DIY - Check/Replace your CPS Sensor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChrisK7UND, Jun 22, 2017.
  1. Jun 22, 2017 at 1:50 PM
    ChrisK7UND
    ChrisK7UND [OP] Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    After combing through many threads on this I decided to check my CPS in my 2017 TRD Sport to see if I have the new version of the sensor. Mine was made in Mexico with a build date of 8/16. These steps can be used to check for the "hash" marking on the newer sensor OR replace the CPS. They run about ~$100 online.
    1). Remove the passenger wheel to make gaining access much easier. Once the wheel is off, use a panel removal tool or screwdriver to remove the top plastic keepers on the rubber flap toward the rear of the wheel well and let it flop down for access to the sensor.
    2). Remove the connector from the sensor. Hint: There is a rubber boot over the connector you need to pull back to press the plastic retainer clip to remove the connector.
    3). Remove the 10mm bolt that holds the sensor to the block and gently pull the sensor and it will pull out of the block.
    4). Inspect the sensor for the "hash" mark which is widely believed to denote the new version of the sensor. See mine below which has the hash mark circled.
    5). At this point either reuse your sensor if you believe it to be the newer version OR replace the sensor with a new one. Reverse the procedure of removal and be sure to torque the 10mm bolt to 7 ft-lbs or 10nm. Plug in the electrical connector and reinstall the two plastic retainers for the rubber cover and you're done!
    wahoobie, boynoyce, nartmot and 12 others like this.
  2. Jun 22, 2017 at 1:57 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Great writeup, and also here.
    There may be a recall on some of these CPS.
  3. Jun 22, 2017 at 2:26 PM
    JGS2164
    JGS2164 Active Member
    Jake
    East Tennessee
    2017 Tacoma TRD OR DCSB
    Nice write up, thanks!
    ChrisK7UND[OP] likes this.
  4. Jun 22, 2017 at 2:32 PM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    Great write up, changed mine a month ago. Those doing this might consider keeping your invoice for the new sensor. Under NHTSA rules Toyota has to reimburse you for the cost of the part for a safety recall if you do it yourself. The rules are on the NHTSA website in the safety recall section. Also you can enter the information on the toyota owners app for maintenance performed, and if you take it in for service your dealership won't pull any crap about having to replace the sensor (15 min job) and give you a yellow Yugo to drive while they spend the day looking for the right part.
  5. Jun 22, 2017 at 2:54 PM
    ChrisK7UND
    Colorado
    Great idea! Since I am not on the recall list, I'll keep the receipt in case they add mine so then at that point I'll get reimbursed for it. But for piece of mind I'm gonna change mine.
  6. Jun 22, 2017 at 2:58 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    IS the sensor already out in the first picture?
    It goes from zoomed out to zoomed in, and the zoomed out picture appears to already have the sensor removed..but its shown first. Unless I'm not following this sequence.
    Its a tad confusing.
  7. Jun 22, 2017 at 3:32 PM
    ChrisK7UND
    Colorado
    Haha yes. I forgot to take a picture of taking the rubber flap down so I used the pic with the sensor out to show the fact the wheel off gives you much better access to the sensor. The steps are dead on and should not be confusing.
  8. Jun 22, 2017 at 6:26 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Nice writeup! I have one question, and I'm NOT trying to be a dick... Once you pull the boot back and disconnect the harness, can the marking on the CPS be seen without removing it from the block?
    IronPeak likes this.
  9. Jun 22, 2017 at 7:26 PM
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    Even though yours had the mark, thus assuming it's the new version of the sensor, did changing it have any effect on the vehicle?
  10. Jun 22, 2017 at 8:48 PM
    ChrisK7UND
    Colorado
    Actually that is a great question. I had a hard time seeing it mounted and I also wanted to pull it to see how the replacement would go so I could make the write-up since I was that far. If your eyes are better than mine you may be able to see the mark while still mounted.
    MOC221_[QUOTED] likes this.
  11. Jun 22, 2017 at 8:49 PM
    ChrisK7UND
    Colorado
    I haven't changed it yet. Before I ordered one I wanted to see how hard the job would be before I spent the money. It is a 15min or less job. I don't believe I currently have any problems so when I replace it, which I will, I doubt I'll notice any difference.
    cwolgy88[QUOTED] likes this.
  12. Jun 23, 2017 at 5:20 AM
    MOC221_
    Frank
    Fair enough :thumbsup:
  13. Jun 23, 2017 at 6:03 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    You guys are lucky, I had a hell time removing that dam connector.
    Having said that, I've long have had the suspicion this little (cps) sensor maybe responsible for some driving concerns, maybe even some transmission hiccups some complain about. Sounds far fetch I know, but in reading some of the failure threads and symptoms, its there.
    And the job it has to do because of the Atkinson engineering design, it may have to be more precise than other specs, but that's just imo.
    Cheers!
  14. Jun 23, 2017 at 6:25 AM
    cwolgy88
    Cody
    None as of yet
    So did replacing yours result in fixing some of your concerns/issues??
  15. Jun 23, 2017 at 6:30 AM
    The hammer
    No, I did not have any concerns or issues up to the time, but I new it was a problem by the failure rate others were having.
    Cheers!
  16. Jun 24, 2017 at 6:24 PM
    Cpodcpod
    Cpodcpod Active Member
    2016 TRD DBL cab
    Leather seats, leveling kit, tinted windows, grill, TRD bead lock wheels, tires, OEM Audio Plus sound system
    2016 TRD. Being told I have a defective CPS. Truck stopped running several times over the course of a two hour trip. Would not start for about 10 min after it died, but than would run for quite a while. Seems like when I excelerated hard, the truck would die. Kind of makes sence now. Think I will keep an extra one with me just in case. This post and pics was extremely helpful. Nice job.
  17. Jun 24, 2017 at 10:44 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    Nice write up OP ! It's post like this that truly helps TW members as I for one didn't even know where that sensor was located.
    :hattip:
  18. Jun 24, 2017 at 11:34 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
  19. Jun 25, 2017 at 3:13 AM
    MOC221_
    Frank
    Thank you for posting this. Now, can you recall any, and I mean any, weirdness from the engine prior to these stalling episodes? Something that led up to the stalls? I've had severe bogging sometimes when on the throttle hard. Other times the engine seems to cut out for a split second when at idle. Most of the time it runs fine though...
    BTW, what was your build date and are you on the CPS recall?
  20. Jun 25, 2017 at 7:06 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Pro tip: Remove the sensor from the block first, then disconnect the connector.
