DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Dec 6, 2017 at 11:10 PM
    #441
    tacozord
    tacozord [OP] Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    OUCH! That looks like it might hurt.
  2. Dec 6, 2017 at 11:13 PM
    #442
    tacozord
    2015 DCLB 4wd SR5
    Yeah, the Weatherpack terminals are different than the Metri-pack.
    Weatherpack is kind of like a hollow tube.
    Metri-pack is more like a flat blade screwdriver.
  3. Dec 6, 2017 at 11:15 PM
    #443
    tacozord
    2015 DCLB 4wd SR5
    I do, but that recommendation is only for removing the Metri-pack terminals from the RTMR. I use the official Metri-pack tool for Metri-pack connectors and the Weather-pack tool for its connectors.
  4. Dec 7, 2017 at 8:45 AM
    #444
    Sprocket1505
    Sprocket1505 Well-Known Member
  5. Dec 8, 2017 at 3:23 PM
    #445
    Philly100000
    Philly100000 Unknown Human
    Phillip
    Regina, Saskatchewan, Canada
    2011 Toyota Tacoma 4x4 DCLB TRD Sport Edition
    For the Weatherpack I used a straw :D
  6. Dec 8, 2017 at 10:49 PM
    #446
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Cute, I keep most sizes of the K&S precision brass tubing around for a variety of projects. I'm sure one would do as well.
  7. Dec 9, 2017 at 8:33 PM
    #447
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    @2015whitetaco this is the thread i was talking about. I did the 10relay /40 fused bussman (but i made one post + and the other ground)
    2015whitetaco and Tac0maSteve like this.
  8. Dec 9, 2017 at 9:26 PM
    #448
    Tac0maSteve
    Tac0maSteve Well-Known Member
    East Bay, CA
    '15 TRD Off Road Icon Ext. Travel
    DCSB... No mods here
    I did the exact same setup as you. Been working perfectly.
    rob1208[QUOTED] likes this.
  9. Dec 10, 2017 at 8:04 AM
    #449
    2015whitetaco
    2015whitetaco Well-Known Member
    Pleasant Hill
    2000 Ford F-250 7.3 powerstroke 96 4runner POS
    :eek: @rob1208 thanks man this thread is awesome
    I haven't read through it yet but I can see this is what im going to be doing
    thank you @tacozord for doing this write up i will probably be spending a whole weekend in the near future using this write up
    tacozord[OP] and rob1208 like this.
  10. Dec 10, 2017 at 8:22 AM
    #450
    raccoonrough
    raccoonrough Well-Known Member
    Eastern Panhandle of WV
    2017 Tacoma TRD -OR-DCLB Quicksand
    Awesome....now i need to read this like 10 times as step one. Thanks a million!
    tacozord[OP] and 2015whitetaco like this.
  11. Dec 10, 2017 at 8:32 AM
    #451
    2015whitetaco
    Pleasant Hill
    that was my thought im probably gonna spend a full day just reading this thread over and over and over again
  12. Dec 10, 2017 at 8:45 AM
    #452
    raccoonrough
    I know exactly what you mean. I am completely and totally new to wiring anything into an auto. So, this is not going to come natural for me.
  13. Dec 10, 2017 at 8:54 AM
    #453
    bagleboy
    Scott
    Norcal, Santa Rosa
    Read other build threads too, I'm several months into reading this and just a few weeks ago found out how and why I'd want a couple 5 pin relays instead. I already had the Bussman and 5 - 4 pin relays so I've a couple extras (or maybe use two external relay mounts)but at least I haven't assembled it so I won't need to take it apart. Tacozord did(and still does) an amazing job with the op and follow up advice but his layout is tailored to the goal of 5 relayed switches in the sunglasses holder. The better you understand how it all works the better you'll be able to meld ideas from other build threads to truly customize your rig while keeping it organized. With a base model Tacoma I've an embarrassment of riches in empty switch locations but I still want to have each group have some internal logic. Also, the dash illumination is white but all the aux switches are green and I want to change those LEDs to white. In most cases it should be fairly simple and I'll post a how-to based on seat heaters.
  14. Dec 10, 2017 at 9:23 AM
    #454
    rob1208
    Rob
    SF Bay Area
    Haha i did that. For me, the longest part was verifying i ordered everything, had hit quantity minimums, etc.
    Once i had the parts on hand, that stuff was easy
    raccoonrough[QUOTED] likes this.
  15. Dec 23, 2017 at 2:36 PM
    #455
    Mako99
    Mako99 Well-Known Member
    Virginia
    2012 Taco Sport
    This is a great write up. I've mainly been reading the first portion for the build, and I have a few questions. I apologize up front if the answers are buried in here somewhere and I missed it.
    1) @Sandman614 builds a great RTMR. I do like how the switch harness was made in this setup. With that being said my RTMR is already built. How hard is it to pop out the switch wires IOT replace it with a switch harness that I make like in this writeup?
    2) I have the Rigid SRM backup lights. I have a 3 position switch. I will have it set for manual on; manual off; and On with Reverse. The relays are all 4 pin relays. I think the Relay that comes with the SRM is a 5 pin? I take it I'm going to have to pull the RTMR apart IOT make one a 5 pin?
    Thanks for the help/insight.
    Sandman614 likes this.
  16. Dec 23, 2017 at 2:53 PM
    #456
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    https://www.youtube.com/watch?v=Z3mB6ZC09sU
  17. Dec 23, 2017 at 3:36 PM
    #457
    Mako99
    Virginia
    2012 Taco Sport
  18. Dec 23, 2017 at 5:27 PM
    #458
    bagleboy
    Scott
    Norcal, Santa Rosa
    The fifth pin location on the rtmr has is covered by an adhesive plastic that you can cut away with a razor knife.
  19. Dec 23, 2017 at 6:17 PM
    #459
    Sandman614
    Tim
    '06 SR5 Off Road
    You only need to do that If you use a 5 pin relay.
  20. Dec 24, 2017 at 9:35 AM
    #460
    bagleboy
    Scott
    Norcal, Santa Rosa
    Mako99 mentioned using a 5-pin relay and I'm using a couple in mine. For simple spst(off/on) switching they're unnecessary but for more complicated switching they're handy. There are even more complex relays that can be fused through the bussman but mounted separately.
