches have a 1" intrusion into the compartment. I am expecting to shave this down since the panel is only 1/8" thick and the tailgate empty space isn't that big to begin. Done want to loose more space than I need.
    10) Put it all together and Enjoy
    Deck Hatch:
    https://www.amazon.com/gp/product/B07Q887FF9?ie=UTF8
    Tacoma Tail Gate Reinforcement Panel:
    https://www.relentlessfabrication.c...a-tail-gate-reinforcement?variant=41786897156
    https://aloffroadusa.com/products/toyota-tacoma-trailgate-panel-2nd-3rd-gen
  2. Apr 19, 2022 at 5:08 PM
    Tooshort
    Tooshort Well-Known Member
    Eric
    2022 DCSB TRD-OR 4x4
    I'm actually really surprised this hasn't caught more attention. This looks great man
    Squirt and Benny blanco like this.
  3. Apr 19, 2022 at 5:11 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice work!
    Looking forward to the finish.
    :cheers:
  4. Apr 19, 2022 at 5:28 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    In for future updates :sawzall::welder::thumbsup:
  5. Apr 19, 2022 at 5:35 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
  6. Apr 20, 2022 at 10:58 AM
    Overland&UpMoutains
    Parker
    Deleware
    No time to finish the write up this moment but here are some photos of the finished product. Will get the write up done soon...ish
    Absolutely loving it. Got all my straps on the left hatch and my airhoses in the right hatch with room to spare. One drawback after finishing they aren't flat. So if you want to take this on find flush hatch if you can. These sit 0.5" off the surface which not a big deal honestly. They are big enough that I can put cups, stove, etc on them without too much worry (and they are flat themselves so still better than stock ridged panel). But in a perfect world Id prefer them to be flush.
  7. Apr 20, 2022 at 11:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very cool!
    Great effort and mod, esp considering the existing teasers out there.
  8. Apr 20, 2022 at 11:04 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Nice! Just gotta be careful raising and lowering?
  9. Apr 20, 2022 at 3:38 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I would think you would want to be careful about what goes in there. Soft storage only.
  10. Apr 20, 2022 at 3:57 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Necessity is the Mother of all invention! Pretty cool idea and decent looking outcome.
  11. Apr 21, 2022 at 10:23 AM
    Overland&UpMoutains
    Parker
    Deleware
    Careful raising and lowering? How do you mean?
    Yea soft storage only at this point. Though with the foam liner in there as long as things are arranged well (not sloshing around) I actually wouldn't be to worried about them or the tailgate. They if packed tightly they won't be banging against the tailgate. I wouldn't put anything too heavy I think.
    Benny blanco[QUOTED] likes this.
  12. Apr 21, 2022 at 10:25 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
  13. Apr 22, 2022 at 10:57 AM
    Overland&UpMoutains
    Parker
    Deleware
    the teasers are what got me going. I knew I wouldn’t be able to resist drop the money for it so I made it myself
  14. Apr 22, 2022 at 10:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Smart man.
  15. Apr 22, 2022 at 2:54 PM
    Doc76251
    Doc76251 Well-Known Member
    2016 ACLB
    My initial thought is that would be the perfect place to stuff a rifle.
    Cheers,
    Doc
  16. Apr 24, 2022 at 12:51 AM
    L3GO_MAST3R
    L3GO_MAST3R Active Member
    2022 AG OR DCSB 6MT / 2022 AG OR 4Runner
    Until someone steals your tail gate and now they got a free rifle too. :infantry:
    Benny blanco and bulalo like this.
  17. Apr 24, 2022 at 3:54 AM
    Overland&UpMoutains
    Parker
    Deleware
    Couldn’t do it with the locking mechanism in the center.
    Mr-Paul likes this.
  18. Apr 24, 2022 at 3:23 PM
    Gametracker
    Gametracker Well-Known Member
    Fort Worth, Tx
    17 sport TRD 4x4
    SSO Hidden winch bumper, Meso puddle lights,
    Nice work. I need to do something like that.
  19. Oct 23, 2022 at 9:09 AM
    switch
    switch Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    Nice work. Can't wait to see the finished job. Could a Hi Lift jack fit in there?
  20. Oct 23, 2022 at 2:18 PM
    kaptainsims
    kaptainsims Well-Known Member
    Sims
    2021 Tacoma TRD Offroad Double Cab 6 speed
    None yet
    That's really need, I did see how open it was inside, but didn't think of it! Great job op!
