DIY: How to Remove and Disassemble the Gauge Cluster on a 95-04 Toyota Tacoma (VIDEO)
Discussion in '1st Gen. Tacomas (1995-2004)' started by ProStreetDriver, Jul 11, 2020.
  1. Jul 11, 2020 at 10:14 PM
    ProStreetDriver
    ProStreetDriver [OP] Active Member
    01 Tacoma TRD 4wd
    None as of yet
    Video tutorial on how to remove the gauge cluster on first generation Toyota Tacoma. You may notice some variations between the years, this is a 2001. The reason for removing the cluster is that my temperature started acting up again, so I’m looking into a common problem for these trucks. The same issue can cause a faulty fuel gauge too.
    https://youtu.be/S9bhcQat6Hs
    tacoma_ca, 4xdog and mattyosh like this.
  2. Jul 12, 2020 at 1:04 AM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Nicely edited for time efficiency. Did cleaning the terminals and tightening the screws solve the problem?
    ProStreetDriver[OP] likes this.
  3. Jul 12, 2020 at 7:36 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    That's a really good tutorial. I've been into my two Gen 1 IPs multiple times, yet still learned some tips. I like the idea of the paperboard wedges to help get the gauge cluster lens off.
  4. Jul 12, 2020 at 9:55 AM
    ProStreetDriver
    01 Tacoma TRD 4wd
    None as of yet
    Thank you! Yep, it solved the problem. Been driving around for over a year without a temp gauge lol. Was installing a head unit so I figured it was the perfect opportunity to pull the cluster too.
    Thank you!
    tacoma_ca[QUOTED] likes this.
