DIY Ram ball mount bracket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ben95, Mar 6, 2021.
  1. Mar 6, 2021 at 10:32 PM
    Ben95
    Ben95 [OP] Well-Known Member
    Ben
    North GA
    2012 TRD OR Grey
    I wanted a clean way to mount a tablet. The teck deck that goes above the climate controls is way too bulky and too high up for what I wanted. I also didn't want anything in the way if I wanted to take it off. And I wanted it pretty low profile with the tablet in. Additionally, I wanted to avoid drilling into visible parts of large trim pieces. I liked this setup. But didn't seem super stiff, and sticks out too much when not in use. So here's what I came up with.
    Honestly pretty easy. Just made a paper template and cut it out of some 1/16" steel plate. Then bent it in a vice.
    I tapped all the holes to 10-32 threads and cut the screws off flush on the back.
    Here's how it goes in. Fits really snug. Used two self tapping screws to secure it.
    Had to take a small trim off the plastic lip below it and make a small cutout in the climate control faceplate. A bit hard to see in the picture. but I took about two inches in length out below the knob that controls where the air is blowing.
    I also ran a charging cable to the mount to reduce wire mess. I used one of the leftover USB ports from my AA/AAA battery charger project here. So I fished it down to the driver footwell.
    The finished product. It's super stiff and feels rock solid.
    I can upload the template to print out if anyone wants to make one. I could also make a few more if there's enough interest in people wanting to buy them.
    tinker_troy, Hawapino and mikkydee like this.
  2. Mar 9, 2021 at 7:02 PM
    Robersmi09
    Robersmi09 Active Member
    I would take one! Looks good
    Ben95[OP] likes this.
  3. Oct 23, 2021 at 11:06 AM
    GOZER
    GOZER Member
    Albuquerque, NM, US, Earth
    2015 DCSB TRD Sport 6MT, previously a 2006 AC TRD Off-Road 6MT
    aFe, Volant, Apex, Cali-Raised, Excelon, SOS, SCS, Icon, Meso, AJT, JL, ...
    Looks pretty good. For a second I thought it would be just as flimsy as the Panavise solution, but the Panavise puts the Ram ball too far from the mounting screws. So you end up with a lot of flexing in the metal when bouncing down the road. This seems like it's about as close to the screws as possible, further reinforced by keeping it against the dash panels. :thumbsup:
