DIY spray in bedliner
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoJenn, Jul 21, 2012.
  1. Jul 21, 2012 at 11:16 AM
    TacoJenn
    TacoJenn [OP] *~*
    Jennifer
    Houston, TX
    Campa shell, 5100s
    thinking about doing a bedliner, saw the herculiner advertised and a few other ones, anyone done them? or done the rattle can ones, i hardly use my truck bed so it doesnt have to be super tough, its just the paint is well weathered from sun and snow and is starting to chip
  2. Jul 21, 2012 at 6:27 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    There are tons out there from spray on to roll on or rattle can on. A lot of threads about bed liner. I went with Line-X. It cost a lot more ($400 over the rail) but it was worth it. Just make sure to scuff it really good. Clean it. And mask or take off any hardware you don't want to spray/roll on like tie downs. And it should be simple and effective. There is Herculiner, Raptor, Line-X, Rhino Lining and so much more.
  3. Jul 21, 2012 at 7:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Spend the money to do it right.
    Rattle can bedliner was designed for touchups and to hit areas that can't be rolled.
    And you'll be near the cost of a pro job once you buy enough cans to get a heavy enough coat to be any good.
    Roll-in Herculiner isn't bad for DIY, but it looks DIY. For a beater? Sure.
    Just don't skimp on the prep. Bedliner, like any paint, prep is 75% of the job.
  4. Jul 21, 2012 at 9:51 PM
    Madjik_Man
    Colorado Front Range
    For DYI I am pretty convinced on Raptor Liner after my research.
    I don't have any experience with it though.
  5. Jun 26, 2013 at 2:16 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    hey op, this is a 11 month old thread. have you try it yet doing diy spray in? i'm curious to know how it turn out. have any pictures? were you satisfy with diy? i still have the truck plastic bedliner on and it is limiting the space for things to put back there.
  6. Jun 26, 2013 at 2:35 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    ^This. MUCH MUCH better than Herculiner. Smoother finish and you don't need to add a UV stabalizer to it to keep it from fading like you do with Herculiner. I've sprayed on the inside and underside of my offroad trailer back in 2008 and it's still holding strong and looks great.
  7. Jun 26, 2013 at 7:24 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've used Herculiner on my 96 truck bed, two Jeep Wrangler interiors, & rock sliders.
    Herculiner works pretty darn good for what it is. If you're looking for a cheaper alternative - there's nothing wrong with it. Prep work and installation can be a bit messy & ugly....but worth it.
    1) Wear disposable clothing, long sleeves, gloves
    2) DO not get it on your skin - its a bitch to get off. Don't SCRUB or you could end up with a nasty rash.
    3) Use disposable cups, brushes, everything.
    4) Use an orbitable sander to make the prep work go quicker
    It's gonna be much thinner than the professionally applied liners ... If you rub heavy (heavy) objects across it, it can come off. If exposed to the weather for a few years, it can fade and get even thinner.
    Other than my 96 bed...I Herculined the floor boards of two Jeep Wranglers. With regular wear/tear and traffic, the stuff did not come off. I did the topside of a set of rock sliders also (for traction). It never came off with regular usage.
    The best part about it - you can buy a quart can and do touch-ups without an prep work - as it sticks to itself rather easily. You can make certain areas thicker by applying more coats.
