DIY rock sliders...advice?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pbird74, Apr 12, 2019.
  1. Apr 12, 2019 at 1:10 PM
    Pbird74
    Pbird74 [OP] Well-Known Member
    17MGMDCSR54x4
    Off Road Bilsteins, Pro grille
    I am going to be making my own sliders from square tubing. Any advice or blueprints/drawings would be greatly appreciated. They will be bolt on and for DCSB 3rd gen.
    MTopp likes this.
  2. Apr 12, 2019 at 1:14 PM
    mwaterous
    mwaterous Well-Member Known
    Mark
    Western Slope, CO
    2016 TRD OR
    Buy More Things
    The design doesn't change a whole lot between companies. I would advise buying them from someone who has made and tested a few hundred already, but then I don't know what your background is.
    MTopp and Chew like this.
  3. Apr 12, 2019 at 1:25 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    There’s another member here that posted about doing that a while back, they were pretty good looking sliders too. Sorry, but you’re going to have to search for it :)
    Simpleton likes this.
  4. Apr 12, 2019 at 2:56 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    I'm going to use 1.75" square for the outriggers(from the frame), and 1.5" 0.120”wall round tube for outer portion (the bent tubes). I think 1020 DOM should be good enough. I only have a 1.5” di on my bender otherwise 1.75” would look better.
    The hard part is going to be the frame mounts. If it bolts on then things need to be unbolted / drilled and plate needs to be cut for the bolt on frame mounts. Most of the aftermarket sliders include large sections of 3/16 (?) plate which mounts up frame side.
    weld on should be way less work…
  5. Apr 12, 2019 at 5:22 PM
    yodafr33k
    yodafr33k Well-Known Member
    BC Canada
    18 TRD OR DCSB Cement kings Methods
    Are you bending (roll) the square tubing or weld every mitre cuts? If you're welding the mitre cuts just make sure you put a backing plate inside the tubing, leave about 1/8 gap for weld prep. I made them before and yes it took a lot of abuse.
  6. Apr 12, 2019 at 7:15 PM
    OnHartung'sRoad
  7. Apr 13, 2019 at 2:56 AM
    Pbird74
    17MGMDCSR54x4
  8. Apr 13, 2019 at 4:14 AM
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    Some companies will sell you all the pieces, then you can weld them yourself to help cut down cost. Not sure exactly who but that's what my cousin did on his 4runner.
  9. Apr 13, 2019 at 8:07 AM
    OnHartung'sRoad
    The company who must not be named in this place used to sell a good looking kit to do that. Too bad they “pilfered” money from so many, they once “built” nice stuff!
    Red18Taco707[QUOTED] and svdude like this.
  10. Apr 13, 2019 at 9:25 AM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    First time working with steel or are you already and experienced welder?
