DIY Front Brake Pad Change.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badguybuster, May 20, 2009.
  1. May 20, 2009 at 10:29 AM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Well, I decided to change my front brake pads today. They were starting to squeal once in a while. I changed to Duralast Gold Ceramic pads ($55 at Auto Zone). They come with everything you will need including grease and spring clips.
    This is for informational purposes only, I am NOT responsible if you damage yourself, your vehicle, or anything else. If you are competent, have a professional do it.
    Now, with that said you will need. 1-New brake pads 2-Brake Fluid or a recepticle to catch fluid after bleeding (I made my own). 3-Normal tire changing equipement. 4-Flat and hex head screw drivers. 5-Crescent wrench (or other) to open bleeder valve.
    Step 1: Set your emergency brake and chock the wheels.
    Step 2: Remove your tire (one at a time or all at once it doesn't matter).
    Step 3: Observe your caliper and brake pads. Check your rotor for damage.
    Step 4: Remove the pins holding the brake pads by taking off the retaining clips in the back of each pin. Be careful with the large retaining pin holding the two pads together. It can fly away if you aren't cautious. You can save your clips to reuse or use new ones.
    Step 5: Clean up the caliper some (I painted mine). Open bleeder valve and spread the caliper apart some (I used a wooden dowel to press it open). Be sure to catch the brake fluid other wise you have a mess on your hands. This is what I used.
    Step 6: Grease your pads and slide them into place. Make sure the pad with the little metal bar is to the inside. When you replace your pins, ensure that the lower pin goes through the large retaining clip. Make sure you close the bleeder valve.
    Step 7: Replace your tires. Refill your brake fluid reservoir to factory specs.
    Now, that's it. If you all see that I did something wrong. Please feel free to point it out. After all, this was my first time on a Tacoma. Pretty damn easy.
    dgonzo56298 likes this.
  2. May 20, 2009 at 10:33 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    :p
    Doing mine tomorrow, thanks for the info :)
  3. May 20, 2009 at 10:37 AM
    badguybuster
    Michael
    Welcome. Oh, I ordered my Flowmaster 50 today. Whoo hoo
  4. May 20, 2009 at 11:14 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Nice write up,
    Your calipers look rusted to death for an 06, do they salt the roads there as bad as WI?
  5. May 20, 2009 at 11:21 AM
    badguybuster
    Michael
    Yes, they surely do. Plus, I drive in ALL kinds of mud and muck on a regular basis. That is the main reason I slapped a coat of Rustoleum wheel paint on'em. To help stop the rust a little.
  6. May 20, 2009 at 11:34 AM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    Well, I wouldn't put grease on my brake pads. Did you grease the sides that are contacting the Rotor... scary...
    You can avoid opening the bleed valve if you take the caliper off and pressing the piston back with a C Clamp so you don't have a mess or have to bleed you brakes.
    rleppell likes this.
  7. May 20, 2009 at 11:35 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    nice write up
  8. May 20, 2009 at 11:36 AM
    badguybuster
    Michael
    I found it easier to just bleed them, then to go through removing the calipers. Seemed faster.
  9. May 20, 2009 at 11:39 AM
    papabear050
    yup... more than one way to skin a cat... nice write up BTW
  10. Sep 12, 2009 at 5:26 PM
    parfleet
    parfleet Well-Known Member
    Rex
    Pensacola, FL.
    05 PreRunner, SR5 Package, 4.0 Engin
    Front Bush Guard with 100 Watt Driving Lights, Color Match Tonel Cover. Cold Air Intake By True Flow,added an additional 26 HP.
    Greetings From Parfleet hailing from Pensacola, FL.
    I have an 05 Tacoma PreRunner and I'm doing the breaks tomorrow morining, Sunday, September 13, 2009. I must say you did a super job on explaining how to do the front brakes on the 05 Tacoma. I just have a couple of questions.
    *First-Do I really have to remove the caliper if I'm replacing the pads?
    *Second-If the answer to removing the caliber is no, the what is a wooden dowel that you mentioned to press the caliper pistons back in? Just a wooden handle, say a wooden hammer handle?
    *Third-If I do not have to remove the caliper, then would I remove some fluid from the master cylinder, and then push the caliber pistons all the way in, one at a time?
    I guess my questions could be confusing. I guess I could just remove the caliper, open the bleeder valve, push in the pistons with a "C-Clamp" while leaving the old inside pad inplace and then mount the new pads, and remount the caliper?
    Waiting for you advice.
    Thanks!
  11. Sep 12, 2009 at 5:51 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Subscribing
  12. Sep 12, 2009 at 5:59 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Is that a 4 piston caliper? If it is then these brakes are better than I thought.
    Bleeding the brakes is only necessary if you open up the system to let air get in it. Hard wood shims between the pad and rotor should push the pistons back and fluid back into the reservoir.
  13. Sep 12, 2009 at 5:59 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Change pads when they are the same thickness as as the backing plate. Take the top off the master cylinder. Put C Clamp on the back of caliper and face of inside pad. Tighten up the
  14. Sep 12, 2009 at 6:03 PM
    parfleet
    Rex
    Pensacola, FL.
    Yes, the PreRunner has 4 piston calibers and a 6-lug pattern.
  15. Sep 12, 2009 at 6:33 PM
    george3
    New Jersey
    Change pads when pad is the thickness of the backing plate. Take the top of the master cylinder off. You shouldn't have to mess with the bleeder. Put a C Clamp on the back of the caliper and inside pad. Tighten C Clamp which will push the piston in. Use marine grade antisize on sliding parts like pins pads slide on and where backing plate slides on caliper. When you take the caliper off hang it with a old wire coat hanger so it's not hanging on the hose. Put it back together and don't for get to put the cap back on the master cylinder. This is probably clear as mud but should help once you get into it. Like he said, if you screw up it's not my problem and if you are not comfortable doing this kind of work you probably shouldn't. Work safe be safe.
  16. Sep 12, 2009 at 7:40 PM
    parfleet
    Rex
    Pensacola, FL.
    I just have one final question----this is my first time at doing brakes on an ABS system. I have been told that you can't back brake fluid up into the system like you could on a vehicle without ABS and the reason is that you could damage the ABS Power Module which is about a $1200 unit on the TRD and PreRunner. I just don't know if this is so. You are about the third person that has told me to just remove some fluid from the master cylinder and use a "C-Clamp" and just push in the caliper piston. I have been told by others just to open the bleeder valve, atach a bleeder hose to it, and push the piston in with a "C-Clamp." This does two things. First it removes possible sediments from the caliper and secondly, you don't damage the ABS Brake Module by bleeding this way.
    What is your opinion and others that may be reading this.
    Thanks!
    Parfleet from Pensacola, FL.
    Volt likes this.
  17. Sep 12, 2009 at 7:53 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    totally agree i've never done it like that.but some like to
  18. Sep 12, 2009 at 8:16 PM
    george3
    New Jersey
    You'd better check with chris4x4, he's the resident mechanical guru. I have a 08 SRS and don't know if it is the same as a TRD or Pre Runner. I haven't had 2 do brakes on that yet. I had a 2000 and did brake jobs on that with no problem. I don't remember if it had ABS or not. I'll ask Chris to check this post out. I wouldn't want you to mess up on my say so. I've been doing my own brakes for ever but I know nothing of $1200 modules and don't want 2 B responsible for a $1200 mistake.
  19. Sep 12, 2009 at 8:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I too have heard you can screw up the ABS if pushing the pistons in without the bleeder open. I have done it in the past with no problems, but that was on a 2 channel ABS system, and my 2000 Tacoma. I'll have to find out if it hurts the second gens or not.
  20. Sep 12, 2009 at 8:32 PM
    jfr02
    abs does not matter.i worked at caddillac dealership for 6 years and a independent garage for 3. never once did i ever see or hear of a problem with abs when changing pads.so you would be just fine compressing the piston without opening the bleeder.and as far as having to remove fluid from the resivor,as long as someone didn't ad fluid you will be fine.which brings me to a point DO NOT ADD FLUID if the resivoir is low.if the fluid level is low it means you have a leak or you pads and or shoes need replaced.
