DIY: Fishing Rod Holder Using Rotopax Mount
Discussion in 'Boating & Fishing' started by PuffDr4gon, Apr 7, 2013.
  1. Apr 7, 2013 at 1:33 PM
    PuffDr4gon
    PuffDr4gon [OP] Well-Known Member
    Joe
    Earth
    2013 TRD Sport 4.0
    Got mods?
    This project came to mind about a month ago after I bought my first Taco!
    I needed a way to carry my rods in the bed of the truck with the tail gate down while transporting my kayak. I wanted a system that would let me:
    1. Utilize the Toyota rail system
    2. Be inconspicuous and not protrude above the bed of the truck (the rod holder itself, not the rods ;))
    3. Allow me to transport several rods at once
    Being that I don't have a metal bender or any other means to fabricate my own mount I had to think outside the box. That's when I found Rotopax's mount for their gas cans designed specifically for the Toyota rail system. So I ended up buying two of them and here is the result. I am very please with the way it turned out and it took me less then 30 minutes to fabricate the whole thing!
    So far this system has proven very sturdy and I don't notice any rattling coming from the back besides the occasional rods tapping against each other. I do throw small bungee cords over the rods just in case, but I think it would be hard for them to fly out on their own.
    The best part is that I can unmount the rod holders and still use the Rotopax mount for cans if needed.
    Parts needed:
    2-Rotopax mounts (http://rotopax.com/Toyota-Nissan-Truck-Plate-Pack-Mount.html)
    2-Berkley tube rod holders: found mine at Dick's-rattle canned them grey (http://www.basspro.com/Berkley-Tube-Rod-Holder/product/20678/)
    4-8x5/8 Bolts
    4-8x5/8 Nuts
    Permatex Blue Thread Locker
    Power drill
    3/16 Drill Bit
    Oil (I used WD40)
    First, figure out where you want to mount the Rotopax in your bed. I have a tool box so I opted to mount it towards the rear.
    Second, decide where you want to mount the rod holder and use a pencil to mark the two spots you will drill later on. I decided to just eyeball it and not get too specific with measurement. Be sure to measure the rod holder while the Rotopax is on the truck so you know what angle will be best for you.
    Here you can see my pencil marks I will use as indicators of where to drill.
    Third, unmount the Rotopax and bring to a safe spot to drill. A large piece of wood would be preferable, but I used my recycling can turn upside down. Cover your pencil mark with oil (I used WD40 because it was there, but motor oil would work nice too). Use oil so that the drill bit & metal don't over heat.
    Fourth, using a 3/16 drill bit. Drill the spot you marked with the pencil.
    Fifth, repeat for the second pencil mark and clean up shavings. Here you can now see the two new holes that will be used to mount the Berkley rod holders.
    Sixth, using an 8x5/8 bolt & nut-mount the rod holder to the Rotopax. Be sure to use some threadlocker to help keep it secure. Here is the final result.
    LOL, my hood is still popped
  2. Apr 7, 2013 at 1:45 PM
    Dantwenty2
    Dantwenty2 Well-Known Member
    Saugus, CA
    2009 TRD OFF-ROAD DCSB
    Fox 2.0 coilovers, yellow fogs, Peltyfry bed light bar with Rigid Duallys.
    Looks pretty nice! I put mine in the rear window and close it on them lightly. I don't know what ill do when I put the yak in the back, but this is a cool looking option.
  3. Apr 7, 2013 at 2:51 PM
    Usmcsantosj
    Usmcsantosj Well-Known Member
    Jovani
    Orlando, Florida
    2013 TRD Sport
    By order: Tinted windows, WeatherTech liners added, NFab's, bar caddy center console, plasti-dipped emblems and rims.
    If I was into fishing this would be my next mod for sure! Looks very nice, dude.
  4. Apr 9, 2013 at 2:12 PM
    PuffDr4gon
    Joe
    Earth
    2013 TRD Sport 4.0
    Got mods?
    I've done this plenty off times and still managed to break a rod tip! It was really easy to make if you want to go this route
    Thanks!
  5. Apr 15, 2013 at 5:18 AM
    eaglesfn5402
    eaglesfn5402 Well-Known Member
    do the rotapax mounts just slide/snap into the bed rails?
  6. Apr 15, 2013 at 1:17 PM
    PuffDr4gon
    Joe
    Earth
    2013 TRD Sport 4.0
    Got mods?
    No, it uses a t-slot nut type design. You have to bolt it on using the hardware that came with the mount. It's very easy and all you need is the correct size allen key.
  7. Jun 6, 2013 at 4:48 AM
    Patmac
    Patmac Well-Known Member
    Pat
    Chesapeake, VA
    14 TRD Sport
    20% tint, weather techs, icon stage 3. n-fab, bhlm, retrofits, SCS SR8, 285s
    nice tail lights haha
  8. Jun 6, 2013 at 4:52 AM
    HombreSteven
    HombreSteven Needs money for mods
    Tampa
    2011 Reg cab 4x4
    K&N air filter, Aries bull bar; not much YET
    ^^ agreed. And That looks very nice I'll def look into that
  9. Jun 6, 2013 at 4:58 AM
    aj hank
    aj hank Well-Known Member
    AJ
    412 PA
    09 Regular cab
    Hi/lo HIDs, window tint, keyless entry
    Nice mod! Definitely a good idea
  10. Jun 6, 2013 at 5:53 AM
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    I would pay you to make me 2 of these and ship them to me..... let me know
  11. Jun 7, 2013 at 8:26 PM
    HombreSteven
    Tampa
    2011 Reg cab 4x4
  12. Jun 8, 2013 at 7:16 PM
    PuffDr4gon
    Joe
    Earth
    2013 TRD Sport 4.0
    Got mods?
    Thanks guys! It's a pretty simple rod holder that works well. I have since discontinued using the bungee cords to strap in the rods as they stay in place all by themselves. From 70mph on the freeway to back dirt roads the rods stay locked in!
  13. Jul 12, 2013 at 8:38 AM
    CDSurfPhotography
    CDSurfPhotography Well-Known Member
    Cody
    San Diego
    06 PreRunner
    very nice idea, hope to do this in the near future
  14. Sep 9, 2013 at 9:14 AM
    EFalco50
    EFalco50 Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
    I like it!
  15. Sep 16, 2013 at 9:22 PM
    stag808
    stag808 New Member
    Honolulu
    13 Tacoma 4dr 4WD
    I had posted this earlier. You can make your own t-bolts using 1" washers and rod holders (pvc pipes) very cheaply to accommodate your fishing needs. I made mine to accommodate up to seven Penn 50 and 70 conventional reels (very big and heavy).
  16. Sep 17, 2013 at 12:25 AM
    PuffDr4gon
    Joe
    Earth
    2013 TRD Sport 4.0
    Got mods?
    Cool design. Looks solid. I'm glad it works for you, but it like I said in my original thread I needed a design that did not protrude above the bed rail. Nor did I want to utilize the entire rail system. I have a big Shimano TLD on a trolling rod that this system works fine on as well! Tight lines!
  17. May 20, 2014 at 9:35 PM
    Tacoma Off Course
    Tacoma Off Course Well-Known Member
    Austin
    Houston, KS
    2005 DCSB Prerunner SR5
    Stuff
    sub'd. Great work! will be doing this soon.
  18. Jun 11, 2014 at 4:12 PM
    TheDuke0fHurl
    TheDuke0fHurl Well-Known Member
    Boston
    2013 DCLB SR5
    Looks nice. Probably gonna do this this weekend. Do you think mounting them so the rods lean toward the cab would work better?
  19. Jun 17, 2014 at 11:36 AM
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
    It looks nice! Quick question, what kind of tool box do you have for your Tacoma
  20. Sep 4, 2014 at 9:08 PM
    PuffDr4gon
    Joe
    Earth
    2013 TRD Sport 4.0
    Got mods?
    Kobalt slimline. I painted the badge black.
